• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only)**6.0
• TensorRT Version 8.6.2
When I try to run this code with the sample_1080p_h264.mp4 file
import sys
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
def main(args):
# Initialize GStreamer
Gst.init(None)
# Create the pipeline
pipeline = Gst.Pipeline()
# Create common elements
streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
# Check if streammux and sink were created successfully
if not all([pipeline, streammux, sink]):
sys.stderr.write("Unable to create streammux or sink.\n")
return -1
# Set properties for streammux
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
streammux.set_property('batch-size', len(args) - 1)
streammux.set_property('batched-push-timeout', 4000000)
# Add streammux and sink to the pipeline
pipeline.add(streammux)
pipeline.add(sink)
# Create elements for each input video
for i, video_path in enumerate(args[1:]):
# Create elements
source = Gst.ElementFactory.make("filesrc", f"file-source-{i}")
demuxer = Gst.ElementFactory.make("qtdemux", f"demuxer-{i}")
parser = Gst.ElementFactory.make("h264parse", f"parser-{i}")
decoder = Gst.ElementFactory.make("nvv4l2decoder", f"nv-decoder-{i}")
# Add inference element
nvinfer = Gst.ElementFactory.make("nvinfer", f"nvinfer-{i}")
# Add OSD element
nvdsosd = Gst.ElementFactory.make("nvdsosd", "nv-osd")
# Check if all elements were created successfully
if not all([source, demuxer, parser, decoder, nvinfer, nvdsosd]):
sys.stderr.write(f"Unable to create elements for video {i}.\n")
return -1
# Set source property
source.set_property('location', video_path)
# Set properties for the inference element
nvinfer.set_property('config-file-path', 'model_config.txt') # Set your model config file path
# Add elements to the pipeline
pipeline.add(source)
pipeline.add(demuxer)
pipeline.add(parser)
pipeline.add(decoder)
pipeline.add(nvinfer)
pipeline.add(nvdsosd)
# Link elements
source.link(demuxer)
demuxer.connect("pad-added", on_pad_added, parser)
parser.link(decoder)
decoder.link(nvinfer)
nvinfer.link(nvdsosd)
# Link nvdsosd to streammux
sinkpad = streammux.get_request_pad(f"sink_{i}")
srcpad = nvdsosd.get_static_pad("src")
srcpad.link(sinkpad)
# Link streammux to sink
streammux.link(sink)
# Start playing
ret = pipeline.set_state(Gst.State.PLAYING)
if ret == Gst.StateChangeReturn.FAILURE:
sys.stderr.write("Unable to set the pipeline to the playing state.\n")
return -1
# Wait until error or EOS
bus = pipeline.get_bus()
msg = bus.timed_pop_filtered(
Gst.CLOCK_TIME_NONE,
Gst.MessageType.ERROR | Gst.MessageType.EOS
# Free resources
pipeline.set_state(Gst.State.NULL)
def on_pad_added(src, new_pad, data):
print(f"Received new pad {new_pad.get_name()} from {src.get_name()}")
if new_pad.get_current_caps().get_structure(0).get_name().startswith("video/"):
sink_pad = data.get_static_pad("sink")
if not sink_pad.is_linked():
new_pad.link(sink_pad)
if __name__ == '__main__':
if len(sys.argv) < 2:
sys.stderr.write("Usage: python3 script_name.py <video1> <video2> ...\n")
sys.exit(1)
sys.exit(main(sys.argv))
I get the following error
I am using he same model that deepstream-test1 uses.
Also, when I try to run deepstream-test1, I get this error.
I can run the videos and rtsp streams just fine using deepstream. This problem only happens when trying to run inferences on them.
