hardware problem/The TX2 original LAN LEDs are abnormal.
Two TX2 modules are installed the same OS, which are installed on the self-developed backplane and the TX2 kit backplane for verification. Original LAN LEDs status are different when press the power button. The module 1(SN:0421518036042): LEDs don’t flash on the two backplanes when press the power button , then enters into the os normally, and the network and LEDs are normal in the os. The module 2(SN:0422818043776) on the two backplanes , both LEDs will flash once when press the power button , then enters into the os normally, the network and LEDs are normal in the os . From the experimental point of view, there are differences between the two TX2 modules, why? Are the TX2 modules produced in different batches different?
Hi, can you please provide the P/N that contains the number of x3310-xxxx-xx?
699-83310-1000-B02 F
So they are same version hardware and same OS. Does the “don’t flash” LED flash when LAN is working?
