I have been flashed the jetson
here is the conf code
# Copyright (c) 2011-2015 NVIDIA CORPORATION. All Rights Reserved.
# This is the minimal configuration necessary to use the Tegra driver.
# Please refer to the xorg.conf man page for more configuration
# options provided by the X server, including display-related options
# provided by RandR 1.2 and higher.
# Disable extensions not useful on Tegra.
#Section "Files"
#Endsection
#Section "ServerFlags"
#Option "NoTrapSignals" "true"
#Endsection
#Section "Module"
# Disable "fb"
# Disable "dri"
# SubSection "extmod"
# Option "omit xfree86-dga"
# EndSubSection
#EndSection
#Section "Extensions"
#Endsection
#Section "InputDevice"
#Endsection
#Section "InputClass"
#Endsection
Section "Device"
Identifier "Tegra0"
Driver "fbdev"
# Option "AllowEmptyInitialConfiguration" "true"
Option "UseEDID" "true"
# Option "DPI" "96 x 96"
# Option "DPI" "168 x 168"
# Option "nvidia-auto-select" "false"
# Option "fbdev" "/dev/fb1"
EndSection
#Section "VideoAdaptor"
#Endsection
Section "Monitor"
Identifier "DFP-0"
ModelName ""
VendorName "ADA"
# Monitor Manufactured week 1 of 2007
# EDID version 1.3
# Digital Display
DisplaySize 150 100
Gamma 1.00
Option "DPMS" "false"
# Option "DPI" "96x96"
Modeline "1024x600" 32.00 1024 1064 1112 1152 600 613 616 645 -hsync -vsync
#Modeline "1024x600"x0.0 32.00 1024 1064 1112 1152 600 613 616 645 -hsync -vsync (27.8 kHz)
#Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
EndSection
#Section "Modes"
#Endsection
Section "Screen"
Identifier "Default Screen"
Device "Tegra0"
Monitor "DFP-0"
DefaultDepth 8
SubSection "Display"
Depth 8
Modes "1024x600"
# Modes "8192x8192" "8192x4608" "7680x4800" "7680x4320" "6400x4800" "6400x4096" "5120x4096" "5120x3200" "5120x2880" "5120x2160" "4096x3702" "4096x2304" "3840x2400" "3840x2160" "3440x1440" "3200x2400" "3200x1800" "2880x1800" "2880x900" "2800x2100" "2736x1824" "2732x2048" "2560x2048" "2560x1920" "2560x1800" "2560x1700" "2560x1600" "2560x1440" "2560x1080" "2538x1080" "2304x1728" "2304x1440" "2160x1440" "2048x1536" "2048x1280" "2048x1152" "1920x1440" "1920x1400" "1920x1280" "1920x1200" "1920x1080" "1856x1392" "1800x1440" "1792x1344" "1776x1000" "1680x1050" "1600x1280" "1600x1200" "1600x1024" "1600x900" "1600x768" "1440x1080" "1440x1024" "1440x960" "1440x960" "1440x900" "1366x768" "1334x750" "1280x1024" "1280x960" "1280x854" "1280x800" "1280x768" "1280x720" "1152x900" "1152x864" "1152x768" "1152x720" "1136x640" "1120x832" "1080x1200" "1024x1024" "1024x800" "1024x768" "1024x640" "1024x600" "1024x576" "960x720" "960x640" "960x544" "960x540" "854x480" "848x480" "832x624" "800x600" "800x480" "800x352" "800x240" "768x480" "720x364" "720x350" "720x348" "640x512" "640x480" "640x400" "640x360" "640x350" "640x320" "640x256" "640x240" "640x200" "600x480" "560x192" "512x384" "514x342" "512x256" "480x500" "480x320" "480x272" "480x250" "480x234" "432x240" "432x128" "416x352" "400x300" "400x270" "400x240" "384x288" "376x240" "320x320" "320x256" "320x240" "320x224" "320x208" "320x200" "320x192" "312x390" "280x192" "272x340" "256x256" "240x240" "240x160" "240x64" "220x176" "208x208" "208x176" "160x256" "160x200" "160x160" "160x152" "160x102" "150x40" "144x168" "140x192" "128x128" "128x48" "128x36" "102x64" "96x96" "96x65" "96x64" "84x48" "75x64" "72x64" "64x64" "60x40" "48x32" "42x32" "42x11" "40x40" "32x32" "16x16"
#Modeline "Mode 0" 32.00 1024 1064 1112 1152 600 613 616 645 -hsync -vsync
EndSubSection
EndSection
#Section "ServerLayout"
#Endsection
#Section "DRI"
#Endsection
#Section "Vendor"
#Endsection
Here is the log output
[ 12.065]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 12.065] X Protocol Version 11, Revision 0
[ 12.065] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
[ 12.065] Current Operating System: Linux tegra-ubuntu 3.10.40-ga7da876 #1 SMP PREEMPT Tue Jun 7 21:05:06 PDT 2016 armv7l
[ 12.065] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
[ 12.065] Build Date: 12 February 2015 02:55:07PM
[ 12.065] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[ 12.065] Current version of pixman: 0.30.2
[ 12.065] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 12.065] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 12.066] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 21 02:42:54 2016
[ 12.077] (==) Using config file: "/etc/X11/xorg.conf"
[ 12.077] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 12.082] (==) No Layout section. Using the first Screen section.
[ 12.082] (**) |-->Screen "Default Screen" (0)
[ 12.082] (**) | |-->Monitor "DFP-0"
[ 12.082] (**) | |-->Device "Tegra0"
[ 12.082] (==) Automatically adding devices
[ 12.082] (==) Automatically enabling devices
[ 12.082] (==) Automatically adding GPU devices
[ 12.092] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 12.093] Entry deleted from font path.
[ 12.093] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 12.093] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 12.094] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 12.094] Entry deleted from font path.
[ 12.094] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 12.094] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 12.094] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 12.094] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 12.094] (II) Loader magic: 0xb6fdff10
[ 12.094] (II) Module ABI versions:
[ 12.094] X.Org ANSI C Emulation: 0.4
[ 12.094] X.Org Video Driver: 15.0
[ 12.094] X.Org XInput driver : 20.0
[ 12.094] X.Org Server Extension : 8.0
[ 12.095] Initializing built-in extension Generic Event Extension
[ 12.095] Initializing built-in extension SHAPE
[ 12.095] Initializing built-in extension MIT-SHM
[ 12.095] Initializing built-in extension XInputExtension
[ 12.095] Initializing built-in extension XTEST
[ 12.095] Initializing built-in extension BIG-REQUESTS
[ 12.096] Initializing built-in extension SYNC
[ 12.096] Initializing built-in extension XKEYBOARD
[ 12.096] Initializing built-in extension XC-MISC
[ 12.096] Initializing built-in extension SECURITY
[ 12.096] Initializing built-in extension XINERAMA
[ 12.096] Initializing built-in extension XFIXES
[ 12.096] Initializing built-in extension RENDER
[ 12.096] Initializing built-in extension RANDR
[ 12.096] Initializing built-in extension COMPOSITE
[ 12.096] Initializing built-in extension DAMAGE
[ 12.096] Initializing built-in extension MIT-SCREEN-SAVER
[ 12.096] Initializing built-in extension DOUBLE-BUFFER
[ 12.096] Initializing built-in extension RECORD
[ 12.096] Initializing built-in extension DPMS
[ 12.096] Initializing built-in extension Present
[ 12.096] Initializing built-in extension DRI3
[ 12.096] Initializing built-in extension X-Resource
[ 12.096] Initializing built-in extension XVideo
[ 12.096] Initializing built-in extension XVideo-MotionCompensation
[ 12.096] Initializing built-in extension SELinux
[ 12.096] Initializing built-in extension XFree86-VidModeExtension
[ 12.096] Initializing built-in extension XFree86-DGA
[ 12.096] Initializing built-in extension XFree86-DRI
[ 12.096] Initializing built-in extension DRI2
[ 12.097] (II) LoadModule: "glx"
[ 12.108] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 12.377] (II) Module glx: vendor="NVIDIA Corporation"
[ 12.377] compiled for 4.0.2, module version = 1.0.0
[ 12.377] Module class: X.Org Server Extension
[ 12.377] (II) NVIDIA GLX Module 21.5 Release Build (integ_stage_rel) (buildbrain@mobile-u64-234) Tue Jun 7 21:04:57 PDT 2016
[ 12.377] Loading extension GLX
[ 12.377] (II) LoadModule: "fbdev"
[ 12.386] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 12.388] (II) Module fbdev: vendor="X.Org Foundation"
[ 12.388] compiled for 1.15.0, module version = 0.4.4
[ 12.388] Module class: X.Org Video Driver
[ 12.389] ABI class: X.Org Video Driver, version 15.0
[ 12.389] (II) FBDEV: driver for framebuffer: fbdev
[ 12.389] (++) using VT number 7
[ 12.390] (WW) Falling back to old probe method for fbdev
[ 12.390] (II) Loading sub module "fbdevhw"
[ 12.390] (II) LoadModule: "fbdevhw"
[ 12.390] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 12.391] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 12.391] compiled for 1.15.1, module version = 0.0.2
[ 12.391] ABI class: X.Org Video Driver, version 15.0
[ 12.391] (II) FBDEV(0): using default device
[ 12.391] (**) FBDEV(0): Depth 8, (--) framebuffer bpp 8
[ 12.391] (==) FBDEV(0): Default visual is PseudoColor
[ 12.391] (**) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 12.392] (II) FBDEV(0): hardware: tegra_fb (video memory: 18432kB)
[ 12.392] (II) FBDEV(0): checking modes against framebuffer device...
[ 12.392] (II) FBDEV(0): mode "1024x600" ok
[ 12.392] (II) FBDEV(0): checking modes against monitor...
[ 12.392] (--) FBDEV(0): Virtual size is 1024x600 (pitch 1024)
[ 12.392] (**) FBDEV(0): Mode "1024x600": 32.0 MHz (scaled from 0.0 MHz), 27.8 kHz, 43.1 Hz
[ 12.392] (II) FBDEV(0): Modeline "1024x600"x0.0 32.00 1024 1064 1112 1152 600 613 616 645 -hsync -vsync (27.8 kHz)
[ 12.392] (**) FBDEV(0): Display dimensions: (150, 100) mm
[ 12.392] (**) FBDEV(0): DPI set to (173, 152)
[ 12.392] (II) Loading sub module "fb"
[ 12.392] (II) LoadModule: "fb"
[ 12.392] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 12.394] (II) Module fb: vendor="X.Org Foundation"
[ 12.394] compiled for 1.15.1, module version = 1.0.0
[ 12.394] ABI class: X.Org ANSI C Emulation, version 0.4
[ 12.394] (**) FBDEV(0): using shadow framebuffer
[ 12.394] (II) Loading sub module "shadow"
[ 12.394] (II) LoadModule: "shadow"
[ 12.395] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 12.396] (II) Module shadow: vendor="X.Org Foundation"
[ 12.396] compiled for 1.15.1, module version = 1.1.0
[ 12.396] ABI class: X.Org ANSI C Emulation, version 0.4
[ 12.397] (EE) FBDEV(0): FBIOPUT_VSCREENINFO: Invalid argument
[ 12.397] (EE) FBDEV(0): mode initialization failed
[ 12.397] (EE)
Fatal server error:
[ 12.397] (EE) AddScreen/ScreenInit failed for driver 0
[ 12.397] (EE)
[ 12.397] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 12.397] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 12.397] (EE)
[ 12.399] (EE) Server terminated with error (1). Closing log file.
This is the output of xrandr, I connected to jetson using ssh. Is the command of xrandr correct?
ubuntu@tegra-ubuntu:~$ sudo xrandr -q -d :0
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1200, current 1920 x 1200, maximum 1920 x 1200
default connected 1920x1200+0+0 0mm x 0mm
1920x1200 60.0*
this is the output of xrand only, I think it detect my laptop setting.
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 32767 x 32767
LVDS1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1600x900 60.0*+ 40.0
1440x900 59.9
1368x768 60.0
1360x768 59.8 60.0
1152x864 60.0
1280x720 60.0
1024x768 60.0
1024x576 60.0
960x540 60.0
800x600 60.3 56.2
864x486 60.0
800x450 60.0
640x480 59.9
720x405 60.0
640x360 60.0
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
DP3 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
HDMI3 disconnected (normal left inverted right x axis y axis)
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
