H20 graphics card deployment VSS exception
Hi,after the reboot the nvidia-fabricmanager version changed, I’m not sure why, this time I rebooted the server, last time I didn’t do anything.
The graphics card driver (535.161.08) in the official tutorial caused the nvidia-smi command to get stuck.
The problem was solved after replacing the driver(550.127.08) recommended by @yuweiw .
Problem location:after completing Installing a Kubernetes Cluster
k8s cude verification failed.
nvidia-cuda-validator.log (3.8 KB)
nvidia-fabricmanager has a default installed version that does not match existing graphics card drivers(I’m very sorry that the default version was not recorded due to the tight schedule.).Reinstalling nvidia-fabricmanager that is consistent with the graphics card driver can solve the problem.
Reinstall nvidia-fabricmanager
Thanks to @yuweiw for providing the solution
driver_version=<version>
driver_version_main=$(echo $driver_version | awk -F '.' '{print $1}')
wget https://developer.download.nvidia.cn/compute/cuda/repos/ubuntu2004/x86_64/nvidia-fabricmanager-${driver_version_main}_${driver_version}-1_amd64.deb
sudo dpkg -i nvidia-fabricmanager-${driver_version_main}_${driver_version}-1_amd64.deb
Restart and make the service take effect
systemctl restart nvidia-fabricmanager
systemctl enable nvidia-fabricmanager
Yes. You need to make sure the fabricmanager version is exactly the same as the driver version.
