Handgun-Detection-Deepstream
Based on current situation around the world, there is major need of automated visual surveillance for security to detect handgun .Every now and then ,there is a gunpoint store robbery , any hostage situation or a shootout .Applying this application in our surveillance system, we can attempt to save human life and accomplish reduction in the crime rate .
To automatically detect weapon from the RTSP inputs of security camera available in the premise of Stores,Banks,Home etc.
Citations
Introduction
Handgun detection Application consists of an Intelligent Video Analytics Pipeline powered by Deepstream and NVIDIA Jetson Xavier NX / NVIDIA Jetson Nano 2GB (I personally used Jetson Nano for this project but the same setup can be replicated for Jetson Xavier NX for High FPS)
This project is a proof-of-concept, trying to monitor the safety of people in any possible armed robbery , terror situations using Computer Vision and and is accelerated using NVIDIA Deepstream and can be done with a surveillance camera or raspberry pi v2 (CSI) and an onboard Jetson platform.
Camera (CSI) was tested as an alternative to lower quality CCTV cameras as those can omit False Positives and False Negatives due to the low image resolution.
Deepstream Setup
This post assumes you have a fully functional Jetson device. If not, you can refer the documentation here.
1. Install System Dependencies
sudo apt install \
libssl1.0.0 \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
libgstrtspserver-1.0-0 \
libjansson4=2.11-1
2. Install Deepstream
Download the DeepStream 5.0.1 Jetson Debian package deepstream-5.1_5.1.0-1_arm64.deb
, to the Jetson device. Then enter the command:
sudo apt-get install ./deepstream-5.1_5.1.0-1_arm64.deb
cd /opt/nvidia/deepstream/deepstream-5.1/sources
Running the Application
1. Clone the repository
This is a straightforward step, however, if you are new to git or git-lfs, I recommend glancing through the steps.
First, install git and git-lfs
sudo apt install git git-lfs
Next, clone the repository
# Using HTTPS
git clone https://github.com/Abhishek97M/Handgun-Detection-Deepstream.git
#Using SSh
git@github.com:Abhishek97M/Handgun-Detection-Deepstream.git
2. Trained Weights
YoloV3 Weights: here
Download the Yolov3 weights file from the above link and move to this folder
YoloV3-tiny Weights: here
Download the Yolov3-tiny weights file from the above link and move to this folder
3. Compile
CUDA_VER=10.2 make -C nvdsinfer_custom_impl_Yolo
This is a one-time step and you need to do this only when you make source-code changes.
Understanding and editing deepstream_app_config
To understand and edit deepstream_app_config.txt file, read the DeepStream SDK Development Guide - Configuration Groups
- Edit source
Example for 1 source:
[source0]
enable=1
# 1=Camera (V4L2), 2=URI, 3=MultiURI, 4=RTSP, 5=Camera (CSI; Jetson only)
type=3
# Stream URL
uri=file:///home/user/Videos/input.mp4 or <rtsp url>
# Number of sources copy (if > 1, you need edit rows/columns in tiled-display section and batch-size in streammux section and config_infer_primary.txt; need type=3 for more than 1 source)
num-sources=1
gpu-id=0
cudadec-memtype=0
Example for 2 sources:
[source0]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
Example for Camera (CSI):
[source0]
enable = 1
type = 5
intra-decode-enable = 1
gpu-id = 0
camera-id = 0
camera-width = 960
camera-height = 616
camera-fps-n = 21
camera-fps-d = 1
camera-csi-sensor-id = 0
drop-frame-interval = 0
cudadec-memtype=0
Now, run the application for file/rtsp source by running the following command:
deepstream-app -c deepstream-gun-yoloV3.txt
Or you can run the same with tiny-yolov3 for faster inference:
deepstream-app -c deepstream-gun-yoloV3-tiny.txt
To run the application for Camera (CSI) by running the following command:
deepstream-app -c deepstream-guncsi-yoloV3.txt
Video demonstration of the App
Link to video demonstartion video_link
References
- Dataset 1 - weapon_detection_dataset | Kaggle
- Dataset 2 (Open Images) - GitHub - EscVM/OIDv4_ToolKit: Download and visualize single or multiple classes from the huge Open Images v4 dataset
- Darknet repository (training only) - GitHub - AlexeyAB/darknet: YOLOv4 / Scaled-YOLOv4 / YOLO - Neural Networks for Object Detection (Windows and Linux version of Darknet )
