The TX1 reference desig on M.2 card “page 10_M.2 KEY E” connect is:
M2 CARD(pin num)------------->TX1 MODULE(pin num)
PERPO(35)------------------->|PEX1 TX_P(E41)
PERNO(37)------------------->|PEX1 TX_N(E42)
PETPO(41)------------------->|PEX1 RX_P(H41)
PETNO(43)------------------->|PEX1 RX_N(H42)
But in the M.2 specification PCIe (PCIe_M 2_Electromechanical_Spec_Rev0 7_11272012), PERx on the M.2 card should be connected to the receiving end of host, PETx signal should be connected to the transmitter host
Here is a quote:
IMPLENTATION NOTE: Lane Polarity
By default, the PETp0 and PETn0 pins (the transmitter differential pair of the connector) shall be
connected to the PCI Express transmitter differential pair on the system board and to the PCI
Express receiver differential pair on the PCI Express M.2 Card add-in card. Similarly by default,
the PERp0 and PERn0 pins (the receiver differential pair of the connector) shall be connected to
the PCI Express receiver differential pair on the system board and to the PCI Express transmitter
I think “system board” is the TX1 Module
