Hdf5 problem with docker tensorflow
I am currently trying to build a docker container which is able to run GPU accelerated tensorflow on top of a Xavier AGX.
My approach is derived from example and the official documentation jetson tensorflow.
My Dockerfile looks like this:
FROM nvcr.io/nvidia/l4t-base:r32.4.2
WORKDIR /
RUN apt update && apt install -y --fix-missing make g++
RUN apt update && apt install -y --fix-missing python3-pip libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev libjpeg8-dev liblapack-dev libblas-dev gfortran python3-h5py
RUN pip3 install -U pip testresources setuptools cython numpy==1.16.1 future==0.17.1 mock==3.0.5 h5py==2.9.0 keras_preprocessing==1.0.5 keras_applications==1.0.8 gast==0.2.2 pybind11
RUN pip3 install --pre --no-cache-dir --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow
COPY requirements.txt .
RUN pip3 install -r requirements.txt
COPY . .
CMD ["python3", "-u", "app.py"]
However, I am getting the following error, related to the hdf5-lib:
 In file included from /tmp/pip-build-cdi1gcqf/h5py/h5py/defs.c:654:0:
    /tmp/pip-build-cdi1gcqf/h5py/h5py/api_compat.h:27:10: fatal error: hdf5.h: No such file or directory
     #include "hdf5.h"
The JetPack version of the Xavier is 4.4 and the l4t version is 32.4.2.
Any help would be highly appreciated!
Best regards
Dominik
The solution was to add:
HDF5_DIR=/usr/lib/x86_64-linux-gnu/hdf5/serial/
to the
RUN HDF5_DIR=/usr/lib/x86_64-linux-gnu/hdf5/serial/ pip3 install -U pip testresources setuptools cython numpy==1.16.1 future==0.17.1 mock==3.0.5 h5py==2.10.0 keras_preprocessing==1.0.5 keras_applications==1.0.8 gast==0.2.2 pybind11
and to change:
h5py==2.9.0 to h5py==2.10.0
The following Dockerfile works now:
WORKDIR /
COPY . .
