Handling failures in RTSP streams
deepstream-app can continue to work even when one or several streams broken. The only case it stops working is that the client received “EOS” from server or error message from pipeline. In this case, application needs to finish the pipeline and re-start the pipeline. Application can decide what to do when there is error happens.
