I am trying to setup a pipeline with the mipi camera and use CUDA code to do image processing. While I can get the camera to produce a color image, I can’t seem to get it to render a gray scale image. I am having problems with the conversion algorithm not being able to handle uint8 arrays.
I have tried several versions with no luck. I modified the basic camera render and added the colorconversion code as a final attempt. (My stand alone file input/output works fine).
Here is my example code:
#include <jetson-utils/videoSource.h>
#include <jetson-utils/videoOutput.h>
#include <jetson-utils/cudaColorspace.h>
#include <jetson-utils/cudaMappedMemory.h>
#include <jetson-utils/imageIO.h>
int main( int argc, char** argv )
// create input/output streams
videoSource* input = videoSource::Create(argc, argv, ARG_POSITION(0));
videoOutput* output = videoOutput::Create(argc, argv, ARG_POSITION(1));
if( !input )
return 0;
// capture/display loop
while( true )
uint8_t* imgOutput = NULL; // output is gray8 (uint8)
uint8_t* image = NULL; // can be uchar3, uchar4, float3, float4
int status = 0; // see videoSource::Status (OK, TIMEOUT, EOS, ERROR)
int width = 0;
int height = 0;
if( !input->Capture(&image, 1000, &status) ) // 1000ms timeout (default)
if( status == videoSource::TIMEOUT )
continue;
break; // EOS
width = input->GetWidth();
height = input->GetHeight();
// allocate the output as gray8 (uint8), with the same width/height
if( !cudaAllocMapped(&imgOutput, width, height,IMAGE_GRAY8) )
return false;
// convert from rgb8 to gray8
if( CUDA_FAILED(cudaConvertColor(image, IMAGE_RGB8, imgOutput, IMAGE_GRAY8, width, height)) )
return false; // an error or unsupported conversion occurred
if( output != NULL )
output->Render(imgOutput, input->GetWidth(), input->GetHeight(),IMAGE_GRAY8);
if( !output->IsStreaming() ) // check if the user quit
break;
// destroy resources
SAFE_DELETE(input);
SAFE_DELETE(output);
I keep getting an error in invalid image format type:
$ nvcc -o jetsoncamera jetsoncamera.cu -I/usr/local/include/jetson-utils -I/usr/local/cuda/include -L/usr/local/lib -ljetson-utils -lopencv_core -lopencv_highgui -lopencv_videoio -lopencv_imgproc -lopencv_imgcodecs -lcuda -lcudart
/usr/local/include/jetson-utils/imageFormat.inl(234): error: static assertion failed with “invalid image format type - supported types are uchar3, uchar4, float3, float4”
static_assert(__image_format_assert_false::value, “invalid image format type - supported types are uchar3, uchar4, float3, float4”);
detected during:
instantiation of “imageFormat imageFormatFromType() [with T=uint8_t]” at line 242 of /usr/local/include/jetson-utils/videoSource.h
instantiation of “__nv_bool videoSource::Capture(T **, uint64_t, int *, cudaStream_t) [with T=uint8_t]” at line 25 of jetsoncamera.cu
1 error detected in the compilation of “jetsoncamera.cu”.
But just confirm that you got stuck in the building step before testing, right?
If yes, could you share the building command/Makefile file with us as well?
Here is the error message I get when compiling:
$ make
/usr/local/cuda/bin/nvcc -O3 -I/usr/local/cuda/include -I/usr/local/include/jetson-utils jetsoncamera.cu -o jetsoncamera -L/usr/local/cuda/lib64 -lcudart -L/usr/local/include/jetson-utils/lib -ljetson-utils
detected during:
make: *** [Makefile:18: jetsoncamera] Error 1
