HDMI disconnected, Linux Mint on Ubuntu 22.04
Hi, I just got brand new laptop Hyperbook NV5 with GeForce 3050Ti and after few hours of trying to get my second monitor to work I decided to ask you.
I have a fresh installation of Linux Mint 21
Monitor is an old DELL 23" 1920x1080 connected by HDMI → DVI-D cable
SecureBoot seems to be disabled
Here’s my nvidia-bug-report.sh output
nvidia-bug-report.log.gz (342.8 KB)
All external display connectors are driven by the intel igpu but no monitors are detected:
[    30.849] (II) modeset(0): Output eDP-1 connected
[    30.849] (II) modeset(0): Output DP-1 disconnected
[    30.849] (II) modeset(0): Output HDMI-1 disconnected
[    30.849] (II) modeset(0): Output DP-2 disconnected
[    30.849] (II) modeset(0): Output DP-3 disconnected
[    30.849] (II) modeset(0): Output DP-4 disconnected
[    30.849] (II) modeset(0): Output HDMI-2 disconnected
Please check with another cable.
Thanks for your response,
I tried with TV and it doesn’t work, then I’ve installed windows 11 and on windows it works with this cable. I’ve also tried with HDMI-> USB-C adapter but with no luck.
Ok, please check in Windows whether the external monitor is driven by the intel or the nvidia gpu.
Since there are some errors in the logs regarding the i915 intel driver, please use the liquorix ppa to upgrade your kernel to latest. Also, please check for a bios update.
It seems that it is driven by the intel.
As far as I know I have the latest kernel and bios.
You’re running the stock kernel 5.15 of 22.04. The liqourix ppa will get you 5.18 and the updated intel driver.
Ok, now I have
Operating System: Linux Mint
Kernel: Linux 5.18.0-16.1-liquorix-amd64
Still nothing changed
nvidia-bug-report.log.gz (107.4 KB)
Still the same errors
[    2.525902] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
[    2.760046] i915 0000:00:02.0: drm_WARN_ON(intel_dp->pps.vdd_wakeref)
[    2.760058] WARNING: CPU: 6 PID: 307 at drivers/gpu/drm/i915/display/intel_pps.c:591 intel_pps_vdd_on_unlocked+0x286/0x2a0 [i915]
[    2.760137] Modules linked in: nvidia_drm(POE+) nvidia_modeset(POE) nvidia(POE) hid_generic i915(+) i2c_algo_bit ttm drm_kms_helper syscopyarea sysfillrect sysimgblt intel_lpss_pci fb_sys_fops i2c_hid_acpi cec intel_lpss crct10dif_pclmul crc32_pclmul ghash_clmulni_intel ahci i2c_hid aesni_intel xhci_pci i2c_i801 r8169 rc_core nvme crypto_simd cryptd psmouse drm i2c_smbus realtek libahci idma64 xhci_pci_renesas nvme_core intel_pmt hid wmi pinctrl_tigerlake video
[    2.760151] CPU: 6 PID: 307 Comm: systemd-udevd Tainted: P           OE     5.15.0-41-generic #44-Ubuntu
[    2.760153] Hardware name: Notebook V15x_V17xPNKPNJPNH/V15x_V17xPNKPNJPNH, BIOS 1.07.11RBL1 04/14/2022
[    2.760153] RIP: 0010:intel_pps_vdd_on_unlocked+0x286/0x2a0 [i915]
[    2.760200] Code: 4c 8b 77 50 4d 85 f6 75 03 4c 8b 37 e8 73 2c 7b d8 48 c7 c1 28 b1 d4 c0 4c 89 f2 48 c7 c7 61 f8 d5 c0 48 89 c6 e8 41 23 c2 d8 <0f> 0b e9 1e fe ff ff e8 de 7b cc d8 66 66 2e 0f 1f 84 00 00 00 00
[    2.760201] RSP: 0018:ffffbf3840f5f380 EFLAGS: 00010282
[    2.760202] RAX: 0000000000000000 RBX: ffff97d107d1a170 RCX: ffffffff9ab7a468
[    2.760203] RDX: 0000000000000000 RSI: 0000000000000003 RDI: 0000000000000003
[    2.760204] RBP: ffffbf3840f5f3d8 R08: 0000000000000003 R09: 000000009b1d002a
[    2.760204] R10: ffffffffffffffff R11: 0000000000000001 R12: 0000000000000001
[    2.760204] R13: ffff97d12a5e0000 R14: ffff97d102f4bab0 R15: ffff97d12a5e07d0
[    2.760205] FS:  00007fc22e0298c0(0000) GS:ffff97d85f380000(0000) knlGS:0000000000000000
[    2.760206] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    2.760206] CR2: 000055cf73d69d38 CR3: 00000001207ec002 CR4: 0000000000770ee0
[    2.760207] PKRU: 55555554
[    2.760207] Call Trace:
[    2.760208]  <TASK>
[    2.760209]  ? __cond_resched+0x1a/0x50
[    2.760212]  intel_dp_aux_xfer+0x10d/0x870 [i915]
[    2.760258]  ? psi_task_switch+0xc6/0x220
[    2.760260]  ? finish_task_switch.isra.0+0xa6/0x270
[    2.760262]  ? __schedule+0x245/0x590
[    2.760263]  intel_dp_aux_transfer+0x177/0x2b0 [i915]
[    2.760301]  drm_dp_dpcd_access+0x6f/0x120 [drm_kms_helper]
[    2.760312]  drm_dp_dpcd_write+0xae/0x100 [drm_kms_helper]
[    2.760318]  intel_dp_set_power+0x61/0x170 [i915]
[    2.760355]  intel_ddi_post_disable_dp.constprop.0+0x19e/0x230 [i915]
[    2.760392]  intel_ddi_post_disable+0x1e7/0x290 [i915]
[    2.760428]  ? intel_disable_ddi+0xd4/0x170 [i915]
[    2.760464]  ? synchronize_irq+0x3e/0xb0
[    2.760465]  intel_encoders_post_disable+0x83/0xa0 [i915]
[    2.760512]  hsw_crtc_disable+0x23/0x30 [i915]
[    2.760549]  intel_old_crtc_state_disables+0xfb/0x1c0 [i915]
[    2.760583]  intel_commit_modeset_disables+0x1f1/0x200 [i915]
[    2.760622]  intel_atomic_commit_tail+0x198/0xb70 [i915]
[    2.760656]  intel_atomic_commit+0x390/0x410 [i915]
[    2.760685]  drm_atomic_commit+0x47/0x50 [drm]
[    2.760704]  intel_initial_commit+0x17b/0x200 [i915]
[    2.760739]  intel_modeset_init+0x23/0x80 [i915]
[    2.760778]  i915_driver_probe+0x1dd/0x470 [i915]
[    2.760817]  ? mutex_lock+0x13/0x40
[    2.760818]  i915_pci_probe+0x58/0x140 [i915]
[    2.760855]  local_pci_probe+0x48/0x90
[    2.760858]  pci_device_probe+0x115/0x1f0
[    2.760859]  really_probe+0x21b/0x420
[    2.760860]  __driver_probe_device+0x115/0x190
[    2.760861]  driver_probe_device+0x23/0xc0
[    2.760863]  __driver_attach+0xbd/0x1d0
[    2.760864]  ? __device_attach_driver+0x110/0x110
[    2.760865]  bus_for_each_dev+0x7c/0xc0
[    2.760866]  driver_attach+0x1e/0x20
[    2.760867]  bus_add_driver+0x135/0x200
[    2.760868]  driver_register+0x95/0xf0
[    2.760870]  __pci_register_driver+0x68/0x70
[    2.760871]  i915_register_pci_driver+0x23/0x30 [i915]
[    2.760904]  i915_init+0x3b/0xfc [i915]
[    2.760939]  ? 0xffffffffc079d000
[    2.760940]  do_one_initcall+0x46/0x1d0
[    2.760942]  ? kmem_cache_alloc_trace+0x19e/0x2e0
[    2.760944]  do_init_module+0x52/0x250
[    2.760946]  load_module+0xac9/0xbb0
[    2.760947]  __do_sys_finit_module+0xbf/0x120
[    2.760948]  __x64_sys_finit_module+0x18/0x20
[    2.760948]  do_syscall_64+0x59/0xc0
[    2.760950]  ? __x64_sys_mmap+0x33/0x40
[    2.760951]  ? do_syscall_64+0x69/0xc0
[    2.760952]  ? exit_to_user_mode_prepare+0x37/0xb0
[    2.760954]  ? syscall_exit_to_user_mode+0x27/0x50
[    2.760955]  ? __x64_sys_newfstatat+0x1c/0x20
[    2.760957]  ? do_syscall_64+0x69/0xc0
[    2.760958]  ? exit_to_user_mode_prepare+0x37/0xb0
[    2.760959]  ? syscall_exit_to_user_mode+0x27/0x50
[    2.760960]  ? __x64_sys_finit_module+0x18/0x20
[    2.760960]  ? do_syscall_64+0x69/0xc0
[    2.760961]  ? sysvec_apic_timer_interrupt+0x4e/0x90
[    2.760962]  ? asm_sysvec_apic_timer_interrupt+0xa/0x20
[    2.760964]  entry_SYSCALL_64_after_hwframe+0x44/0xae
[    2.760965] RIP: 0033:0x7fc22e721a3d
[    2.760966] Code: 5b 41 5c c3 66 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c3 a3 0f 00 f7 d8 64 89 01 48
[    2.760967] RSP: 002b:00007ffedc714668 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[    2.760968] RAX: ffffffffffffffda RBX: 000055cf73d17250 RCX: 00007fc22e721a3d
[    2.760969] RDX: 0000000000000000 RSI: 00007fc22e8b8441 RDI: 0000000000000015
[    2.760969] RBP: 0000000000020000 R08: 0000000000000000 R09: 0000000000000002
[    2.760970] R10: 0000000000000015 R11: 0000000000000246 R12: 00007fc22e8b8441
[    2.760970] R13: 000055cf73d14870 R14: 000055cf73d11600 R15: 000055cf73cedf50
[    2.760971]  </TASK>
You should report this to the intel i915 issue tracker though I fear this rather points to another broken bios with an incorrect VBT from insyde.
Hey, I wanted to thank you for your time, and I wanted to tell you (and others - maybe someone will need this) that HDMI → mini DP works in my case.
It turns out that HDMI and DP are sharing some ports (if I understand correctly) and current driver cannot handle this properly.
