In Jetson Nano board, after boot-up I installed the JetPack using the below commands :-
sudo apt update
apt depends nvidia-jetpack | awk '{print $2}' | xargs -I {} sudo apt install -y {}
The installation is successful.
The HDMI is showing the below errors, after the reboot.
[ 7.831749] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 7.847426] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 8.054827] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.072073] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.100762] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.124407] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.154407] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.158760] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.188448] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.205026] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.222056] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.236579] usb 2-1: Manufacturer: Generic
[ 8.253340] systemd[1]: Created slice System Slice.
[ 8.255923] hub 2-1:1.0: USB hub found
[ 8.256875] hub 2-1:1.0: 4 ports detected
[ 8.307314] systemd[1]: Listening on Syslog Socket.
[ 8.333094] systemd[1]: Listening on Journal Socket.
[ 8.550306] usb 2-1.3: new SuperSpeed USB device number 3 using tegra-xusb
[ 8.570676] usb 2-1.3: New USB device found, idVendor=0451, idProduct=8140
[ 8.587812] usb 2-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.594355] hub 2-1.3:1.0: USB hub found
[ 8.594505] hub 2-1.3:1.0: 4 ports detected
[ 8.727952] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 8.853790] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.882465] usb 2-1.3.4: new SuperSpeed USB device number 4 using tegra-xusb
[ 8.927066] usb 2-1.3.4: New USB device found, idVendor=0451, idProduct=8140
[ 8.944179] usb 2-1.3.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.986558] hub 2-1.3.4:1.0: USB hub found
[ 8.986753] hub 2-1.3.4:1.0: 4 ports detected
[ 9.110022] usb 2-1.3.4: usb_suspend_both: status 0
[ 9.131252] usb 2-1.3: usb_suspend_both: status 0
[ 11.117961] random: crng init done
[ 11.128466] random: 7 urandom warning(s) missed due to ratelimiting
[ 12.356392] using random self ethernet address
[ 12.356401] using random host ethernet address
[ 14.509877] using random self ethernet address
[ 14.534561] using random host ethernet address
[ 18.364735] nvgpu: 57000000.gpu __nvgpu_timeout_expired_msg_cpu:94 [ERR] Timeout detected @ gr_gk20a_ctx_wait_ucode+0xa4/0x3a8 [nvgpu]
[ 18.390563] nvgpu: 57000000.gpu gr_gk20a_ctx_wait_ucode:528 [ERR] timeout waiting on mailbox=0 value=0x00000010
[ 18.418161] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 18.439591] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x40
[ 18.462050] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x1
[ 18.481004] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 18.498369] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 18.498383] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 18.498394] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 18.498406] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 18.498416] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 18.498426] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 18.498436] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 18.498446] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x300
[ 18.498458] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x10
[ 18.498469] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 18.498480] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x41009
[ 18.498490] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x20
[ 18.498501] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 18.498510] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 18.498520] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 18.498529] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 18.498538] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 18.498548] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 18.498557] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 18.498567] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 18.498577] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 18.498587] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 18.498597] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 18.498607] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 18.498616] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 18.498626] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 18.498635] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 18.498646] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 18.498656] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 18.498667] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 18.498676] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 18.498686] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 18.498696] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.498706] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.498716] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.498725] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.498735] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.498745] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 18.498755] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 18.498765] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
Version of L4T : R32.4.2
Could you please revert for this issue.
