When trying to work with HDMI, we found out that the speed of DDC (I2C) Jetson Nano is 400 kHz.
Our display only supports 100 kHz. Can the speed be reduced to 100 kHz?
Wiki: HDMI requires that the E-DDC implement [I2C] standard mode speed (100 [kbit/s] and allows it to optionally implement fast mode speed (400 kbit/s).
Maybe you should share us the dmesg log to check first.
