Following is my kernel code.
global void doResample( variables… ){
int xx, yy;
xx = blockIdx.x;
yy = blockIdx.y;
if (dev_fft) {
if (xx<XDIM) {
if (yy<YDIM) {
if (dev_resample) {
h_in[yy].x = dev_b[dev_frame*YDIM*XDIM+xx*YDIM+int(dev_resamp[yy*2])]
- dev_resamp[yy*2+1]*(dev_b[dev_frame*YDIM*XDIM+xx*YDIM+int(dev_resamp[2*yy])+1]-dev_b[dev_frame*YDIM*XDIM+xx*YDIM+int(dev_resamp[2*yy])])/k_resampledspacing;
else {
h_in[yy].x = dev_b[dev_frame*YDIM*XDIM+xx*YDIM+yy];
h_in[yy].y = 0;
The code compiles and I have assigned values that does not exceed the length of array so there should be no problem with the code.
However, whenever I try to execute the code, it somehow shuts down or gives 0. Does anyone have I idea what is going on? Thank you.
