• Hardware Platform = Jetson and dGPU
• DeepStream Version = 4.0.2
• TensorRT Version = 6
• NVIDIA GPU Driver Version = 440.82
I have a custom function within gst-nvinfer for some custom processing. At exactly the same frame/inference on a video (each video is different) the process either completely hangs when processing gst_buffer_pool_acquire_buffer()
The exact command is:
flow_ret = gst_buffer_pool_acquire_buffer(nvinfer->pool, &conv_gst_buf, nullptr);
or it segfaults after exiting my custom function.
if (nvinfer->process_full_frame) {
flow_ret = gst_nvinfer_process_full_frame(nvinfer, inbuf, in_surf);
} else {
//flow_ret = gst_nvinfer_process_objects(nvinfer, inbuf, in_surf);
flow_ret = gst_nvinfer_process_custom(nvinfer, inbuf, in_surf);
I don’t get any errors or any kind of feedback when getting stuck on gst_buffer_pool_acquire_buffer(). The processing just stops and nothing else happens.
When it exits the custom function I get a segfault but cannot see what the cause might be. My debugger tell me that it cannot access the memory address of the fault. I’m running the debug process as root, but I still get that error.
If I run the application with GST_DEBUG=3 (or even up to 6) I don’t get any additional relevant info. I’m assuming I’m seeing a deadlock of some kind or a null pointer somewhere, but I cannot figure out what might be causing it.
