Had an interesting bug today with the "updates" panel in DGX dashboard - resolution included
**Hey all, I spent a fair few hours on this. was updating my second Spark when all this started. Hopefully this will help someone else who, like me, wants to keep using the Nvidia recomended update path and has encountered this issue.
fwupd/libfwupd version mismatch after OTA update causes Dashboard “Updates” page to hang indefinitely**
## Summary
After applying the OTA update to DGX OS software version **7.5.0** via the DGX Dashboard, the
Dashboard’s **Updates** page never resolves — it sits on grey skeleton-loading placeholders
indefinitely. Root cause: the OTA update left the `fwupd` daemon package and the `libfwupd`
library package at mismatched versions, causing `fwupd.service` to fail to start. `fwupdmgr`
(the CLI client) then hangs indefinitely instead of failing fast when the daemon is
unreachable, and that hang propagates all the way up through NVIDIA’s own OTA-check tooling
and the Dashboard backend to the browser.
## Environment
- Hardware: NVIDIA DGX Spark (Founders Edition)
- Base image: `DGX_SWBUILD_VERSION=7.2.3` (build date 2025-09-10)
- OTA applied: `DGX_OTA_VERSION=7.5.0` (applied 2026-07-03, via DGX Dashboard)
- Kernel: `6.17.0-1026-nvidia` (aarch64)
- A second, otherwise-identical DGX Spark unit on the same base image, **without** the 7.5.0
OTA applied, does **not** exhibit this issue — used throughout as a known-good comparison.
## Symptom
1. Open the DGX Dashboard → **Updates** page.
2. The **Available Updates** table renders its skeleton/loading placeholder rows and never
populates — no update list appears, and no “you’re up to date” message appears either. The
page is stuck indefinitely in a loading state.
3. Browser DevTools (Network tab) shows the page’s underlying API calls
(`GET /api/v1/ota/status`, plus `available`, `list` requests) sitting in **Pending** state
with 0 bytes transferred — they never receive a response, and never time out client-side.
## Root cause (fully isolated and confirmed)
### 1. The Dashboard backend itself was ruled out first
`journalctl -u dgx-dashboard.service` and `journalctl -u dgx-dashboard-admin.service` show
**no activity at all** when the Updates page is loaded or refreshed — the request reaches
neither service’s logged output, which initially suggested a routing/networking problem. It
does not; these services simply don’t log routine request handling.
### 2. A direct authenticated request to the local API confirms a real backend hang
Extracting the Bearer token from the browser’s own request (DevTools → Network → the
`status` request → Headers) and hitting the Dashboard’s real listening port directly and
locally (found via `sudo ss -tlnp | grep dashboard`, confirmed at `127.0.0.1:11000`):
curl -v http://localhost:11000/api/v1/ota/status \
-H "Authorization: Bearer " \
--max-time 10
This connects instantly (TCP handshake succeeds) but the request itself **times out after
10 seconds with 0 bytes received** — a genuine, reproducible backend hang, independent of the
browser, any SSH tunnel, and any external network path (confirmed separately that this
machine has fully working outbound HTTPS connectivity to `api.ngc.nvidia.com`).
### 3. The hang traced to NVIDIA’s own OTA-check tooling piling up stuck processes
Every time the Updates page is loaded (or the direct curl above is run), a **new** instance of
/opt/nvidia/spark-ota-check/check_ota_status.py is-ota-available
is spawned and never exits (confirmed via repeated `ps aux | grep -i ota` showing an
accumulating pile of `S`-state processes across multiple minutes, none reaped even after a
`systemctl restart dgx-dashboard.service`).
### 4. Traced through the script’s own source to the exact blocking call
Reading `/opt/nvidia/spark-ota-check/check_firmware.py` (package `nvidia-spark-ota-check`,
version `1.0.14-1`, byte-identical on both the affected and unaffected unit — so this is not
a code bug in this package itself) shows `check_firmware()` calling, among other checks:
```python
def _get_fwupd_devices() → dict[str, str]:
raw = run_cmd(\["fwupdmgr", "get-devices", "--json"\])
`run_cmd()` (in `utils.py`) does set a `timeout=30` on its internal `subprocess.run(…)`
call — but that timeout does not appear to be effective in practice, and the underlying
`fwupdmgr` invocation itself blocks indefinitely (confirmed independently, see below), which
appears to defeat the intended timeout handling.
### 5. Confirmed: `fwupdmgr` itself hangs indefinitely, independent of any NVIDIA tooling
$ timeout 15 fwupdmgr get-devices --json
$ echo “exit code: $?”
exit code: 124
`124` = killed by `timeout` after 15 seconds. This reproduces with the stock `fwupdmgr` CLI
directly, with no NVIDIA-specific code involved at all.
### 6. Confirmed: the actual root cause is a stuck `fwupd.service`
$ systemctl status fwupd.service
Jul 04 04:41:03 fwupd[180179]: Failed to load daemon: failed to load engine:
libfwupd version 1.9.34 does not match daemon 1.9.30
Jul 04 04:41:03 systemd[1]: fwupd.service: Main process exited, code=exited, status=1/FAILURE
$ dpkg -l | grep -i fwupd
ii fwupd 1.9.30-0ubuntu1~24.04.1 arm64 Firmware update daemon
ii fwupd-signed 1.52+1.4-1 arm64 Linux Firmware Updater EFI signed binary
ii libfwupd2:arm64 1.9.34-0ubuntu1~24.04.1 arm64 Firmware update daemon library
ii nvidia-lvfs-config 25.09-1 all Provides fwupd configuration for NVIDIA LVFS
The `libfwupd2` library was upgraded to `1.9.34` as part of the 7.5.0 OTA, but the `fwupd`
daemon package itself was **not** upgraded to a matching version, leaving them mismatched.
`fwupd.service` explicitly detects this at startup and refuses to run — which is correct,
safe behavior on `fwupd`'s part. The actual bug is that **`fwupdmgr` (the client) does not
handle “daemon unavailable/failed to start” gracefully** — instead of erroring out
immediately, it blocks indefinitely, and that indefinite block is what cascades upward
through every layer described above.
The known-good comparison unit, which never received the 7.5.0 OTA, has no
`DGX_OTA_VERSION` field set at all and its `fwupd`/`libfwupd2` versions are presumably still
matched at their original base-image versions — consistent with this being introduced
specifically by the 7.5.0 OTA’s package set, not a pre-existing condition.
## Fix (applied, confirmed working)
sudo apt update
sudo apt install --only-upgrade fwupd
`apt` resolved this correctly on its own: the fix is not "upgrade `fwupd` to match the old
`libfwupd2`" but rather that a current `fwupd` release now depends on **`libfwupd3`**
(superseding `libfwupd2` entirely). The upgrade pulled in `libfwupd3` alongside the newer
`fwupd`, leaving `libfwupd2` orphaned (cleaned up afterward with `apt autoremove`).
After the upgrade:
● fwupd.service - Firmware update daemon
 Active: active (running)
Jul 04 04:47:34 fwupd[193499]: FuMain fwupd 2.0.20 ready for requests
{ …full device list… }
$ echo $?
0
`check_ota_status.py is-ota-available` no longer hangs or accumulates stuck processes, the
direct `curl` to `/api/v1/ota/status` returns immediately, and the Dashboard’s Updates page
loads correctly.
## Requested fixes
1. **`fwupdmgr` should not block indefinitely when `fwupd.service` fails to start or is
unreachable.** It should fail fast with a clear error (as it presumably would for a
simple “connection refused” case) rather than hanging — this single fix would have
prevented the entire cascade described above, independent of whether the underlying
version-mismatch bug is also fixed.
2. **The 7.5.0 OTA recipe/package set should upgrade `fwupd` and `libfwupd2`/`libfwupd3`
together, atomically**, so a fresh OTA application never lands a system in this
mismatched state in the first place.
3. Consider having `/opt/nvidia/spark-ota-check`'s `run_cmd()` wrapper genuinely enforce its
intended timeout regardless of the underlying command’s own hang behavior (e.g. via
process-group termination on timeout), so a single misbehaving external tool cannot make
this OTA-check script itself hang indefinitely and accumulate orphaned processes on every
retry.
## Reproduction is fully isolated and independent of any unusual configuration
This was diagnosed on a unit that also has a ConnectX-7 fabric link manually configured to a
second DGX Spark for clustering purposes. That configuration was explicitly ruled out as a
contributing factor during diagnosis — `ib_write_bw`, `mstflint`, and all Mellanox-related
processes were confirmed absent at the time of every reproduction, and `mstflint -d
0000:01:00.0 q` (queried directly, bypassing the OTA-check tooling entirely) returns
correctly and instantly on the affected unit. The hang is isolated entirely to `fwupdmgr` /
`fwupd.service`, unrelated to networking, clustering, or ConnectX-7 hardware state.
@thrashvtx moved the topic to the Spark forum.
