I want to use the onboard PWM chips on the Jetson Nano Developer Kit, but I haven’t been able to set them up. I tried using the jetson-io.py to configure the pins, but that does not seem to work, as “sudo cat /sys/kernel/debug/pinctrl/700008d4.pinmux/pinmux-pins | grep -i pe0” still says GPIO UNCLAIMED for pe0. Do I need to make a custom overlay in the boot file, or how do i actually enable the pwm chips on the Nano? I am using the developer kit version of the Jetson Nano
Related topics
| Jetson Nano PWM not working | 20 | 5384 | October 18, 2021 | |
| PWM pins and channels | 3 | 4129 | October 18, 2021 | |
| Nano PWM C++ | 24 | 5077 | October 13, 2021 | |
| How do I use PWM on Jetson Nano? | 12 | 31614 | August 25, 2021 | |
| How to use/configure PWM | 3 | 1366 | October 15, 2021 | |
| PWM Configuration For Jetson Nano | 2 | 926 | October 18, 2021 | |
| PWM on Jetson Nano : weird output | 6 | 1244 | October 14, 2021 | |
| Hardware PWM update with Jetson.GPIO | 13 | 5371 | October 18, 2021 | |
| GPIO07 doesnt work as PWM | 3 | 968 | October 15, 2021 | |
| PWM on Jetson Nano with Jetpack 4.3 | 6 | 766 | October 15, 2021 |
