I’m trying to reduce the saved video time duration. I thought by changing the framerate the time duration of the video will change but I see no effect. Currently, the saved video is slower than expected.
Can you suggest how can I change the total video duration?
The performance can be capped by the software converter. Please execute sudo nvpmodel -m 0 and sudo jetson_clocks. To run CPU cores at max clocks. This is optimal solution on Jetson platforms since hardware engines does not support 16-bit GRAY. Has to use CPU cores for the conversion.
Thanks for this info. I’ll try this out. But my question is a little different.
Currently, when I save the video, the video plays for 11 sec. But the actual time of capture is around 2 sec. Hence, it looks like the video is in slow motion.
