I have some questions that I would like to get the answers for:
I am trying to write the bootloader into the GSPI flash and the OS into the NVM flash, is that what my flash command will do.
Does the SOM have GSPI internal flash?
If I flash the bootloader and the something fails in the write of the external flash will I see anything on the serial from the bootloader when I power up after flashing?
Do I need to format the external flash before I try and use my flash command to program the external flash?
I guess it should be “QSPI” but not “GSPI”. If so, then the answer is “yes”.
Yes, we also have method to flash QSPI only.
Yes, you wil.
Having an issue with my connection to the recovery port on my carrier board but when I run the initrd_flash command I end up reconnecting and running the bootloader/flashcmd.txt script. Is there something wrong with my flash command results? flashoutlog.txt (241.6 KB)
