Operating System:
Windows
Linux
GPU Hardware:
H200 NVL
GPU Driver:
Latest (580)
Recommended (573.xx)
Other
Having an issue with NVLink for an 4x H200 setup. Details are below. Any help would be appreciated. Only thing I haven’t tried is the “loose GPU trick” since I was not physically present in the data center to configure this.
Work Flow:
Devices arrived April 2026. Replacement NVLink arrived August 2026.
Installed NVLink and 4x H200 NVL
Configured BIOS (Above 4G Encoding, etc…)
Configured FABRIC_MODE=1 in /usr/share/nvidia/nvswitch/fabricmanager.cfg
Ensured all driver versions are the same (580.173.02)
Haven’t done the loose GPU trick yet.
Main Issue:
It still isn’t showing NV# for connections, replaced NVLink and reseated everything.
Reproduction Steps:
Not sure if this is reproducible or a hardware issue or something else?
Error Code:
Hello and thanks for posting. Actually we really do not cover NVLINK here in this area. This is just for Omniverse.
What I can tell you is the NVLink is older technology and we do not automatically recommend it anymore. It is only recommended on very specific use cases. Each GPU is designed to work alone or together at the software level, without needing to use NVLINK now. Is there a specific reason you need it engaged?
Here is a complete answer from our AI agent on the subject.
Yes—if your H200 systems will run tightly coupled multi-GPU workloads, choose an H200 configuration with NVLink. It is particularly worthwhile for distributed AI training, large-model inference, and HPC applications that exchange tensors, activations, gradients, or KV cache frequently between GPUs.
When NVLink is recommended
| Workload / system design |
Recommendation |
Why |
| 8-GPU H200 SXM/HGX server |
Strongly recommended |
HGX H200 systems use NVSwitch to give the eight Hopper GPUs high-bandwidth, non-blocking GPU-to-GPU communication—up to 900 GB/s per GPU bidirectionally. developer.nvidia |
| 2- or 4-GPU H200 NVL server |
Recommended if GPUs cooperate on one job |
H200 NVL supports 2-way or 4-way NVLink bridge configurations, with up to 900 GB/s for 2-way and 1.8 TB/s for 4-way configurations. resources.nvidia |
| Training large LLMs or MoE models |
These workloads require frequent collective communication and model parallelism, where GPU interconnect bandwidth and latency materially affect scaling efficiency. NVLink is purpose-built as a scale-up GPU fabric. nvidia |
| Independent inference jobs or batch processing |
Usually optional |
If every GPU serves separate requests or runs separate jobs, PCIe plus a good Ethernet/InfiniBand network may be sufficient. |
| A fleet of multi-node servers |
Use NVLink within servers; plan a fast network between servers |
NVLink does not replace cluster networking. NVIDIA’s H200 NVL reference deployment calls for 400 Gb/s BlueField-3 connectivity per two GPUs for cluster-scale performance. resources.nvidia |
Practical choice
For a new H200 purchase:
- Choose H200 SXM/HGX with NVSwitch if you need the strongest 8-GPU single-node performance, want to train or serve large models using tensor/pipeline/expert parallelism, or expect workloads to grow.
- Choose H200 NVL with NVLink bridges for smaller 2–4 GPU systems where the GPUs need to collaborate closely, especially for model serving or moderate-size training.
- Skip NVLink only when your jobs are genuinely GPU-independent and the price premium, power, and platform constraints outweigh the benefit.
Important caveats
NVLink accelerates communication; it does not magically combine several GPUs into one universally shared pool of memory for every application. Your framework and workload must actually use multi-GPU parallelism effectively.
Also distinguish:
- NVLink / NVSwitch: scale-up connectivity inside a server or closely integrated GPU domain.
- InfiniBand or high-speed Ethernet: scale-out connectivity across separate servers.
For H200, the key decision is less “is NVLink modern?” and more “will GPUs exchange data often enough that PCIe becomes a bottleneck?” If the answer is yes, NVLink is generally the right choice. Hopper-based H100/H200 NVLink provides up to 900 GB/s per GPU, while H200 systems with NVSwitch enable full-speed GPU-to-GPU communication across the 8-GPU server. developer.nvidia
