Relevant to this previously asked question: USB flash interface
- What are the requirements when designing a custom carrier card to be able to flash the Jetson Xavier AGX?
- Is there any documentation which explains what hardware support is required to allow flashing?
- Does flashing use USB super speed lanes, or does it occur entirely over the USB 2.0 diff pair?
- Is flashing only supported over lane USB0, or are other channels supported as well?
With the dev kit, I have noticed that only USB-C port J512 has the ability to flash the device (ie, force_recovery mode, run lsusb on the host and see the “NVIDIA” line, then run ./flash.sh). USB-C port J513 does not show the “NVIDIA” line when running lsusb on the host, nor does ./flash.sh work. Same for the USB micro port–flashing can only be achieved over J512. Why is this?
