Following this up:
I increased the 2500ms timeout to 30000ms and the errors still occur, even before 30 seconds has passed. Can you explain this behaviour? I would love to get this solved ASAP.
Full error message:
=== nodelet[17473]: CameraProvider initialized (0x7f88cb34a0)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
LSC: LSC surface is not based on full res!
X11 connection rejected because of wrong authentication.
(NvCapture) Error Timeout: capture waiting for status timeout (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture_hw_linux.c, function NvCaptureLinuxGetCaptureStatus(), line 362)
(NvCapture) Error Timeout: (propagating from /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureDequeue(), line 1055)
SCF: Error Timeout: (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 898)
SCF: Error InvalidState: Timeout waiting on frame end sensor guid 2, capture sequence ID = 1, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
SCF: Error InvalidState: Something went wrong with waiting on frame end (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 991)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 2, capture sequence ID = 1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
SCF: Error InvalidState: Something went wrong with waiting on frame start (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1077)
PowerServiceCore:handleRequests: timePassed = 1669
SCF: Error InvalidState: Timeout waiting on frame end sensor guid 2, capture sequence ID = 4, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 2, capture sequence ID = 4 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
PowerServiceCore:handleRequests: timePassed = 1678
SCF: Error InvalidState: Timeout waiting on frame end sensor guid 2, capture sequence ID = 6, channel = 1/1 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 905)
SCF: Error InvalidState: Timeout waiting on frame start sensor guid 2, capture sequence ID = 6 (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 1018)
SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 92)
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 997)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
