Hi all - could be the wrong spot for this but thought i would raise it anyway…
I am trying to validate the use of H264 client decode with the following setup:
Windows 10 virtual machine running on ESXi 6.5. VM has a GRID P6 GPU assigned using a P6-4Q profile
Thin clients are a mix of Intel NUC but primarily Pentium (Gemini Lake) CPU (using HD605 GPU) and an i3 CPU (Kaby Lake) with an integrated HD620 GPU
NUCs run Ubuntu 18.04 as a locally installed OS (4.15.0-20-generic)
Horizon client installed is 4.7.0 build 7395152
Horizon Agent and Direct Connection plug-in are at version 7.4
I am aiming to confirm whether my client is offloading H264 decode to the NUC GPU. I am assured by our Intel rep that the GPU mentioned above are capable of this function however i see information the Horizon client which tells me that this may not be happening, as per here in the vmware-mks-xxxx.log file:
- RemoteDisplay.allowClientH264 = ‘TRUE’
This refers to the option for H264 decode in the Horizon Client GUI. Confirmed as when removing the tick in the GUI, the value becomes ‘RemoteDisplay.allowClientH264 = ‘FALSE’ with no further H264 entriesRemoteDisplay.allowClientH264 = ‘FALSE
- VNC Client: H264 hardware decoding unavailable
Anyone else have trouble validating or verifying hardware client decode using Horizon and GRID?
