sure … below is the full dmesg. The kernel messages in original post were dmesg | grep tegradc.
Please note at time 183 I enabled HDMI via gst pipeline nvdrmvidosink set-mode=1.
But our current pipeline ends with nvdrmvideosink sync=false offset-x=X offset-y=0 plane-id=0 conn-id=0 set-mode=0, which does not enable hdmi.
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11) ) #1 SMP PREEMPT Wed Apr 1 20:17:44 UTC 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 85600000
[ 0.000000] OF: fdt: - 175e00000 , 200000
[ 0.000000] OF: fdt: - 176600000 , 200000
[ 0.000000] OF: fdt: - 177000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1006592
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 7624 pages used for memmap
[ 0.000000] Normal zone: 482816 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffffffc0f7140000 s61144 r8192 d28968 u98304
[ 0.000000] pcpu-alloc: s61144 r8192 d28968 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 990776
[ 0.000000] Kernel command line: console=ttyS0,115200 console=tty0 OS=l4t fbcon=map:0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p33 rw rootwait console=ttyS0,115200 console=tty0 OS=l4t fbcon=map:0 rootfstype=ext4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29472(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3855484K/4026368K available (12798K kernel code, 2752K rwdata, 5908K rodata, 7616K init, 584K bss, 105348K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008d00000 ( 12800 KB)
[ 0.000000] .rodata : 0xffffff8008d00000 - 0xffffff80092d0000 ( 5952 KB)
[ 0.000000] .init : 0xffffff80092d0000 - 0xffffff8009a40000 ( 7616 KB)
[ 0.000000] .data : 0xffffff8009a40000 - 0xffffff8009cf0008 ( 2753 KB)
[ 0.000000] .bss : 0xffffff8009cf0008 - 0xffffff8009d8214c ( 585 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03dc8000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0f7200000 ( 3954 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.010099] Console: colour dummy device 80x25
[ 0.014750] console [tty0] enabled
[ 0.018295] bootconsole [uart8250] disabled
[ 0.022655] kmemleak: Kernel memory leak detector disabled
[ 0.022671] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022684] pid_max: default: 32768 minimum: 301
[ 0.022832] Security Framework initialized
[ 0.022902] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.022912] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023384] ftrace: allocating 40799 entries in 160 pages
[ 0.087043] sched-energy: Sched-energy-costs installed from DT
[ 0.087064] ASID allocator initialised with 65536 entries
[ 0.127326] tegra-id: chipid=21817.
[ 0.127342] tegra-id: opt_subrevision=1.
[ 0.127363] Tegra Revision: A02p SKU: 0x94 CPU Process: 0 SoC Process: 0
[ 0.127377] DTS File Name: /builds/ULTRON/ultron-os/build/tmp/work-shared/ultron12/kernel-source/arch/arm64/boot/dts/../../../../nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
[ 0.127395] DTB Build time: <unknown>
[ 0.174154] CPU1: Booted secondary processor [4e0f0030]
[ 0.205765] CPU2: Booted secondary processor [4e0f0030]
[ 0.237570] CPU3: Booted secondary processor [411fd073]
[ 0.269547] CPU4: Booted secondary processor [411fd073]
[ 0.301534] CPU5: Booted secondary processor [411fd073]
[ 0.301587] Brought up 6 CPUs
[ 0.301628] SMP: Total of 6 processors activated.
[ 0.301640] CPU features: detected feature: 32-bit EL0 Support
[ 0.302385] CPU: All CPU(s) started at EL2
[ 0.302439] alternatives: patching kernel code
[ 0.303957] devtmpfs: initialized
[ 0.355434] Initilizing CustomIPI irq domain
[ 0.355634] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.355660] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.356472] pinctrl core: initialized pinctrl subsystem
[ 0.356697] OS set in device tree is not L4T.
[ 0.356869] regulator-dummy: no parameters
[ 0.357027] Initializing plugin-manager
[ 0.357093] Plugin module not found
[ 0.357166] Plugin-manager status disabled
[ 0.359358] NET: Registered protocol family 16
[ 0.359986] pstore: using zlib compression
[ 0.360378] console [pstore-1] enabled
[ 0.360390] pstore: Registered ramoops as persistent store backend
[ 0.360403] ramoops: attached 0x200000@0x175880000, ecc: 0/0
[ 0.377141] cpuidle: using governor menu
[ 0.379685] bpmp: waiting for handshake
[ 0.379705] bpmp: handshake completed
[ 0.379728] bpmp: synchronizing channels
[ 0.379747] bpmp: channels synchronized
[ 0.379759] bpmp: mail init ok
[ 0.382894] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.382916] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.382930] arm-smmu 12000000.iommu: stage 1 translation
[ 0.382943] arm-smmu 12000000.iommu: stage 2 translation
[ 0.382955] arm-smmu 12000000.iommu: nested translation
[ 0.382970] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.382989] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.383008] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.383022] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.383036] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.385065] vdso: 2 pages (1 code @ ffffff8008d07000, 1 data @ ffffff8009a44000)
[ 0.385096] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.388128] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.390728] Registering BPMP clocks...
[ 0.390839] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.393818] tegra_powergate_init: DONE
[ 0.393841] DTS File Name: /builds/ULTRON/ultron-os/build/tmp/work-shared/ultron12/kernel-source/arch/arm64/boot/dts/../../../../nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
[ 0.393869] DTB Build time: <unknown>
[ 0.397214] Tegra reboot handler registered.
[ 0.398954] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.399041] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.399064] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.399076] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.399088] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.399255] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.399283] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.399672] iommu: Adding device 3460000.sdhci to group 0
[ 0.400189] iommu: Adding device 3440000.sdhci to group 1
[ 0.400693] iommu: Adding device 3400000.sdhci to group 2
[ 0.401873] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.401903] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.402405] iommu: Adding device 3160000.i2c to group 4
[ 0.402907] iommu: Adding device c240000.i2c to group 5
[ 0.403325] iommu: Adding device 3180000.i2c to group 6
[ 0.403722] iommu: Adding device 3190000.i2c to group 7
[ 0.404198] iommu: Adding device 31b0000.i2c to group 8
[ 0.404593] iommu: Adding device 31c0000.i2c to group 9
[ 0.404992] iommu: Adding device c250000.i2c to group 10
[ 0.405415] iommu: Adding device 31e0000.i2c to group 11
[ 0.407019] iommu: Adding device 3210000.spi to group 12
[ 0.407428] iommu: Adding device c260000.spi to group 13
[ 0.407820] iommu: Adding device 3240000.spi to group 14
[ 0.408562] iommu: Adding device 3100000.serial to group 15
[ 0.408958] iommu: Adding device 3110000.serial to group 16
[ 0.409381] iommu: Adding device c280000.serial to group 17
[ 0.409771] iommu: Adding device 3130000.serial to group 18
[ 0.411328] iommu: Adding device 2490000.ether_qos to group 19
[ 0.411352] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.412102] iommu: Adding device b000000.rtcpu to group 20
[ 0.414780] iommu: Adding device 13e10000.host1x to group 21
[ 0.415133] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.415496] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.415841] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.416185] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.416526] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.416876] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.417257] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.417609] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.418154] iommu: Adding device 150c0000.nvcsi to group 30
[ 0.418875] iommu: Adding device 15700000.vi to group 31
[ 0.419281] iommu: Adding device 15600000.isp to group 32
[ 0.419792] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.420508] iommu: Adding device 15220000.nvdisplay to group 34
[ 0.421237] iommu: Adding device 15340000.vic to group 35
[ 0.421506] iommu: Adding device 154c0000.nvenc to group 36
[ 0.421761] iommu: Adding device 15480000.nvdec to group 37
[ 0.422163] iommu: Adding device 15380000.nvjpg to group 38
[ 0.422417] iommu: Adding device 15500000.tsec to group 39
[ 0.422669] iommu: Adding device 15100000.tsecb to group 40
[ 0.423768] iommu: Adding device 15810000.se to group 41
[ 0.424031] iommu: Adding device 15820000.se to group 42
[ 0.424292] iommu: Adding device 15830000.se to group 43
[ 0.424537] iommu: Adding device 15840000.se to group 44
[ 0.425558] iommu: Adding device smmu_test to group 45
[ 0.426294] mc: mapped MMIO address: 0xffffff800a280000 -> 0x2c10000
[ 0.426321] mc: mapped MMIO address: 0xffffff800a2a0000 -> 0x2c20000
[ 0.426343] mc: mapped MMIO address: 0xffffff800a2c0000 -> 0x2c30000
[ 0.426364] mc: mapped MMIO address: 0xffffff800a2e0000 -> 0x2c40000
[ 0.426385] mc: mapped MMIO address: 0xffffff800a4b0000 -> 0x2c50000
[ 0.426403] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.426423] mc-err: mcerr ops are set to t18x
[ 0.426583] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.427807] iommu: Adding device 3530000.xhci to group 46
[ 0.427834] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.428355] iommu: Adding device 3550000.xudc to group 47
[ 0.428378] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.429147] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.429167] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.429827] iommu: Adding device 17000000.gp10b to group 48
[ 0.432342] tegra-reset 5000000.clock: registered 193 resets.
[ 0.436641] iommu: Adding device d000000.bpmp to group 49
[ 0.437081] bpmp: ping status is 0
[ 0.437286] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.442424] bpmp d000000.bpmp: probe ok
[ 0.447532] iommu: Adding device 2600000.dma to group 50
[ 0.449316] GPIO line 459 (pcie0_lane2_mux) hogged as output/low
[ 0.449382] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.449441] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.449524] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.449594] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.449671] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.449728] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.450135] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.457508] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.460393] iommu: Adding device 10003000.pcie-controller to group 51
[ 0.460475] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.461055] iommu: Adding device sound to group 52
[ 0.461635] iommu: Adding device 3510000.hda to group 53
[ 0.461784] random: fast init done
[ 0.474507] iommu: Adding device c1a0000.aon to group 54
[ 0.475273] vdd-ac-bat: 5000 mV
[ 0.477747] vdd-1v8-ap: 1800 mV
[ 0.490318] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.494910] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.495306] SCSI subsystem initialized
[ 0.495400] libata version 3.00 loaded.
[ 0.495621] usbcore: registered new interface driver usbfs
[ 0.495697] usbcore: registered new interface driver hub
[ 0.495834] usbcore: registered new device driver usb
[ 0.498845] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.498952] pca953x 0-0074: failed reading register
[ 0.499058] pca953x: probe of 0-0074 failed with error -121
[ 0.499430] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.499537] pca953x 0-0077: failed reading register
[ 0.499631] pca953x: probe of 0-0077 failed with error -121
[ 0.515079] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.522006] vddio-ddr: at 1125 mV
[ 0.525797] avdd_dsi_csi: 1200 mV
[ 0.529799] vdd-1v8: 1800 mV
[ 0.533800] vdd-3v3-sys: 3300 mV
[ 0.534547] max77620-sd4: at 600 mV
[ 0.535731] spmic-ldo0: at 1800 mV
[ 0.536628] spmic-ldo1: at 800 mV
[ 0.541798] vddio-3v3: 3300 mV
[ 0.542692] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.545840] vdd-rtc: at 800 mV
[ 0.546847] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.549802] spmic-ldo6: at 1500 mV
[ 0.553837] vdd-pex-1v00: 1000 mV
[ 0.554673] dvdd-pex: 1000 mV
[ 0.555340] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.555549] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.555855] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.558346] max77620 4-003c: max77620 probe successful
[ 0.558903] media: Linux media interface: v0.10
[ 0.558983] Linux video capture interface: v2.00
[ 0.563445] pps_core: LinuxPPS API ver. 1 registered
[ 0.563496] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.563574] PTP clock support registered
[ 0.564301] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.564374] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.570770] tegra_fiq_debugger_init: found FIQ source (IRQ 388)
[ 0.577216] trusty trusty: trusty version: Built: 22:43:54 Dec 9 2019
[ 0.577303] trusty trusty: selected api version: 3 (requested 3)
[ 0.578587] Advanced Linux Sound Architecture Driver Initialized.
[ 0.579998] en-vdd-sd: 3300 mV
[ 0.580545] vdd-usb0-5v: 5000 mV
[ 0.580983] vdd-usb1-5v: 5000 mV
[ 0.581620] vdd-3v3: 3300 mV
[ 0.582015] en-vdd-vcm-2v8: 2800 mV
[ 0.582418] vdd-sys-bl: 3300 mV
[ 0.586481] camchar: rtcpu character device driver loaded
[ 0.587206] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.588945] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.589625] clocksource: Switched to clocksource arch_sys_counter
[ 0.633096] VFS: Disk quotas dquot_6.6.0
[ 0.633254] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.633585] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.634177] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.634198] nvmap_page_pool_init: Total RAM pages: 980255
[ 0.634212] nvmap_page_pool_init: nvmap page pool size: 122531 pages (478 MB)
[ 0.634285] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.638436] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.650379] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.650657] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.651212] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.651347] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.651519] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.651694] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.651937] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.652229] la/ptsa driver initialized.
[ 0.652275] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.652312] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[ 0.652787] NET: Registered protocol family 2
[ 0.653845] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.654246] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.654638] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.654717] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.654809] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.655255] NET: Registered protocol family 1
[ 0.655321] PCI: CLS 0 bytes, default 64
[ 0.655505] Trying to unpack rootfs image as initramfs...
[ 0.678293] host1x 13e10000.host1x: initialized
[ 0.680215] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.684318] audit: initializing netlink subsys (disabled)
[ 0.684449] audit: type=2000 audit(0.624:1): initialized
[ 0.685226] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.694400] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.695124] SGI XFS with security attributes, no debug enabled
[ 0.703183] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.703391] io scheduler noop registered
[ 0.703446] io scheduler deadline registered (default)
[ 0.703732] io scheduler cfq registered
[ 0.708025] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.714902] iommu: Adding device aconnect@2a41000:adsp_audio to group 55
[ 0.736159] iommu: Adding device 2993000.adsp to group 56
[ 0.737406] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.740470] tegra-xusb-padctl 3520000.xusb_padctl: Invalid OC pin: 2
[ 0.741045] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.745939] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.747706] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.749161] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.750679] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.753694] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[ 0.754972] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.755447] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 0.755763] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.756005] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.756083] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=371250, vi_iso_bw=4500000, max_bw=4500000
[ 0.760392] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 0.762105] tsec 15500000.tsec: initialized
[ 0.763266] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.763739] tsec 15100000.tsecb: initialized
[ 0.769781] nvdec 15480000.nvdec: initialized
[ 0.780145] falcon 15340000.vic: initialized
[ 0.782205] falcon 154c0000.nvenc: initialized
[ 0.783934] falcon 15380000.nvjpg: initialized
[ 0.787649] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.789362] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.791116] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.792800] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.794458] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.796099] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.797752] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.799317] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.803899] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.803975] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.804033] tegradccommon 15200000.dc_common: dma mapping done
[ 0.806257] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.806440] generic_infoframe_type: 0x87
[ 0.806557] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.806604] tegradc 15210000.nvdisplay: Display dc.ffffff800a7e0000 registered with id=0
[ 0.816926] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.817843] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.820411] kfuse 3830000.kfuse: initialized
[ 0.820499] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.820542] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.820600] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.820996] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.821030] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.822569] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 0.822629] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.829033] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.832205] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.832264] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.834483] console [ttyS0] disabled
[ 0.834613] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 0.838571] tegradc 15210000.nvdisplay: probed
[ 1.213341] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 1.620632] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.027305] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.029362] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 2.141617] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.141676] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.141683] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.141689] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.141696] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.141743] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[ 2.141882] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.142135] iommu: Adding device 0000:00:01.0 to group 57
[ 2.142148] arm-smmu: forcing sodev map for 0000:00:01.0
[ 2.142383] pci 0000:00:02.0: [10de:10e6] type 01 class 0x060400
[ 2.142503] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.142717] iommu: Adding device 0000:00:02.0 to group 58
[ 2.142723] arm-smmu: forcing sodev map for 0000:00:02.0
[ 2.142878] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.142896] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.143143] pci 0000:01:00.0: [14e4:1657] type 00 class 0x020000
[ 2.143406] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.143475] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.143517] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.143543] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x000007ff pref]
[ 2.143838] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.144094] iommu: Adding device 0000:01:00.0 to group 59
[ 2.144100] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.144294] pci 0000:01:00.1: [14e4:1657] type 00 class 0x020000
[ 2.144358] pci 0000:01:00.1: reg 0x10: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.144405] pci 0000:01:00.1: reg 0x18: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.144446] pci 0000:01:00.1: reg 0x20: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.144495] pci 0000:01:00.1: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 2.144779] pci 0000:01:00.1: PME# supported from D0 D3hot D3cold
[ 2.145029] iommu: Adding device 0000:01:00.1 to group 60
[ 2.145035] arm-smmu: forcing sodev map for 0000:01:00.1
[ 2.145209] pci 0000:01:00.2: [14e4:1657] type 00 class 0x020000
[ 2.145273] pci 0000:01:00.2: reg 0x10: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.145314] pci 0000:01:00.2: reg 0x18: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.145355] pci 0000:01:00.2: reg 0x20: [mem 0x00000000-0x0000ffff 64bit pref]
[ 2.145380] pci 0000:01:00.2: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 2.145895] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[ 2.146152] iommu: Adding device 0000:01:00.2 to group 61
[ 2.146158] arm-smmu: forcing sodev map for 0000:01:00.2
[ 2.153819] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.154094] pci 0000:02:00.0: [1b4b:9215] type 00 class 0x010601
[ 2.154154] pci 0000:02:00.0: reg 0x10: [io 0x8000-0x8007]
[ 2.154187] pci 0000:02:00.0: reg 0x14: [io 0x8040-0x8043]
[ 2.154218] pci 0000:02:00.0: reg 0x18: [io 0x8100-0x8107]
[ 2.154249] pci 0000:02:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 2.154281] pci 0000:02:00.0: reg 0x20: [io 0x800000-0x80001f]
[ 2.154313] pci 0000:02:00.0: reg 0x24: [mem 0x00900000-0x009007ff]
[ 2.154345] pci 0000:02:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 2.154521] pci 0000:02:00.0: PME# supported from D3hot
[ 2.154772] iommu: Adding device 0000:02:00.0 to group 62
[ 2.154779] arm-smmu: forcing sodev map for 0000:02:00.0
[ 2.165720] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 2.165850] pci 0000:00:01.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[ 2.165860] pci 0000:00:01.0: BAR 15: assigned [mem 0x48000000-0x480fffff 64bit pref]
[ 2.165867] pci 0000:00:02.0: BAR 14: assigned [mem 0x40200000-0x402fffff]
[ 2.165872] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.165893] pci 0000:01:00.1: BAR 6: assigned [mem 0x40100000-0x4013ffff pref]
[ 2.165899] pci 0000:01:00.2: BAR 6: assigned [mem 0x40140000-0x4017ffff pref]
[ 2.165907] pci 0000:01:00.0: BAR 0: assigned [mem 0x48000000-0x4800ffff 64bit pref]
[ 2.165943] pci 0000:01:00.0: BAR 2: assigned [mem 0x48010000-0x4801ffff 64bit pref]
[ 2.165978] pci 0000:01:00.0: BAR 4: assigned [mem 0x48020000-0x4802ffff 64bit pref]
[ 2.166013] pci 0000:01:00.1: BAR 0: assigned [mem 0x48030000-0x4803ffff 64bit pref]
[ 2.166048] pci 0000:01:00.1: BAR 2: assigned [mem 0x48040000-0x4804ffff 64bit pref]
[ 2.166083] pci 0000:01:00.1: BAR 4: assigned [mem 0x48050000-0x4805ffff 64bit pref]
[ 2.166117] pci 0000:01:00.2: BAR 0: assigned [mem 0x48060000-0x4806ffff 64bit pref]
[ 2.166153] pci 0000:01:00.2: BAR 2: assigned [mem 0x48070000-0x4807ffff 64bit pref]
[ 2.166187] pci 0000:01:00.2: BAR 4: assigned [mem 0x48080000-0x4808ffff 64bit pref]
[ 2.166221] pci 0000:01:00.0: BAR 6: assigned [mem 0x40180000-0x401807ff pref]
[ 2.166235] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.166246] pci 0000:00:01.0: bridge window [mem 0x40100000-0x401fffff]
[ 2.166254] pci 0000:00:01.0: bridge window [mem 0x48000000-0x480fffff 64bit pref]
[ 2.166269] pci 0000:02:00.0: BAR 6: assigned [mem 0x40200000-0x4020ffff pref]
[ 2.166275] pci 0000:02:00.0: BAR 5: assigned [mem 0x40210000-0x402107ff]
[ 2.166288] pci 0000:02:00.0: BAR 4: assigned [io 0x1000-0x101f]
[ 2.166301] pci 0000:02:00.0: BAR 0: assigned [io 0x1020-0x1027]
[ 2.166314] pci 0000:02:00.0: BAR 2: assigned [io 0x1028-0x102f]
[ 2.166327] pci 0000:02:00.0: BAR 1: assigned [io 0x1030-0x1033]
[ 2.166340] pci 0000:02:00.0: BAR 3: assigned [io 0x1034-0x1037]
[ 2.166354] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 2.166360] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.166370] pci 0000:00:02.0: bridge window [mem 0x40200000-0x402fffff]
[ 2.166773] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.166778] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.166782] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 2.166785] pci 0000:01:00.2: Signaling PME through PCIe PME interrupt
[ 2.166795] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 2.166897] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 2.167131] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.167136] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 2.167144] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.167225] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.417890] console [ttyS0] enabled
[ 3.417896] tegradc 15210000.nvdisplay: fb registered
[ 3.418271] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.418850] tegradc 15220000.nvdisplay: disp1 connected to head2->/host1x/sor
[ 3.418910] generic_infoframe_type: 0x87
[ 3.419005] tegradc 15220000.nvdisplay: DT parsed successfully
[ 3.419045] tegradc 15220000.nvdisplay: Display dc.ffffff800b090000 registered with id=1
[ 3.419464] tegradc 15220000.nvdisplay: vblank syncpt # 11 for dc 2
[ 3.419472] tegradc 15220000.nvdisplay: vpulse3 syncpt # 12 for dc 2
[ 3.420402] tegradc 15220000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 3.426539] tegradc 15220000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 3.427080] tegradc 15220000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 3.431803] tegradc 15220000.nvdisplay: probed
[ 3.498703] tegradc 15220000.nvdisplay: fb registered
[ 3.504282] gpio tegra-gpio wake19 for gpio=120(P:0)
[ 3.506045] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.519551] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.528677] serial-tegra 3130000.serial: RX in PIO mode
[ 3.535175] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.545289] [drm] Initialized
[ 3.557133] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 3.560654] brd: module loaded
[ 3.567611] Extcon HDMI: HPD enabled
[ 3.571273] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.578306] loop: module loaded
[ 3.581507] tegra_profiler: version: 1.134, samples/io: 47/26
[ 3.587502] tegra_profiler: auth: init
[ 3.592094] nct1008_nct72 7-004c: starting parse dt
[ 3.592390] THERMAL EST: found 3 subdevs
[ 3.592395] THERMAL EST num_resources: 0
[ 3.592400] [THERMAL EST subdev 0]
[ 3.592407] [THERMAL EST subdev 1]
[ 3.592411] [THERMAL EST subdev 2]
[ 3.592755] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.592758] THERMAL EST: thz register success.
[ 3.597008] THERMAL EST: end of probe, return err: 0
[ 3.605999] libphy: Fixed MDIO Bus: probed
[ 3.606368] tun: Universal TUN/TAP device driver, 1.6
[ 3.606369] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.606783] VFIO - User Level meta-driver version: 0.3
[ 3.610109] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.610123] ehci-pci: EHCI PCI platform driver
[ 3.610158] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.610176] ohci-pci: OHCI PCI platform driver
[ 3.610207] ohci-platform: OHCI generic platform driver
[ 3.610803] usbcore: registered new interface driver usb-storage
[ 3.688187] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 3.694314] nct1008_nct72 7-004c: success parsing dt
[ 3.699509] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.738315] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 3.744026] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.744251] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 3.758188] Wake73 for irq=42
[ 3.762507] rtc rtc1: alarm rtc device
[ 3.766344] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.773362] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.777195] nct1008_nct72 7-004c: initial LOC temp: 42000
[ 3.777574] nct1008_nct72 7-004c: initial EXT temp: 53750
[ 3.778269] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 3.778665] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.778886] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.806473] i2c /dev entries driver
[ 3.812215] tp2854 0-0001: probing fake v4l2 sensor.
[ 3.818153] tp2854 0-0001: tegracam sensor driver:tp2854_v2.0.6
[ 3.830748] tp2854 0-0001: Detected TP2854 sensor
[ 3.835567] tp2854 0-0002: probing fake v4l2 sensor.
[ 3.841371] tp2854 0-0002: couldn't create debugfs
[ 3.846204] tp2854 0-0002: tegracam sensor driver:tp2854_v2.0.6
[ 3.858781] tp2854 0-0002: Detected TP2854 sensor
[ 3.863661] tp2854 0-0003: probing fake v4l2 sensor.
[ 3.869739] tp2854 0-0003: couldn't create debugfs
[ 3.874577] tp2854 0-0003: tegracam sensor driver:tp2854_v2.0.6
[ 3.887497] tp2854 0-0003: Detected TP2854 sensor
[ 3.892345] tp2854 0-0004: probing fake v4l2 sensor.
[ 3.898508] tp2854 0-0004: couldn't create debugfs
[ 3.903340] tp2854 0-0004: tegracam sensor driver:tp2854_v2.0.6
[ 3.916052] tp2854 0-0004: Detected TP2854 sensor
[ 3.920877] tp2854 0-0005: probing fake v4l2 sensor.
[ 3.926692] tp2854 0-0005: couldn't create debugfs
[ 3.931521] tp2854 0-0005: tegracam sensor driver:tp2854_v2.0.6
[ 3.944013] tp2854 0-0005: Detected TP2854 sensor
[ 3.948838] tp2854 0-0006: probing fake v4l2 sensor.
[ 3.954621] tp2854 0-0006: couldn't create debugfs
[ 3.959451] tp2854 0-0006: tegracam sensor driver:tp2854_v2.0.6
[ 3.971873] tp2854 0-0006: Detected TP2854 sensor
[ 3.976692] tp2854 0-0007: probing fake v4l2 sensor.
[ 3.982430] tp2854 0-0007: couldn't create debugfs
[ 3.987260] tp2854 0-0007: tegracam sensor driver:tp2854_v2.0.6
[ 3.999692] tp2854 0-0007: Detected TP2854 sensor
[ 4.004522] tp2854 0-0008: probing fake v4l2 sensor.
[ 4.010277] tp2854 0-0008: couldn't create debugfs
[ 4.015104] tp2854 0-0008: tegracam sensor driver:tp2854_v2.0.6
[ 4.027521] tp2854 0-0008: Detected TP2854 sensor
[ 4.032360] tp2854 2-0009: probing fake v4l2 sensor.
[ 4.038098] tp2854 2-0009: couldn't create debugfs
[ 4.042926] tp2854 2-0009: tegracam sensor driver:tp2854_v2.0.6
[ 4.055326] tp2854 2-0009: Detected TP2854 sensor
[ 4.060145] tp2854 2-0010: probing fake v4l2 sensor.
[ 4.065899] tp2854 2-0010: couldn't create debugfs
[ 4.070723] tp2854 2-0010: tegracam sensor driver:tp2854_v2.0.6
[ 4.083117] tp2854 2-0010: Detected TP2854 sensor
[ 4.087934] tp2854 2-0011: probing fake v4l2 sensor.
[ 4.093682] tp2854 2-0011: couldn't create debugfs
[ 4.098508] tp2854 2-0011: tegracam sensor driver:tp2854_v2.0.6
[ 4.110904] tp2854 2-0011: Detected TP2854 sensor
[ 4.115724] tp2854 2-0012: probing fake v4l2 sensor.
[ 4.121477] tp2854 2-0012: couldn't create debugfs
[ 4.126309] tp2854 2-0012: tegracam sensor driver:tp2854_v2.0.6
[ 4.138712] tp2854 2-0012: Detected TP2854 sensor
[ 4.144269] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.158193] FAN: coudln't get the regulator
[ 4.168243] cpufreq: platform driver Initialization: pass
[ 4.174243] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.181112] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.188404] sdhci: Secure Digital Host Controller Interface driver
[ 4.194615] sdhci: Copyright(c) Pierre Ossman
[ 4.198988] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.206464] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.215656] CMDQ: cmdq_platfm_init successful
[ 4.221177] CQE: CMD_TIMING bit set for R1B DCMD
[ 4.221480] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 4.225923] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.225972] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 4.227865] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.229745] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 259
[ 4.234843] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.235915] tegra-se-nvhost 15810000.se: initialized
[ 4.237020] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.237950] tegra-se-nvhost 15820000.se: initialized
[ 4.238867] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.239497] tegra-se-nvhost 15830000.se: initialized
[ 4.240251] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.240840] tegra-se-nvhost 15840000.se: initialized
[ 4.241713] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.241962] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.253094] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 4.253123] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 4.253236] ina3221x: probe of 0-0042 failed with error -121
[ 4.253492] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 4.253518] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 4.253615] ina3221x: probe of 0-0043 failed with error -121
[ 4.256592] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.258769] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.259014] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.259155] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.259335] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.260266] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.260329] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.260376] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.260421] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.260538] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.260850] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 4.260852] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.261353] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.263168] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.263660] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.263821] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.263890] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.264391] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264393] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.264395] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.264461] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264463] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.264464] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.264516] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264517] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.264519] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.264571] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264573] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.264574] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.264624] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264625] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.264627] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.264678] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264682] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.264683] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.264742] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264746] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.264747] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.264801] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264804] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.264806] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.264856] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264860] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.264862] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.264911] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264913] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 4.264914] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.264964] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.264969] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 4.264970] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.265024] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.265029] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 4.265030] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.265080] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.265084] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 4.265086] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.265136] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.265141] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 4.265142] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.265194] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.265198] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 4.265199] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.265255] **** A57 ECC: Enabled
[ 4.265257] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 4.265320] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 4.265715] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.265809] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.266317] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.266449] denver_knobs_init:MTS_VERSION:47926945
[ 4.269952] nvpmodel: initialized successfully
[ 4.274500] trusty-virtio trusty:virtio: initializing
[ 4.274610] trusty_ipc virtio0: vring0: va(pa) ffffffc0ec874000(0) qsz 32 notifyid 1
[ 4.274616] trusty_ipc virtio0: vring1: va(pa) ffffffc0ec876000(0) qsz 32 notifyid 2
[ 4.274682] trusty-virtio trusty:virtio: initializing done
[ 4.274834] trusty_ipc virtio0: is online
[ 4.277757] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 4.277810] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.277922] usbcore: registered new interface driver snd-usb-audio
[ 4.279179] Sound aic3x:===========probe===============
[ 4.279227] Sound aic3x:===========probe=============== OK
[ 4.279409] Sound aic3x:===========probe===============
[ 4.285213] Sound aic3x:===========probe=============== OK
[ 4.285213] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.285335] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.377285] OPE platform probe
[ 4.377356] OPE platform probe successful
[ 4.391834] SOUND MACHINE DRIVER Set master clock 12Mhz
[ 4.442489] Sound aic3x:===========aic3x_probe===============
[ 4.448892] Sound aic3x:===========aic3x_probe=============== OK
[ 4.450662] Sound aic3x:===========aic3x_probe===============
[ 4.454397] Sound aic3x:===========aic3x_probe=============== OK
[ 4.454398] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.454484] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.454574] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.454660] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.454748] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.454831] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.454919] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.455007] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.455089] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.455173] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.455258] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.455343] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.455425] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.455516] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.455603] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.455684] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.455766] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.455850] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.455947] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.456035] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.459762] SOUND MACHINE DRIVER Set master clock 12Mhz
[ 4.460025] aic3x: SOUND DAI format 16385 Master/Slave: 16384
[ 4.460027] aic3x: SOUND DAI format Slave Mode
[ 4.460949] SOUND MACHINE DRIVER Set master clock 12Mhz
[ 4.461214] aic3x: SOUND DAI format 16385 Master/Slave: 16384
[ 4.461216] aic3x: SOUND DAI format Slave Mode
[ 4.492717] u32 classifier
[ 4.492720] Actions configured
[ 4.492814] Initializing XFRM netlink socket
[ 4.493439] NET: Registered protocol family 10
[ 4.494226] NET: Registered protocol family 17
[ 4.494239] NET: Registered protocol family 15
[ 4.494296] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.494310] Key type dns_resolver registered
[ 4.495075] Registered cp15_barrier emulation handler
[ 4.495090] Registered setend emulation handler
[ 4.496438] registered taskstats version 1
[ 4.501949] isp 15600000.isp: initialized
[ 4.508865] nvcsi 150c0000.nvcsi: initialized
[ 4.515667] tegra-vi4 15700000.vi: initialized
[ 4.516239] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.516324] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.516391] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.516551] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.517393] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--12 bound
[ 4.517407] tegra-vi4 15700000.vi: subdev tp2854 2-0009 bound
[ 4.520577] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--11 bound
[ 4.520582] tegra-vi4 15700000.vi: subdev tp2854 2-0010 bound
[ 4.522229] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--10 bound
[ 4.522240] tegra-vi4 15700000.vi: subdev tp2854 2-0011 bound
[ 4.523680] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--9 bound
[ 4.523686] tegra-vi4 15700000.vi: subdev tp2854 2-0012 bound
[ 4.525283] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--8 bound
[ 4.525289] tegra-vi4 15700000.vi: subdev tp2854 0-0001 bound
[ 4.526676] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--7 bound
[ 4.526681] tegra-vi4 15700000.vi: subdev tp2854 0-0002 bound
[ 4.528008] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--6 bound
[ 4.528013] tegra-vi4 15700000.vi: subdev tp2854 0-0003 bound
[ 4.529901] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--5 bound
[ 4.529907] tegra-vi4 15700000.vi: subdev tp2854 0-0004 bound
[ 4.531287] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--4 bound
[ 4.531292] tegra-vi4 15700000.vi: subdev tp2854 0-0005 bound
[ 4.532648] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--3 bound
[ 4.532653] tegra-vi4 15700000.vi: subdev tp2854 0-0006 bound
[ 4.533983] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[ 4.533988] tegra-vi4 15700000.vi: subdev tp2854 0-0007 bound
[ 4.535280] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 4.535285] tegra-vi4 15700000.vi: subdev tp2854 0-0008 bound
[ 4.551540] tegra_rtc c2a0000.rtc: setting system clock to 2020-04-06 15:32:51 UTC (1586187171)
[ 4.581698] bpmp: mounted debugfs mirror
[ 4.585116] bwmgr: missing cdev-type property
[ 4.592382] spmic-ldo0: disabling
[ 4.592651] spmic-ldo1: disabling
[ 4.592815] en-vdd-sd: disabling
[ 4.592818] vdd-usb0-5v: disabling
[ 4.592820] vdd-usb1-5v: disabling
[ 4.592822] vdd-3v3: disabling
[ 4.592825] en-vdd-vcm-2v8: disabling
[ 4.592827] vdd-sys-bl: disabling
[ 4.592830] ALSA device list:
[ 4.592833] #0: tegra-hda at 0x3518000 irq 385
[ 4.592835] #1: tegra-sound
[ 5.421531] Waiting for root device /dev/mmcblk0p33...
[ 5.465669] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.519548] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.541537] mmc0: periodic cache flush enabled
[ 5.546016] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.552889] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 5.557677] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 5.563824] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 5.574034] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 5.585147] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 5.649837] EXT4-fs (mmcblk0p33): mounted filesystem with ordered data mode. Opts: (null)
[ 5.658134] VFS: Mounted root (ext4 filesystem) on device 259:1.
[ 5.666231] devtmpfs: mounted
[ 5.670927] Freeing unused kernel memory: 7616K
[ 5.753434] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.760370] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.767332] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.782865] udevd[1958]: starting eudev-3.2.8
[ 5.913968] udevd[1966]: conflicting device node '/dev/input/event1' found, link to '/dev/input/event1' will not be created
[ 5.918053] udevd[1960]: conflicting device node '/dev/input/event0' found, link to '/dev/input/event0' will not be created
[ 6.052592] udevd[1962]: conflicting device node '/dev/input/event2' found, link to '/dev/input/event2' will not be created
[ 6.076945] isawd: loading out-of-tree module taints kernel.
[ 6.083191] isawatchdog: spi_isawd_probe: Registered SPI FPGA.
[ 6.092035] isawatchdog: Register: 11B
[ 6.096053] isawatchdog: Watchdog Presense: AA
[ 6.100520] isawatchdog: Watchdog Part ID: 32
[ 6.104913] isawatchdog: Watchdog Major Number:509
[ 6.110733] isawatchdog: isawatchdog is ready
[ 6.138963] EXT4-fs (mmcblk0p33): re-mounted. Opts: (null)
[ 6.587510] nvgpu: 17000000.gp10b railgate_enable_store:283 [INFO] railgate is disabled.
[ 6.655411] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 6.659501] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b e4 c7 10
[ 6.659624] libphy: dwc_phy: probed
[ 6.660115] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 6.731955] tg3.c:v3.137 (May 11, 2014)
[ 6.731979] tg3 0000:01:00.0: enabling device (0000 -> 0002)
[ 6.755850] tg3 0000:01:00.0 eth1: Tigon3 [partno(BCM95719A1904AC) rev 5719001] (PCI Express) MAC address 00:0a:f7:85:4d:bc
[ 6.755856] tg3 0000:01:00.0 eth1: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 6.755859] tg3 0000:01:00.0 eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 6.755862] tg3 0000:01:00.0 eth1: dma_rwctrl[00000001] dma_mask[64-bit]
[ 6.758031] tg3 0000:01:00.1: enabling device (0000 -> 0002)
[ 6.779463] tg3 0000:01:00.1 eth2: Tigon3 [partno(BCM95719A1904AC) rev 5719001] (PCI Express) MAC address 00:0a:f7:85:4d:bd
[ 6.779471] tg3 0000:01:00.1 eth2: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 6.779475] tg3 0000:01:00.1 eth2: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 6.779480] tg3 0000:01:00.1 eth2: dma_rwctrl[00000001] dma_mask[64-bit]
[ 6.781620] tg3 0000:01:00.2: enabling device (0000 -> 0002)
[ 6.806204] tg3 0000:01:00.2 eth3: Tigon3 [partno(BCM95719A1904AC) rev 5719001] (PCI Express) MAC address 00:0a:f7:85:4d:be
[ 6.806212] tg3 0000:01:00.2 eth3: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 6.806216] tg3 0000:01:00.2 eth3: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 6.806221] tg3 0000:01:00.2 eth3: dma_rwctrl[00000001] dma_mask[64-bit]
[ 6.989984] iommu: Removing device 0000:01:00.2 from group 61
[ 6.994253] TP2854 driver version 0.7.8 loaded
[ 6.995186] Detected TP28xx
[ 6.995610] Detected ID&revision 5401
[ 7.011062] Detected TP28xx
[ 7.011391] Detected ID&revision 5401
[ 7.027381] Detected TP28xx
[ 7.027719] Detected ID&revision 5401
[ 7.043480] TP2854_watchdog_init: done!
[ 7.043482] TP2854 Driver Init Successful!
[ 7.043488] TP2854_watchdog_deamon: start!
[ 7.043751] 2video in ch00 chip 0
[ 7.043893] video format 3 detected ch00 chip 0 count 0
[ 7.048666] 2video in ch01 chip 0
[ 7.048806] video format c detected ch01 chip 0 count 0
[ 7.054798] 2video in ch03 chip 0
[ 7.054939] video format b detected ch03 chip 0 count 0
[ 7.060820] 2video in ch01 chip 1
[ 7.060960] video format e detected ch01 chip 1 count 0
[ 7.069292] 2video in ch01 chip 2
[ 7.069432] video format a detected ch01 chip 2 count 0
[ 7.075298] 2video in ch03 chip 2
[ 7.075438] video format c detected ch03 chip 2 count 0
[ 7.605887] video locked 7e ch00 chip 0
[ 7.606968] video format c detected ch01 chip 0 count 1
[ 7.616452] video locked 7b ch03 chip 0
[ 7.617637] video locked 78 ch01 chip 1
[ 7.619265] video locked 6b ch01 chip 2
[ 7.620551] video format c detected ch03 chip 2 count 1
[ 7.850770] random: crng init done
[ 7.850773] random: 3 urandom warning(s) missed due to ratelimiting
[ 8.150265] status7e ch00
[ 8.150405] CVSTD03 ch00
[ 8.150787] video format c detected ch01 chip 0 count 2
[ 8.156104] status7b ch03
[ 8.156244] CVSTD0b ch03
[ 8.157107] status78 ch01
[ 8.157246] CVSTD0e ch01
[ 8.158594] status6b ch01
[ 8.158734] CVSTD0a ch01
[ 8.159356] video format c detected ch03 chip 2 count 2
[ 8.502256] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 8.504429] tegra-xusb 3530000.xhci: extcon 0: ffffffc0ef34c000 id
[ 8.509687] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 8.515008] ahci 0000:02:00.0: version 3.0
[ 8.525372] ahci 0000:02:00.0: AHCI 0001.0000 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 8.525383] ahci 0000:02:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 8.527083] scsi host0: ahci
[ 8.527917] scsi host1: ahci
[ 8.528188] scsi host2: ahci
[ 8.528967] scsi host3: ahci
[ 8.529099] ata1: SATA max UDMA/133 abar m2048@0x40210000 port 0x40210100 irq 448
[ 8.529105] ata2: SATA max UDMA/133 abar m2048@0x40210000 port 0x40210180 irq 448
[ 8.529110] ata3: SATA max UDMA/133 abar m2048@0x40210000 port 0x40210200 irq 448
[ 8.529115] ata4: SATA max UDMA/133 abar m2048@0x40210000 port 0x40210280 irq 448
[ 8.538698] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 8.538723] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.539544] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 8.539578] tegra-xusb 3530000.xhci: irq 72, io mem 0x03530000
[ 8.539747] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.539752] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.539756] usb usb1: Product: xHCI Host Controller
[ 8.539759] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.539763] usb usb1: SerialNumber: 3530000.xhci
[ 8.540063] hub 1-0:1.0: USB hub found
[ 8.540114] hub 1-0:1.0: 4 ports detected
[ 8.694282] video locked 7a ch01 chip 0
[ 8.694668] CVSTD0c ch01 chip 0
[ 8.701685] RX=00 standard to 04 ch03
[ 8.709870] RX=f3 standard to 01 ch01
[ 8.710358] video locked 7b ch03 chip 2
[ 8.710747] CVSTD0c ch03 chip 2
[ 8.844068] ata4: SATA link down (SStatus 0 SControl 300)
[ 8.844423] ata3: SATA link down (SStatus 0 SControl 300)
[ 9.005677] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 9.005726] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 9.008782] ata2.00: ATA-10: ST10000VX0004-1ZE101, AV01, max UDMA/133
[ 9.008791] ata2.00: 19532873728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 9.011793] ata2.00: configured for UDMA/133
[ 9.016493] ata1.00: ATA-10: ST10000VX0004-1ZE101, AV01, max UDMA/133
[ 9.016500] ata1.00: 19532873728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 9.019463] ata1.00: configured for UDMA/133
[ 9.019938] scsi 0:0:0:0: Direct-Access ATA ST10000VX0004-1Z AV01 PQ: 0 ANSI: 5
[ 9.058291] sd 0:0:0:0: [sda] 19532873728 512-byte logical blocks: (10.0 TB/9.10 TiB)
[ 9.058298] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 9.058387] sd 0:0:0:0: [sda] Write Protect is off
[ 9.058393] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 9.058432] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.059281] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.059852] scsi 1:0:0:0: Direct-Access ATA ST10000VX0004-1Z AV01 PQ: 0 ANSI: 5
[ 9.094064] sd 1:0:0:0: [sdb] 19532873728 512-byte logical blocks: (10.0 TB/9.10 TiB)
[ 9.094071] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 9.094193] sd 1:0:0:0: [sdb] Write Protect is off
[ 9.094200] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 9.094242] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.095593] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 9.114211] sda: sda1 sda2 sda5 sda6 sda7 sda8 sda9
[ 9.115462] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 9.149898] sdb: sdb1 sdb2 sdb5 sdb6 sdb7 sdb8 sdb9
[ 9.150896] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 9.163876] fuse init (API version 7.26)
[ 9.168751] usbcore: registered new interface driver usbserial
[ 9.173775] usbcore: registered new interface driver ftdi_sio
[ 9.173804] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 9.183357] usbcore: registered new interface driver asix
[ 9.208900] usbcore: registered new interface driver rtl8812au
[ 9.218057] usbcore: registered new interface driver usbhid
[ 9.218063] usbhid: USB HID core driver
[ 9.226765] udevd[1973]: conflicting device node '/dev/input/mice' found, link to '/dev/input/mice' will not be created
[ 9.226975] mousedev: PS/2 mouse device common for all mice
[ 9.242692] status7a ch01
[ 9.242836] CVSTD0c ch01
[ 9.245836] status7b ch03
[ 9.245974] CVSTD0c ch03
[ 9.577913] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 9.577926] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 9.579677] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.579683] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.579686] usb usb2: Product: xHCI Host Controller
[ 9.579690] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 9.579693] usb usb2: SerialNumber: 3530000.xhci
[ 9.580921] hub 2-0:1.0: USB hub found
[ 9.581308] hub 2-0:1.0: 3 ports detected
[ 9.679178] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 9.682889] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.788339] RX=00 standard to 04 ch01
[ 9.797245] RX=e1 standard to 01 ch03
[ 11.041712] usb usb1-port2: over-current condition
[ 11.161666] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 11.182010] usb 1-3: New USB device found, idVendor=0424, idProduct=2514
[ 11.182015] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.183123] hub 1-3:1.0: USB hub found
[ 11.183241] hub 1-3:1.0: 4 ports detected
[ 12.089990] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.266131] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 12.410195] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.410768] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.715653] Wake76 for irq=199
[ 12.715659] Wake77 for irq=199
[ 12.715661] Wake78 for irq=199
[ 12.715664] Wake79 for irq=199
[ 12.715666] Wake80 for irq=199
[ 12.715668] Wake81 for irq=199
[ 12.715670] Wake82 for irq=199
[ 12.715699] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 12.715702] tegra-xusb 3530000.xhci: port 1 over-current detected
[ 12.715710] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 12.715721] tegra-xusb-padctl 3520000.xusb_padctl: tegra186_phy_xusb_handle_overcurrent: clear port 1 pin 1 OC
[ 13.537652] usb 1-2: new high-speed USB device number 3 using tegra-xusb
[ 13.558438] usb 1-2: New USB device found, idVendor=0424, idProduct=2744
[ 13.558442] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 13.558444] usb 1-2: Product: USB2744
[ 13.558447] usb 1-2: Manufacturer: Microchip Tech
[ 13.559263] hub 1-2:1.0: USB hub found
[ 13.559324] hub 1-2:1.0: 3 ports detected
[ 13.917946] reg01=7a reg04@2f=0c 05 std02 ch03
[ 13.918193] Cgain=0x23
[ 13.919901] Cgain=0x0b
[ 13.965885] Cgain=0x0c
[ 14.521705] eqos 2490000.ether_qos eth0: Link is Down
[ 15.004702] reg01=6a reg04@2f=0c 20 std01 ch01
[ 15.004948] Cgain=0x1a
[ 15.008035] Cgain=0x0e
[ 16.357129] Adding 524284k swap on /dev/disk/by-type/ata/ZA2BHR23/part1. Priority:-1 extents:1 across:524284k
[ 16.413372] XFS (sdb2): Mounting V4 Filesystem
[ 16.504705] XFS (sdb2): Ending clean mount
[ 16.676681] XFS (sdb5): Mounting V4 Filesystem
[ 16.779264] XFS (sdb5): Ending clean mount
[ 17.017744] XFS (sdb6): Mounting V4 Filesystem
[ 17.131768] XFS (sdb6): Ending clean mount
[ 17.323062] XFS (sdb7): Mounting V4 Filesystem
[ 17.461785] XFS (sdb7): Ending clean mount
[ 17.700869] XFS (sdb8): Mounting V4 Filesystem
[ 17.794223] XFS (sdb8): Ending clean mount
[ 18.007465] XFS (sdb9): Mounting V4 Filesystem
[ 18.081604] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 18.134784] XFS (sdb9): Ending clean mount
[ 18.600210] Adding 524284k swap on /dev/disk/by-type/ata/ZA2BHRKM/part1. Priority:-2 extents:1 across:524284k
[ 18.646186] XFS (sda2): Mounting V4 Filesystem
[ 18.722152] XFS (sda2): Ending clean mount
[ 18.898944] XFS (sda5): Mounting V4 Filesystem
[ 18.987373] XFS (sda5): Ending clean mount
[ 19.169112] XFS (sda6): Mounting V4 Filesystem
[ 19.273802] XFS (sda6): Ending clean mount
[ 19.445598] XFS (sda7): Mounting V4 Filesystem
[ 19.563418] XFS (sda7): Ending clean mount
[ 19.766057] XFS (sda8): Mounting V4 Filesystem
[ 19.858167] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 19.871862] XFS (sda8): Ending clean mount
[ 19.878437] usb 2-3: New USB device found, idVendor=0424, idProduct=5744
[ 19.878445] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 19.878449] usb 2-3: Product: USB5744
[ 19.878452] usb 2-3: Manufacturer: Microchip Tech
[ 19.881113] hub 2-3:1.0: USB hub found
[ 19.881495] hub 2-3:1.0: 3 ports detected
[ 20.037748] usb 2-3: usb_suspend_both: status 0
[ 20.059165] XFS (sda9): Mounting V4 Filesystem
[ 20.184737] XFS (sda9): Ending clean mount
[ 23.229961] usb usb2: usb_suspend_both: status 0
[ 30.861604] tp2854 0-0001: SET MODE 1
[ 30.861616] tp2854 0-0001: START M 1
[ 31.635510] tp2854 0-0002: SET MODE 0
[ 31.635522] tp2854 0-0002: START M 2
[ 32.371035] tp2854 0-0004: SET MODE 1
[ 32.371047] tp2854 0-0004: START M 4
[ 33.229419] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 4640624 has been capped to VI's max BW 4500000
[ 33.230191] tp2854 0-0006: SET MODE a
[ 33.230198] tp2854 0-0006: START M 6
[ 34.077665] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 5800780 has been capped to VI's max BW 4500000
[ 34.077796] tp2854 2-0010: SET MODE 4
[ 34.077808] tp2854 2-0010: START M 10
[ 34.800980] misc tegra_camera_ctrl: tegra_camera_update_isobw: Warning, Requested ISO BW 6960936 has been capped to VI's max BW 4500000
[ 34.801020] tp2854 2-0012: SET MODE 0
[ 34.801028] tp2854 2-0012: START M 12
[ 183.365979] tegradc 15210000.nvdisplay: blank - powerdown
[ 183.373591] tegradc 15210000.nvdisplay: unblank
[ 183.374733] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 183.374835] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 183.374930] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 183.376702] Parent Clock set for DC plld2
[ 183.380814] tegradc 15210000.nvdisplay: hdmi: tmds rate:154000K prod-setting:prod_c_hdmi_111m_223m
[ 183.382136] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 183.382160] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 183.417673] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 183.417676] Extcon AUX1(HDMI) enable
