Have problem getting started
I am new to this software and would like to use this on my AGV project.
When I try to follow the tutorials on the website some sections are unavailable (404 not found).
Currently, I am following the tutorial for the Omni graph. After I add the controllers it shows “prim path not valid”. Can you please help and take a look at where it is wrong?
Miles
Hi @c7ma - The documentation platform was going through upgradation. I don’t think there should be any 404 issues but if you do then please share and I can help resolve that.
Can you share at what step from the tutorial you are having issues?
Thanks for replying! I was browsing through other posts these days and found the updated links for the documentation. And after I tried another several times it finally worked. I think originally I made a mistake when specifying the token name.
CM
