I am having issues using an imx185 camera on a spacely carrier board.
I’m using a tx2 that is flashed with the latest Jetpack and the BSP used is spacely-imx185-3cam.
The camera is connected through a FAW cable to csi0,1 and its DIP switch is set to master mode. The spacely’s S3 DIP switches are off.
The problem occurs when I use the example gstreamer pipeline from Connect Tech’s site:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),height=1080, width=1920, format=NV12, framerate=60/1" ! nvvidconv ! xvimagesink -ev &
This gives me the following error:
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp. function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp. function create(), line 44)
Error generated. /dvs/git/dirte/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:220 Failed to create FrameConsumer
I also took a look at dmesg and noticed the following lines:
imx185 35-001a: probing v4l2 sensor
imx185 35-001a: reset-gpios not found 0
tegra-vi4 15700000.vi: subdev imx185 30-001a bound
imx185 35-001a: tegra camera driver registration failed
Could anyone give guidance as to the next step?
