Has NVIDIA Aerial Testbed Validated VoNR Calls Between Two Commercial UEs Using the OAI IMS Container?
Background
We are currently using NVIDIA Aerial Testbed with the following setup:
  • NVIDIA Aerial CUDA-Accelerated RAN
  • OAI gNB (L2/L3) and OAI 5GC
  • WNC O-RU (n78)
  • Two commercial Android UEs connected to the 5G SA network
  • IMS container: oaisoftwarealliance/ims:latest
Both UEs can successfully connect to the 5G SA network and establish data sessions.
However, the OAI IMS Docker Hub documentation states:
“This IMS is not tested to communicate between two phones.”
Reference: oaisoftwarealliance/ims - Docker Image
Questions
  1. Has NVIDIA tested end-to-end VoNR voice calls between two commercial UEs using Aerial Testbed and the OAI IMS container?
  2. Does the current oaisoftwarealliance/ims:latest image support actual UE-to-UE VoNR calls, or is it primarily intended to satisfy IMS registration requirements?
  3. If two-UE VoNR calls have been validated, could NVIDIA share the tested configuration, including IMS settings, ims DNN, P-CSCF, QoS (5QI 5/1), and UE models?
  4. If this functionality is not currently supported or validated, is full VoNR calling planned for a future Aerial Testbed release?
Our goal is to enable native phone-to-phone VoNR calls between two Android devices over NVIDIA Aerial + OAI 5GC + WNC O-RU, without relying on third-party calling applications.
Thank you for your support!
We haven’t tested VoNR using Aerial.
From the L1 perspective, we have supported multi-slot transmission in UL, which is designed for VoNR. However, it’s a vendor-specific interface. For that reason, we wouldn’t say it is well-validated. At least, I believe OAI doesn’t support the interface.
Regarding the OAI functionalities, please directly ask the OAI team.
Thank you.
