Hi,When I parser the sprop-parameter-sets=Z00MH5WgKA9oQAAAAwBAAAAPIQ==,aO48gA==, I got results as follows:
Start dumping SPS:
profile_idc = 77
constrained_set0_flag = 0
constrained_set1_flag = 0
constrained_set2_flag = 0
constrained_set3_flag = 0
level_idc = 31
seq_parameter_set_id = 0
chroma_format_idc = 1
bit_depth_luma_minus8 = 0
bit_depth_chroma_minus8 = 0
seq_scaling_matrix_present_flag = 0
log2_max_frame_num_minus4 = 4
pic_order_cnt_type = 2
log2_max_pic_order_cnt_lsb_minus4 = 0
delta_pic_order_always_zero_flag = 0
offset_for_non_ref_pic = 0
offset_for_top_to_bottom_field = 0
num_ref_frames_in_pic_order_cnt_cycle = 0
num_ref_frames = 1
gaps_in_frame_num_value_allowed_flag = 0
pic_width_in_mbs_minus1 = 39
pic_height_in_mbs_minus1 = 29
frame_mbs_only_flag = 1
mb_adaptive_frame_field_flag = 0
direct_8x8_interence_flag = 1
frame_cropping_flag = 0
frame_cropping_rect_left_offset = 0
frame_cropping_rect_right_offset = 0
frame_cropping_rect_top_offset = 0
frame_cropping_rect_bottom_offset = 0
vui_parameters_present_flag = 1
Start dumping PPS:
pic_parameter_set_id = 0
entropy_coding_mode_flag = 1
pic_order_present_flag = 0
num_slice_groups_minus1 = 0
slice_group_map_type = 0
num_ref_idx_l0_active_minus1 = 0
num_ref_idx_l1_active_minus1 = 0
weighted_pref_flag = 0
weighted_bipred_idc = 0
pic_init_qp_minus26 = 0
pic_init_qs_minus26 = 0
chroma_qp_index_offset = 0
deblocking_filter_control_present_flag = 1
constrained_intra_pred_flag = 0
redundant_pic_cnt_present_flag = 0
transform_8x8_mode_flag = 0
pic_scaling_matrix_present_flag = 0
second_chroma_qp_index_offset = 0
As we can see, gaps_in_frame_num_value_allowed_flag = 0. But I want to get gaps_in_frame_num_value_allowed_flag = 1.
So I want to ask, how to change it? should we set the omxh264 parameter or the caps(‘video/x-h264, stream-format=(string)byte-stream’)?
