H264 Recorder Without Gstreamer in Jetson
Hi friends,
I have problem about recording h264 in Jetson with sample code that are in “usr/src/jetson_multimedia_api/”. I compile code videoEncoder and use it but recorded file play so fast and it’s fps and bit rate is N/A. In NvVideoEncoder.h we have a class NvVideoEncoder that can set bit rate and fps but result of recording can’t play with appropriate fps.
Please refer to this:
./video_encode -fps param is invalid
If you enable VUI in SPS, the decoder can get information of frame rate. Please check if you enable it.
