Hardware RT queries in Python?
Hello everyone!
I am new to the Nvidia Developer ecosystem, and I am currently working on translating a ray-tracing based simulation built in Unity with compute shaders into Omniverse.
The basic gist of it is very simple ray-triangle intersection tests - now, I did some research but I was not able to figure out which of the APIs actually use the RTX cores, do I need to build a spatial data structure etc, so I wonder, is there any way for me to submit ray queries in Omniverse using Python for the RTX cores? And if yes, how and which API do I need to use?
I played around with omni.kit.raycast.query and omni.physx (which is CPU based if I am not mistaken?)
PS, I am building on top of the Editor app template, and a custom Extension as well.
Thank you in advance,
Danilo
Hi and thanks for posting. I am not sure I fully understand your questions. If you want to use Omniverse RTX, you can use it directly in a kit based app. You can either use a template like USD Composer or a custom based app. If you are looking to script directly with an RTX API, outside of a kit, that is something in development. Not available now.
But as for any RTX cores and queries, that is all built directly into the RTX renderer in kit. I would not try to “translate a ray-tracing based simulation” from Unity to Kit. I would simply load in your simulation file and use RTX directly.
sorry for the confusion. I am far from an expert in the field and I am still exploring my possibilities. But my intent was, to benefit from hardware acceleration for ray-tri tests on my geometry.
Here is a shot from my Unity app
Currently the rays are being generated and traced via custom compute shader code (CPU-side BVH, uploaded to the GPU, the rays are generated and traced in shader, basic Moller-Trumbore).
The geometry is “procedural” ie a polymesh loaded from a text file.
My main goal is to improve performance, and one of the methods I had imagined is going from compute to RT cores. Now I may have misunderstood this documentation piece:
But seeing as it mentions RTX Raycast Query, I thought it would allow me to submit work to the RT cores i.e. perform fixed-function ray-triangle tests.
Thank you for your patience and I hope this helps explain it further!
Could OptiX maybe help me in my case?
This is not a typical forum question, so I asked our internal AI, and this is what it is telling me.
The most robust path is to treat your Unity app as a prototype of the logic (ray generation, hit filtering, solar metrics) and then rebuild that logic as a Kit extension that uses OpenUSD geometry plus omni.kit.raycast.query for RTX-accelerated ray tests. You do not “convert” the Unity binary directly; instead you export your scene (panels, sun paths, etc.) to USD and then implement the same intersection pipeline in Python inside Omniverse Kit.omniverse.nvidia+2​youtube​
High-level workflow
  • Export your solar panel geometry and scene layout from Unity to USD via the Omniverse Unity Connector, keeping pivots, transforms, and materials consistent.youtube+1​
  • Create a new Kit-based app using the Kit App Template, which gives you a Python entry point and extension structure to load the USD stage and run your analysis.youtube​omniverse.nvidia​
  • Implement your ray generation and analysis as a Python extension that drives omni.kit.raycast.query over the USD stage while the RTX renderer is active.omniverse.nvidia+1​
Using omni.kit.raycast.query
omni.kit.raycast.query exposes an IRaycastQuery interface that runs ray–scene intersection on the current USD stage using the RTX renderer’s acceleration structures. The typical pattern is:omniverse.nvidia+1​
  • Acquire the interface: raycast = omni.kit.raycast.query.acquire_raycast_query_interface().developer.nvidia+1​
  • For one-off tests, call submit_raycast_query(ray, callback), where ray holds origin, direction, and max distance, and callback(ray, result) receives hit data (hit position, normal, distance, USD prim path).omniverse.nvidia+1​
  • For large batches (e.g., many rays over time or per panel), use add_raycast_sequence, repeatedly submit_ray_to_raycast_sequence, and get_latest_result_from_raycast_sequence to poll results efficiently.omniverse.nvidia+1​
This offloads all triangle traversal and BVH work to RTX hardware; result.hit_position, result.normal, and result.get_target_usd_path() replace your Unity ray-triangle tests.developer.nvidia+1​
Porting your Unity logic
To mirror your Unity app’s behavior in Kit:
  • Reproduce your ray setup (sun direction, panel sampling pattern) as pure math in Python using pxr.Gf vectors, independent of Unity’s API.scratchapixel+1​
  • Load the solar panel meshes as USD prims, either as a single mesh per panel or as instanced panels, and ensure they are on the active stage before casting rays.digitalmediaworld​youtube​
  • For each panel or sample point, build a Ray (origin, normalized direction, tMax) and submit it via IRaycastQuery, then post-process the hit results to compute irradiance, shading, or whatever metrics your Unity app currently calculates.omniverse.nvidia+1​
Practical tips and constraints
  • Omniverse raycast queries operate on the rendered scene, so your USD geometry, transforms, and visibility states must match what you want to test—no hidden collider-only meshes like in some game setups.omniverse.nvidia+1​
  • If you need physics-style queries (e.g., against collision shapes rather than render meshes), you can also look at PhysX scene queries (PxScene::raycast) integrated into Omniverse, but for solar-panel visibility and shading, omni.kit.raycast.query on RTX geometry is typically the right fit.nvidia-omniverse.github+1​
If you share how you currently generate rays in Unity (per-vertex, per-panel patch, sun path sampling), a concrete Kit-side code sketch for the ray generation and IRaycastQuery usage can be outlined in more detail.
  1. omni.kit.raycast.query — Omniverse Kit
  2. Overview — Omniverse Kit
  3. https://www.digitalmediaworld.tv/vfx/nvidia-opens-omniverse-rtx-based-3d-simulation-and-collaboration
  4. https://www.youtube.com/watch?v=-54P9v7kiW8
  5. https://www.youtube.com/watch?v=vgHa1JFwJbs
  6. https://www.youtube.com/watch?v=UPhgP6UKgvM
  7. The Omniverse Kit SDK — kit-app-template
  8. Are there any examples of the use of omni. kit. raycast. inquiry
  9. IRaycastQuery — Omniverse Kit
  10. Ray-Tracing: Rendering a Triangle
  11. RTX - Common — Omniverse Materials and Rendering
  12. Can we use a RayTraced renderer in Omniverse, and get direct access to rays like in OptiX?
  13. Geometry Queries — physx 5.2.1 documentation
  14. Scene Queries — physx 5.1.3 documentation
  15. https://docs.omniverse.nvidia.com/kit/docs/omni.kit.raycast.query
  16. IRaycastQuery — Omniverse Kit
  17. omni.kit.raycast.query Functions — Omniverse Kit
  18. https://www.youtube.com/watch?v=XgUhgSlQvic
  19. Ray-casting — Godot Engine (stable) documentation in English
  20. https://www.youtube.com/watch?v=8-sWQTdKK7U
  21. Extension Store
Hi Richard!
first off I’d like to apologize for the confusion introduced by my unfortunate word choice - “porting” is indeed what I meant, not “translation” :)
So it sounds like omni.kit.raycast.query is indeed what I am looking for.
Thank you!
You are welcome.
