HandleCapsules: resetting to activate new firmware
Hello,after we use apt-get update and apt-get install nvidia-jetpack then reboot the system we found the log as follows ,it seems different from Normal times ,it seems do some update.Does it matter?
log.txt (11.9 KB)
If the system is up and running, the print should be harmless. Please use Jetpack 6.0GA(r36.3) if you use previous release.
we use the latest version Jetpack 6.0GA(r36.3),after the log system is up and running
