Anyone who have tried to stream video to Youtube with h265 protocol?
I have tried hlssink, but with no success to stream via HTTP
It may not be clear to know what the usecase is. Please share more information. Other users may have similar experience to give suggestion. And is it specific to h265? Or it also fails in h264 encoding?
Thanks, DaneLLL
Currently the RTMP Protocol only support h264, which has a limitation of 4096 in image width.
My use-case is to live stream a 180 degree field of view.
Youtube support 360 deg. live streaming, This gives 2048 in width for the 180 deg. image I’m processing. This is a huge constraint on the quality of the image, where I’m rather looking at having a width of 4000-6000.
Two options:
Youtube supports h265 through HLS, and that’s why I tried the hlssink
Im trying a stream where the sink is:
… hlssink location=https://a.upload.youtube.com/http_upload_hls?cid=$STREAM_KEY©=0&file=
where the STREAM_KEY is my Youtube key
For information, h265 hardware encoder also has the limitation of 4096 in width. You would need to have width < 4096.
Hi there. Have you solved it? I’m actually using rtmp but I have the h.264 limit. I’d really like to move to hevc.
But it doesn’t looks straightforward. I so an intermediate proxy provided by google but not sure if it will compile on aarch64.
Anyways, any hint would be welcome. Thanks
