I’ve configured a realsense camera to generate a trigger signal once an image is captured. I want to route this trigger signal to a GPIO on the Nvida Xavier AGX, but I can’t find any examples of how this could be done?
In the end, I want to check the difference in timestamp between the computer clock and the camera clock.
BR
Robin
hello robin.andersson,
may I know what’s the use-case.
for example, here’s also one similar discussion thread, Topic 153404, to have use-case by using GPIO for frame synchronization.
BTW,
there’re several ways to access GPIOs. such as, kernel APIs, python scripts, C++ sample
you may also refer to discussion thread,Topic 144550 for reference.
thanks
Thanks for your reply and info!
I aiming to access the GPIO inside a python script, or in a c++ script. But in userspace.
I saw this Python package, and this is exactly what Im looking for: GitHub - NVIDIA/jetson-gpio: A Python library that enables the use of Jetson's GPIOs
Is this something you recommend? @JerryChang
BR
Robin
yes, you may access GPIOs with that python scripts.
