Can Jetson Nano HDMI DDC (I2C) operate with 100 kHz speed?
You already shared same topics before and you didn’t reply.
There is no case to configure this before.
Understand, but.
Can you specify at what speed this port works according to the existing configuration?
You can use the node to check. Also, you can try to configure it with echo.
/sys/bus/i2c/devices/i2c-*/bus_clk_rate
Thanks, will try.
