I am trying to use __half2uchar_rz to convert a uint8_t into a half in my device kernel.
Unfortunately when I compile it, I get this error:
error: identifier "__half2uchar_rz" is undefined
Why won’t it compile when the other intrinsics work fine (e.g. __half2uchar_rz)?
This is for Jetson Nano (compute 5.3). Thanks.
you’ll need a very recent CUDA install for this to work. It may not be available on your Jetson Nano. I suggest asking on the Jetson nano forum.
__half2uchar_rz
does not convert a uint8_t to a half.
In the first sentence, the error indicates __half2uchar_rz
. In the second sentence, you seem to be suggesting __half2uchar_rz
works fine.
I failed to copy and paste correctly.
__half2ushort_ru works fine.
__half2uchar_rz does not.
Okay I’ll update CUDA. Thanks.
system
Closed
4
