HDMI display issue with JP5.1.3
I encountered an HDMI problem while using the Xavier NX with JP5.1.3. The display works normally with the JP4.x version, but once I flashed the Xavier NX with JP5.1.3, the display failed to work. I attempted to access it via the serial port or the onboard Micro USB, and I tried to check the logs to obtain error information related to the display. I would appreciate any help you can provide regarding this issue。
The logs of dmesg for reference:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.192-tegra (buildbrain@mobile-u64-6519-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon Feb 19 20:19:53 PST 2024
[    0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x2764e8a98 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x27b330000 MEMATTR=0x276403018 ESRT=0x276406818 RNG=0x269df0018 MEMRESERVE=0x26a76bf18
[    0.000000] random: crng init done
[    0.000000] esrt: Reserving ESRT space from 0x0000000276406818 to 0x0000000276406850.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000a0a73fff]
[    0.000000]   node   0: [mem 0x00000000a0a74000-0x00000000a0a75fff]
[    0.000000]   node   0: [mem 0x00000000a0a77000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c79fffff]
[    0.000000]   node   0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[    0.000000]   node   0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000026c91bfff]
[    0.000000]   node   0: [mem 0x000000026c91c000-0x000000026cd3bfff]
[    0.000000]   node   0: [mem 0x000000026cd3c000-0x000000027a21ffff]
[    0.000000]   node   0: [mem 0x000000027a220000-0x000000027c15ffff]
[    0.000000]   node   0: [mem 0x000000027c160000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[    0.000000] On node 0 totalpages: 1868463
[    0.000000]   DMA zone: 4619 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 295599 pages, LIFO batch:63
[    0.000000]   Normal zone: 24576 pages used for memmap
[    0.000000]   Normal zone: 1572864 pages, LIFO batch:63
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] pcpu-alloc: s90392 r8192 d32488 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1839268
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off nospectre_bhb nv-auto-config usbcore.autosuspend=1
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[    0.000000] Memory: 6918208K/7473852K available (18560K kernel code, 3168K rwdata, 7196K rodata, 3968K init, 1417K bss, 490108K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000786] Console: colour dummy device 80x25
[    0.001935] printk: console [tty0] enabled
[    0.002025] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.002078] pid_max: default: 32768 minimum: 301
[    0.002248] LSM: Security Framework initializing
[    0.002323] Yama: becoming mindful.
[    0.002379] SELinux:  Initializing.
[    0.002538] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002575] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.005742] rcu: Hierarchical SRCU implementation.
[    0.006027] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006751] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[    0.006854] DTB Build time: Feb 19 2024 20:32:39
[    0.009642] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[    0.009908] Remapping and enabling EFI services.
[    0.012319] smp: Bringing up secondary CPUs ...
[    0.041344] Detected PIPT I-cache on CPU1
[    0.041449] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.073846] Detected PIPT I-cache on CPU2
[    0.073947] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.103306] Detected PIPT I-cache on CPU3
[    0.103397] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.132842] Detected PIPT I-cache on CPU4
[    0.132939] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.162354] Detected PIPT I-cache on CPU5
[    0.162608] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.162988] smp: Brought up 1 node, 6 CPUs
[    0.163471] SMP: Total of 6 processors activated.
[    0.163509] CPU features: detected: Privileged Access Never
[    0.163536] CPU features: detected: LSE atomic instructions
[    0.163560] CPU features: detected: User Access Override
[    0.163585] CPU features: detected: 32-bit EL0 Support
[    0.163608] CPU features: detected: RAS Extension Support
[    0.163632] CPU features: detected: CRC32 instructions
[    0.163657] CPU features: detected: 32-bit EL1 Support
[    0.199919] spectre-bhb mitigation disabled by command line option
[    0.232288] CPU: All CPU(s) started at EL2
[    0.237655] devtmpfs: initialized
[    0.286677] Registered cp15_barrier emulation handler
[    0.286851] Registered setend emulation handler
[    0.286887] KASLR enabled
[    0.287147] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.287245] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.288553] pinctrl core: initialized pinctrl subsystem
[    0.290125] NET: Registered protocol family 16
[    0.292089] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.292638] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.293379] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.293467] audit: initializing netlink subsys (disabled)
[    0.293744] audit: type=2000 audit(0.288:1): state=initialized audit_enabled=0 res=1
[    0.294270] thermal_sys: Registered thermal governor 'step_wise'
[    0.294276] thermal_sys: Registered thermal governor 'power_allocator'
[    0.294303] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.296669] cpuidle: using governor menu
[    0.297007] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.297463] ASID allocator initialised with 32768 entries
[    0.297678] Serial: AMBA PL011 UART driver
[    0.300764] Tegra reboot handler registered.
[    0.375300] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[    0.375382] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[    0.375427] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[    0.375470] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[    0.375521] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[    0.375563] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[    0.375604] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[    0.375645] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[    0.375687] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[    0.375749] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[    0.375832] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[    0.375876] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[    0.375921] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[    0.375963] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[    0.376004] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[    0.376055] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[    0.376104] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[    0.376211] mc-err: mcerr ops are set to t19x
[    0.389263] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.389310] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.389340] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.389366] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.396107] ACPI: Interpreter disabled.
[    0.397221] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.398698] iommu: Default domain type: Translated
[    0.398812] eventlib_kernel: keventlib is initialized, test id: 0
[    0.399208] SCSI subsystem initialized
[    0.399387] usbcore: registered new interface driver usbfs
[    0.399438] usbcore: registered new interface driver hub
[    0.399483] usbcore: registered new device driver usb
[    0.399968] mc: Linux media interface: v0.10
[    0.400011] videodev: Linux video capture interface: v2.00
[    0.400326] pps_core: LinuxPPS API ver. 1 registered
[    0.400371] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.400421] PTP clock support registered
[    0.400637] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.401115] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.401265] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.402405] Registered efivars operations
[    0.411199] FPGA manager framework
[    0.411351] Advanced Linux Sound Architecture Driver Initialized.
[    0.412217] Bluetooth: Core ver 2.22
[    0.412276] NET: Registered protocol family 31
[    0.412298] Bluetooth: HCI device and connection manager initialized
[    0.412326] Bluetooth: HCI socket layer initialized
[    0.412353] Bluetooth: L2CAP socket layer initialized
[    0.412418] Bluetooth: SCO socket layer initialized
[    0.415284] camchar: rtcpu character device driver loaded
[    0.416633] clocksource: Switched to clocksource arch_sys_counter
[    0.830352] VFS: Disk quotas dquot_6.6.0
[    0.830485] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.831422] pnp: PnP ACPI: disabled
[    0.845054] la/ptsa driver initialized.
[    0.845278] NET: Registered protocol family 2
[    0.845517] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.853119] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.853288] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.853675] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.854313] TCP: Hash tables configured (established 65536 bind 65536)
[    0.854488] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.854620] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.854949] NET: Registered protocol family 1
[    0.855832] RPC: Registered named UNIX socket transport module.
[    0.855871] RPC: Registered udp transport module.
[    0.855892] RPC: Registered tcp transport module.
[    0.855912] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.855945] PCI: CLS 0 bytes, default 64
[    0.856206] Trying to unpack rootfs image as initramfs...
[    1.162440] Freeing initrd memory: 9548K
[    1.167870] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.168294] kvm [1]: IPA Size Limit: 40 bits
[    1.168869] kvm [1]: vgic interrupt IRQ9
[    1.169454] kvm [1]: VHE mode initialized successfully
[    1.170982] Initialise system trusted keyrings
[    1.171332] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.177402] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.178329] NFS: Registering the id_resolver key type
[    1.178364] Key type id_resolver registered
[    1.178380] Key type id_legacy registered
[    1.178495] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.178549] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.178596] ntfs: driver 2.1.32 [Flags: R/W].
[    1.189343] NET: Registered protocol family 38
[    1.189374] Key type asymmetric registered
[    1.189391] Asymmetric key parser 'x509' registered
[    1.189473] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    1.189755] io scheduler mq-deadline registered
[    1.189780] io scheduler kyber registered
[    1.199119] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.199199] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.199272] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.199342] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    1.199411] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.205746] scrncapt: init (heads:4 wins:6 planes:4)
[    1.205930] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    1.206889] EINJ: ACPI disabled.
[    1.210441] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    1.210468] tegra-pmc: ### PMC reset source: MAINSWRST
[    1.210484] tegra-pmc: ### PMC reset level: L1
[    1.210499] tegra-pmc: ### PMC reset status reg: 0x2d
[    1.210547] tegra-pmc: PMC Prod config success
[    1.215658] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.510627] printk: console [ttyTCU0] enabled
[    2.516796] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.521274] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.526158] arm-smmu 10000000.iommu:         stage 1 translation
[    2.531297] arm-smmu 10000000.iommu:         stage 2 translation
[    2.536672] arm-smmu 10000000.iommu:         nested translation
[    2.542446] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    2.549616] arm-smmu 10000000.iommu:         64 context banks (0 stage-2 only)
[    2.559710] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    2.562483] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.569134] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.576825] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.582163] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.586890] arm-smmu 12000000.iommu:         stage 1 translation
[    2.592141] arm-smmu 12000000.iommu:         stage 2 translation
[    2.597822] arm-smmu 12000000.iommu:         nested translation
[    2.602997] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    2.610201] arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
[    2.620201] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    2.623296] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    2.630113] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    2.637495] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.647649] tegra_profiler: version: 1.151, samples/io: 51/30
[    2.650561] tegra_profiler: auth: init
[    2.654934] THERMAL EST: found 3 subdevs
[    2.657954] THERMAL EST num_resources: 0
[    2.661795] [THERMAL EST subdev 0]
[    2.665151] [THERMAL EST subdev 1]
[    2.668787] [THERMAL EST subdev 2]
[    2.671781] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.678293] THERMAL EST: thz register success.
[    2.682482] THERMAL EST: end of probe, return err: 0
[    2.688042] nvsciipc: loaded module
[    2.695164] tun: Universal TUN/TAP device driver, 1.6
[    2.697628] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.703806] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.709127] e1000e: Intel(R) PRO/1000 Network Driver
[    2.714035] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.720394] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.725665] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.731879] PPP generic driver version 2.4.2
[    2.735811] PPP BSD Compression module registered
[    2.740385] PPP Deflate Compression module registered
[    2.745633] PPP MPPE Compression module registered
[    2.750910] usbcore: registered new interface driver r8152
[    2.756163] usbcore: registered new interface driver asix
[    2.761502] usbcore: registered new interface driver ax88179_178a
[    2.767877] usbcore: registered new interface driver cdc_ether
[    2.773826] usbcore: registered new interface driver net1080
[    2.779171] usbcore: registered new interface driver cdc_subset
[    2.785286] usbcore: registered new interface driver zaurus
[    2.790914] usbcore: registered new interface driver cdc_ncm
[    2.796582] usbcore: registered new interface driver aqc111
[    2.802244] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.808545] ohci-pci: OHCI PCI platform driver
[    2.812586] ohci-platform: OHCI generic platform driver
[    2.818611] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.825048] usbcore: registered new interface driver uas
[    2.829179] usbcore: registered new interface driver usb-storage
[    2.835032] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.841283] mousedev: PS/2 mouse device common for all mice
[    2.846035] usbcore: registered new interface driver xpad
[    2.854368] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.857040] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:26 UTC (26)
[    2.864819] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.871428] i2c /dev entries driver
[    2.874468] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    2.880269] tegra-i2c c240000.i2c: Adding to iommu group 2
[    2.885525] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    2.890955] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    2.896333] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    2.901825] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    2.907261] tegra-i2c c250000.i2c: Adding to iommu group 2
[    2.919612] pps pps0: new PPS source ktimer
[    2.919790] pps pps0: ktimer PPS source registered
[    2.921423] pps_ldisc: PPS line discipline registered
[    2.928568] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    2.934292] device-mapper: uevent: version 1.0.3
[    2.938602] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.949001] cpuidle: Initializing cpuidle driver
[    2.952740] sdhci: Secure Digital Host Controller Interface driver
[    2.957542] sdhci: Copyright(c) Pierre Ossman
[    2.962007] Synopsys Designware Multimedia Card Interface Driver
[    2.968459] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.974463] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    2.975046] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    2.987463] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    3.011105] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[    3.020884] vdd-1v0: supplied by regulator-dummy
[    3.026352] vdd-1v8-hs: supplied by regulator-dummy
[    3.031274] vdd-1v8-ls: supplied by regulator-dummy
[    3.036071] vdd-1v8-ao: supplied by regulator-dummy
[    3.040144] vddio-ddr-1v1: supplied by regulator-dummy
[    3.044608] vdd-rtc: supplied by regulator-dummy
[    3.046401] spmic-ldo1: supplied by regulator-dummy
[    3.047711] vdd-ao-3v3: supplied by regulator-dummy
[    3.053918] vddio-emmc-3v3: supplied by regulator-dummy
[    3.060284] spmic-ldo4: supplied by regulator-dummy
[    3.061480] vdd-usb-3v3: supplied by regulator-dummy
[    3.067651] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.073912] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.079440] spmic-ldo8: supplied by vdd-1v8-ls
[    3.080938] gpio-510 (gpio_default): hogged as output/high
[    3.082283] gpio-511 (gpio_default): hogged as output/high
[    3.085211] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.221233] max77686-rtc max77620-rtc: registered as rtc0
[    3.222577] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.222933] max77620 4-003c: max77620 probe successful
[    4.005678] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.007103] hid: raw HID events driver (C) Jiri Kosina
[    4.008018] usbcore: registered new interface driver usbhid
[    4.008182] usbhid: USB HID core driver
[    4.010563] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[    4.011903] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.096073] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.096623] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.097984] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.098887] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.100599] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.101356] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.102143] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.103911] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[    4.104229] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.106941] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=571b1d9f5b93980c19e16eaf250cfa6deac6f03e
[    4.112274] tegra_aon c1a0000.aon: Adding to iommu group 5
[    4.119166] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.123846] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.129938] denver_knobs_init:MTS_VERSION:72064061
[    4.142072] t19x_cache tegra-cache: probed
[    4.145224] optee: probing for conduit method.
[    4.146078] optee: revision 3.22 (e3b12903)
[    4.265040] optee: dynamic shared memory is enabled
[    4.266240] optee: initialized driver
[    4.270711] nvpmodel: initialized successfully
[    4.271340] tegra_hv: get_hvd: not initialized yet
[    4.271604] user_ivc_mempool: hypervisor not present
[    4.273142] usbcore: registered new interface driver snd-usb-audio
[    4.274589] u32 classifier
[    4.274745]     input device check on
[    4.274944]     Actions configured
[    4.275435] Initializing XFRM netlink socket
[    4.276378] NET: Registered protocol family 10
[    4.280134] Segment Routing with IPv6
[    4.280415] NET: Registered protocol family 17
[    4.280601] NET: Registered protocol family 15
[    4.280959] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.281984] Bluetooth: RFCOMM socket layer initialized
[    4.282284] Bluetooth: RFCOMM ver 1.11
[    4.282458] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.282709] Bluetooth: HIDP socket layer initialized
[    4.283652] 9pnet: Installing 9P2000 support
[    4.283917] Key type dns_resolver registered
[    4.285455] registered taskstats version 1
[    4.285669] Loading compiled-in X.509 certificates
[    4.322247] Loaded X.509 cert 'Build time autogenerated kernel key: d4a16382d2d8ce9df91e7e6b52beaf43d53de57f'
[    4.324156] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[    4.329715] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.330057] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.330372] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.330684] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    5.445594] tegra194-pcie 14160000.pcie: Phy link never came up
[    5.446358] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    5.446581] pci_bus 0004:00: root bus resource [bus 00-ff]
[    5.446766] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    5.447032] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    5.447204] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    5.447579] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    5.447982] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    5.464075] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    5.464428] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    5.466404] pcieport 0004:00:00.0: Adding to iommu group 6
[    5.467729] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    5.469464] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    5.470823] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    5.471682] pci 0004:00:00.0: Removing from iommu group 6
[    5.472024] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    5.476068] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[    5.482253] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    5.482760] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    5.483057] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    5.490964] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    6.609820] tegra194-pcie 141a0000.pcie: Phy link never came up
[    6.610547] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    6.610745] pci_bus 0005:00: root bus resource [bus 00-ff]
[    6.610945] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    6.611177] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    6.611408] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    6.611770] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    6.612162] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    6.629671] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    6.630107] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    6.631841] pcieport 0005:00:00.0: Adding to iommu group 7
[    6.633366] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[    6.635124] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[    6.636580] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    6.637645] pci 0005:00:00.0: Removing from iommu group 7
[    6.637944] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    6.667653] host1x 13e10000.host1x: Adding to iommu group 8
[    6.691337] host1x 13e10000.host1x: initialized
[    6.693009] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[    6.694002] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.695158] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[    6.695922] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.697044] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[    6.697694] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.698655] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[    6.699236] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.703195] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[    6.709973] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.719638] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[    6.726673] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    6.736937] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[    6.743893] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    6.753748] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[    6.760955] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    6.770863] falcon 15340000.vic: Adding to iommu group 17
[    6.784880] falcon 15340000.vic: initialized
[    6.785788] falcon 15380000.nvjpg: Adding to iommu group 17
[    6.791638] falcon 15380000.nvjpg: initialized
[    6.792223] falcon 154c0000.nvenc: Adding to iommu group 17
[    6.804096] falcon 154c0000.nvenc: initialized
[    6.804781] falcon 15a80000.nvenc1: Adding to iommu group 17
[    6.813836] falcon 15a80000.nvenc1: initialized
[    6.814502] nvdec 15480000.nvdec: Adding to iommu group 17
[    6.825813] nvdec 15480000.nvdec: initialized
[    6.826303] nvdec 15140000.nvdec1: Adding to iommu group 17
[    6.834796] nvdec 15140000.nvdec1: initialized
[    6.835329] tsec 15500000.tsec: Adding to iommu group 18
[    6.842021] tsec 15500000.tsec: initialized
[    6.842479] tsec 15100000.tsecb: Adding to iommu group 19
[    6.851101] tsec 15100000.tsecb: initialized
[    6.856578] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.881452] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.894230] gpio-374 (wifi-enable): hogged as output/high
[    6.894550] gpio-431 (camera-control-output-low): hogged as output/low
[    6.894819] gpio-432 (camera-control-output-low): hogged as output/low
[    6.896554] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    6.898434] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    6.899039] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.902058] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    6.907592] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.913362] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[    6.918763] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    6.926806] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    6.934583] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[    6.945527] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.950864] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    6.956816] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.965963] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    6.974929] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[    6.981755] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    6.989752] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    6.996046] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    7.005889] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    7.012249] pva 16000000.pva0: Adding to iommu group 22
[    7.037724] pva 16000000.pva0: initialized
[    7.042909] pva 16800000.pva1: Adding to iommu group 23
[    7.053809] pva 16800000.pva1: initialized
[    7.058996] nvdla 15880000.nvdla0: Adding to iommu group 24
[    7.071257] nvdla 15880000.nvdla0: initialized
[    7.072810] nvdla 158c0000.nvdla1: Adding to iommu group 25
[    7.088583] nvdla 158c0000.nvdla1: initialized
[    7.092895] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[    7.092985] tegradccommon 15200000.display-hub: host1x channel mapped
[    7.093175] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    7.093371] tegradc 15200000.display: Adding to iommu group 26
[    7.093427] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    7.093532] tegradccommon 15200000.display-hub: dma mapping done
[    7.094889] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    7.095912] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    7.101956] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    7.102161] tegradc 15210000.display: Adding to iommu group 26
[    7.102402] tegradc 15200000.display: disp0 connected to head0->sor1
[    7.102629] generic_infoframe_type: 0x87
[    7.102784] tegradc 15200000.display: DT parsed successfully
[    7.102875] tegradc 15200000.display: Display dc.00000000d4978e38 registered with id=0
[    7.107197] tegra_cec 3960000.tegra_cec: probed
[    7.129245] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    7.138476] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    7.142103] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    7.142110] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    7.156216] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    7.166437] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    7.172477] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    7.185577] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[    7.191687] kfuse 3830000.kfuse: initialized
[    7.203155] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[    7.203867] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.211534] tegradc 15210000.display: disp0 connected to head1->sor
[    7.215739] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.216577] serial-tegra 3100000.serial: Adding to iommu group 2
[    7.222307] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.229561] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[    7.235029] tegradc 15210000.display: DT parsed successfully
[    7.243833] serial-tegra 3110000.serial: Adding to iommu group 2
[    7.250999] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    7.270850] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[    7.281024] serial-tegra 3140000.serial: Adding to iommu group 2
[    7.285337] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[    7.304769] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    7.305162] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.309033] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.317167] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    7.325586] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[    7.331927] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.337144] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.344505] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.352194] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.360144] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.367502] usb usb1: Product: xHCI Host Controller
[    7.372059] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.378536] usb usb1: SerialNumber: 3610000.xhci
[    7.384483] hub 1-0:1.0: USB hub found
[    7.387322] hub 1-0:1.0: 4 ports detected
[    7.392172] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.399359] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.406597] usb usb2: Product: xHCI Host Controller
[    7.411833] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.418112] usb usb2: SerialNumber: 3610000.xhci
[    7.423951] hub 2-0:1.0: USB hub found
[    7.426671] hub 2-0:1.0: 4 ports detected
[    7.471565] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    7.479505] i2c i2c-2: Added multiplexed i2c bus 9
[    7.481440] i2c i2c-2: Added multiplexed i2c bus 10
[    7.481681] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    7.496092] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1906000 KHz, changing to: 1907200 KHz
[    7.497179] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[    7.498373] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    7.499116] irq: IRQ261: trimming hierarchy from :pmc@c360000
[    7.501233] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    7.509237] tegra194-vi5 15c10000.vi: initialized
[    7.510566] tegradc 15200000.display: disp0 connected to head0->sor1
[    7.510810] generic_infoframe_type: 0x87
[    7.510989] tegradc 15200000.display: DT parsed successfully
[    7.511260] tegradc 15200000.display: Display dc.00000000b41fbff7 registered with id=0
[    7.512152] nvethernet 2490000.ethernet: Adding to iommu group 27
[    7.517255] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    7.523223] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    7.531395] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[    7.539428] nvethernet 2490000.ethernet: failed to read MDIO address
[    7.547646] mmc0: CQHCI version 5.10
[    7.547678] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[    7.548113] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    7.548120] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[    7.549715] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    7.549722] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    7.554208] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    7.583693] Reserved SVD code 0
[    7.585520] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    7.585533] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    7.586587] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    7.595678] tegradc 15200000.display: probed
[    7.599631] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[    7.599643] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[    7.644896] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[    7.654056] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[    7.654318] Console: switching to colour frame buffer device 160x45
[    7.656692] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    7.662628] tegradc 15200000.display: fb registered
[    7.672972] mmc0: Command Queue Engine enabled
[    7.675966] irq: IRQ262: trimming hierarchy from :pmc@c360000
[    7.680636] mmc0: periodic cache flush enabled
[    7.680653] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    7.686459] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    7.691352] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    7.695564] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    7.702054] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (509:0)
[    7.743132]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[    7.804640] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    7.804807] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[    7.819603] usb 1-2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice=90.23
[    7.819809] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.820005] usb 1-2: Product: USB2.0 Hub
[    7.820160] usb 1-2: Manufacturer: VIA Labs, Inc.
[    7.821718] hub 1-2:1.0: USB hub found
[    7.822016] hub 1-2:1.0: 4 ports detected
[    7.856643] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    7.856802] tegradc 15200000.display: timeout waiting for win assignments to promote
[    7.856970] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[    7.857254] tegradc 15210000.display: disp1 connected to head1->sor
[    7.857484] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    7.857846] tegradc 15210000.display: DT parsed successfully
[    7.858019] tegradc 15210000.display: Display dc.0000000060122690 registered with id=1
[    7.858355] tegradc 15210000.display: vblank syncpt # 13 for dc 1
[    7.858513] tegradc 15210000.display: vpulse3 syncpt # 14 for dc 1
[    7.865863] tegradc 15210000.display: probed
[    7.866258] tegradc 15210000.display: fb registered
[    7.869766] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    7.869971] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    7.871803] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    7.877336] tegradc 15210000.display: blank - powerdown
[    7.882844] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    7.891173] Extcon DP: HPD disabled
[    7.892783] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    7.894570] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    7.901159] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    7.907865] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    7.914653] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    7.920460] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    7.935628] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:76:36:32
[    7.942539] -->macsec_probe()
[    7.942547] <--macsec_probe()
[    7.942555] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[    7.949877] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    7.957560] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[    7.958753] irq: IRQ264: trimming hierarchy from :pmc@c360000
[    7.970128] irq: IRQ265: trimming hierarchy from :interrupt-controller@3881000
[    7.977567] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.985560] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[    7.990702] usb 2-3: New USB device found, idVendor=2109, idProduct=0817, bcdDevice=90.23
[    7.991679] tegra-se-nvhost 15810000.se: initialized
[    7.998605] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.998610] usb 2-3: Product: USB3.0 Hub
[    7.998615] usb 2-3: Manufacturer: VIA Labs, Inc.
[    8.023044] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    8.027756] hub 2-3:1.0: USB hub found
[    8.028097] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[    8.037725] hub 2-3:1.0: 4 ports detected
[    8.037877] Reserved SVD code 0
[    8.038375] tegra-se-nvhost 15820000.se: initialized
[    8.040193] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    8.040746] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[    8.041391] tegra-se-nvhost 15830000.se: initialized
[    8.042521] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    8.073401] tegradc 15200000.display: blank - powerdown
[    8.073833] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[    8.074528] tegra-se-nvhost 15840000.se: initialized
[    8.076314] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    8.077905] tegra_actmon d230000.actmon: in actmon_register()...
[    8.078082] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    8.078631] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    8.079163] hvc_sysfs: hypervisor is not present
[    8.079633] tegradc 15200000.display: unblank
[    8.105961] ALSA device list:
[    8.105967]   No soundcards found.
[    8.128694] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    8.128700] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    8.160646] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    8.160651] tegradc 15200000.display: dc timeout waiting for DC to stop
[    8.212633] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    8.212638] tegradc 15200000.display: dc timeout waiting for DC to stop
[    8.264634] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    8.264639] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[    8.316636] tegradc 15200000.display: dc_poll_register 0x41: timeout
[    8.316642] tegradc 15200000.display: timeout waiting for win assignments to promote
[    8.316646] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[    8.316667] tegradc 15200000.display: update windows ret = -14
[    8.316671] tegradc 15200000.display: sync windows ret = -14
[    8.371400] extcon-disp-state external-connection:disp-state: cable 53 state 1
[    8.372248] Freeing unused kernel memory: 3968K
[    8.378488] Extcon HDMI: HPD enabled
[    8.378501] tegradc 15200000.display: hdmi: plugged
[    8.383453] Run /init as init process
[    8.395431]   with arguments:
[    8.395440]     /init
[    8.395445]     nv-auto-config
[    8.395449]   with environment:
[    8.395453]     HOME=/
[    8.395456]     TERM=linux
[    8.451704] Root device found: mmcblk0p1
[    8.476422] Found dev node: /dev/mmcblk0p1
[    8.512743] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    8.521960] Rootfs mounted over mmcblk0p1
[    8.551015] Switching from initrd to actual rootfs
[    8.696577] systemd[1]: System time before build time, advancing clock.
[    9.067997] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    9.072199] systemd[1]: Detected architecture arm64.
[    9.107326] systemd[1]: Set hostname to <ubuntu>.
[    9.786514] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.788047] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.793459] systemd[1]: Created slice system-modprobe.slice.
[    9.797511] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.800783] systemd[1]: Created slice User and Session Slice.
[    9.803326] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    9.806790] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.809404] systemd[1]: Reached target User and Group Name Lookups.
[    9.811699] systemd[1]: Reached target Slices.
[    9.813923] systemd[1]: Reached target Mounting snaps.
[    9.816173] systemd[1]: Reached target Mounted snaps.
[    9.818450] systemd[1]: Reached target Swap.
[    9.821659] systemd[1]: Listening on RPCbind Server Activation Socket.
[    9.824467] systemd[1]: Listening on Syslog Socket.
[    9.827279] systemd[1]: Listening on fsck to fsckd communication Socket.
[    9.829911] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    9.833348] systemd[1]: Listening on Journal Audit Socket.
[    9.836139] systemd[1]: Listening on Journal Socket (/dev/log).
[    9.839093] systemd[1]: Listening on Journal Socket.
[    9.841946] systemd[1]: Listening on udev Control Socket.
[    9.844494] systemd[1]: Listening on udev Kernel Socket.
[    9.852091] systemd[1]: Mounting Huge Pages File System...
[    9.859728] systemd[1]: Mounting POSIX Message Queue File System...
[    9.866939] systemd[1]: Mounting RPC Pipe File System...
[    9.874769] systemd[1]: Mounting Kernel Debug File System...
[    9.882190] systemd[1]: Mounting Kernel Trace File System...
[    9.891364] systemd[1]: Starting Journal Service...
[    9.899361] systemd[1]: Starting Set the console keyboard layout...
[    9.906735] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    9.913959] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[    9.916413] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    9.922702] systemd[1]: Starting Load Kernel Module efi_pstore...
[    9.930747] systemd[1]: Starting Load Kernel Module pstore_blk...
[    9.935802] tegra-xusb 3610000.xhci: entering ELPG done
[    9.940245] systemd[1]: Starting Load Kernel Module pstore_zone...
[    9.948495] systemd[1]: Starting Load Kernel Module ramoops...
[    9.955978] systemd[1]: Starting NVIDIA specific first-boot udev script...
[    9.967122] systemd[1]: Started Nameserver information manager.
[    9.977568] systemd[1]: Reached target Network (Pre).
[    9.993294] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.995401] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.005325] systemd[1]: Starting Load Kernel Modules...
[   10.012040] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.018866] systemd[1]: Starting udev Coldplug all Devices...
[   10.053621] systemd[1]: Mounted Huge Pages File System.
[   10.063242] systemd[1]: Mounted POSIX Message Queue File System.
[   10.070987] systemd[1]: Mounted RPC Pipe File System.
[   10.074192] systemd[1]: Mounted Kernel Debug File System.
[   10.077034] systemd[1]: Mounted Kernel Trace File System.
[   10.086634] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   10.087923] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   10.102372] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   10.104949] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[   10.105592] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[   10.106112] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   10.106128] nvmap_page_pool_init: Total RAM pages: 1749315
[   10.110151] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   10.110246] nvmap_page_pool_init: nvmap page pool size: 218664 pages (854 MB)
[   10.112671] nvmap_background_zero_thread: PP zeroing thread starting.
[   10.112853] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[   10.113032] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[   10.113039] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[   10.121494] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[   10.126610] systemd[1]: Finished Load Kernel Module efi_pstore.
[   10.130799] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[   10.134318] systemd[1]: Finished Load Kernel Module pstore_blk.
[   10.139432] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[   10.143272] systemd[1]: Finished Load Kernel Module pstore_zone.
[   10.147275] systemd[1]: modprobe@ramoops.service: Succeeded.
[   10.151556] systemd[1]: Finished Load Kernel Module ramoops.
[   10.155323] systemd[1]: nvfb-udev.service: Succeeded.
[   10.165032] systemd[1]: Finished NVIDIA specific first-boot udev script.
[   10.174328] systemd[1]: Finished Remount Root and Kernel File Systems.
[   10.187267] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.189581] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   10.197363] systemd[1]: Starting Load/Save Random Seed...
[   10.205239] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[   10.206565] systemd[1]: Starting Create System Users...
[   10.215407] systemd[1]: Finished Set the console keyboard layout.
[   10.259845] systemd[1]: Finished Load Kernel Modules.
[   10.264792] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.277523] systemd[1]: Mounting Kernel Configuration File System...
[   10.285041] systemd[1]: Started OP-TEE Client Supplicant.
[   10.292719] systemd[1]: Starting Apply Kernel Variables...
[   10.302825] systemd[1]: Finished Load/Save Random Seed.
[   10.306201] systemd[1]: Mounted Kernel Configuration File System.
[   10.331858] systemd[1]: Finished Create System Users.
[   10.340137] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.360872] systemd[1]: Finished Apply Kernel Variables.
[   10.424405] systemd[1]: Finished Create Static Device Nodes in /dev.
[   10.427223] systemd[1]: Reached target Local File Systems (Pre).
[   10.428371] systemd[1]: Reached target Local File Systems.
[   10.429725] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[   10.434659] systemd[1]: Starting Enable support for additional executable binary formats...
[   10.440774] systemd[1]: Starting Set console font and keymap...
[   10.446453] systemd[1]: Starting Preprocess NFS configuration...
[   10.453524] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.454753] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[   10.455049] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.455329] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.459510] systemd[1]: Starting udev Kernel Device Manager...
[   10.462109] systemd[1]: Started Journal Service.
[   10.573368] systemd-journald[263]: Received client request to flush runtime journal.
[   11.693756] spi-tegra114 3210000.spi: Adding to iommu group 2
[   11.696065] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[   11.704523] spi-tegra114 3230000.spi: Adding to iommu group 2
[   11.710560] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.734075] imx219 9-0010: board setup failed
[   11.734171] imx219: probe of 9-0010 failed with error -121
[   11.734536] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[   11.754159] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   11.760893] imx219 10-0010: board setup failed
[   11.760988] imx219: probe of 10-0010 failed with error -121
[   11.855514] tegra-hda 3510000.hda: Adding to iommu group 32
[   11.857268] tegra-hda 3510000.hda: Override SDO lines to 4
[   11.878459] nvadsp 2993000.adsp: Adding to iommu group 33
[   11.878713] nvadsp 2993000.adsp: in probe()...
[   11.879476] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   11.890615] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   11.897775] cpu-throttle-alert cooling device registered.
[   11.899539] gpu-throttle-alert cooling device registered.
[   11.900190] aux-throttle-alert cooling device registered.
[   11.901244] hot-surface-alert cooling device registered.
[   11.952305] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   11.960009] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   11.960270] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   11.966591] input: NVIDIA Jetson Xavier NX HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   11.998093] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 33
[   11.998152] tegra210_adsp_audio_probe: platform probe started
[   12.028550] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   12.029626] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   12.030623] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   12.031597] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   12.032566] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   12.033565] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   12.033575] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   12.033579] tegra210-adsp tegra210-adsp: using adma channel page 0
[   12.033708] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   12.095375] tegra-asoc: sound: Adding to iommu group 33
[   12.372746] cryptd: max_cpu_qlen set to 1000
[   12.385292] tegra210-adsp tegra210-adsp: Loaded app wire
[   12.385307] tegra210-adsp tegra210-adsp: Loaded app apm
[   12.385313] tegra210-adsp tegra210-adsp: Loaded app adma
[   12.385319] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   12.385327] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000080c9b059
[   12.404879] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   12.847606] using random self ethernet address
[   12.849106] using random host ethernet address
[   13.121512] loop: module loaded
[   13.938130] Mass Storage Function, version: 2009/09/11
[   13.938144] LUN: removable file: (no medium)
[   13.975558] using random self ethernet address
[   13.977018] using random host ethernet address
[   14.047500] rndis0: HOST MAC d6:5c:cf:6b:8c:bc
[   14.047524] rndis0: MAC d6:5c:cf:6b:8c:bd
[   14.053431] usb0: HOST MAC d6:5c:cf:6b:8c:be
[   14.053451] usb0: MAC d6:5c:cf:6b:8c:bf
[   14.053497] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[   14.090956] l4tbr0: port 1(rndis0) entered blocking state
[   14.091055] l4tbr0: port 1(rndis0) entered disabled state
[   14.096203] device rndis0 entered promiscuous mode
[   14.130302] l4tbr0: port 2(usb0) entered blocking state
[   14.130346] l4tbr0: port 2(usb0) entered disabled state
[   14.133768] device usb0 entered promiscuous mode
[   14.528991] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[   14.529011] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[   14.529025] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[   14.529136] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[   14.529150] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[   14.529163] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[   14.529194] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[   14.529390] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[   14.529409] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[   14.532775] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[   14.532807] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[   14.534298] tegra-xudc 3550000.xudc: ep 13 disabled
[   14.534388] tegra-xudc 3550000.xudc: ep 8 disabled
[   14.551851] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[   14.551870] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[   14.708493] irq: IRQ267: trimming hierarchy from :interrupt-controller@3881000
[   14.781129] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[   14.781299] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[   15.112656] pstore: Using crash dump compression: deflate
[   15.114125] printk: console [ramoops-1] enabled
[   15.114154] pstore: Registered ramoops as persistent store backend
[   15.114183] ramoops: using 0x200000@0xc8200000, ecc: 0
[   15.197897] CPU4: shutdown
[   15.198976] psci: CPU4 killed (polled 0 ms)
[   15.257886] CPU5: shutdown
[   15.258767] psci: CPU5 killed (polled 0 ms)
[   15.341814] nvgpu: 17000000.gv11b                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   16.030139] zram: Added device: zram0
[   16.032488] zram: Added device: zram1
[   16.034046] zram: Added device: zram2
[   16.034594] zram: Added device: zram3
[   16.239536] zram0: detected capacity change from 0 to 895651840
[   16.284856] Adding 874656k swap on /dev/zram0.  Priority:5 extents:1 across:874656k SS
[   16.289504] zram1: detected capacity change from 0 to 895651840
[   16.328796] Adding 874656k swap on /dev/zram1.  Priority:5 extents:1 across:874656k SS
[   16.332770] zram2: detected capacity change from 0 to 895651840
[   16.372798] Adding 874656k swap on /dev/zram2.  Priority:5 extents:1 across:874656k SS
[   16.374865] zram3: detected capacity change from 0 to 895651840
[   16.424735] Adding 874656k swap on /dev/zram3.  Priority:5 extents:1 across:874656k SS
[   22.302201] l4tbr0: port 2(usb0) entered blocking state
[   22.302219] l4tbr0: port 2(usb0) entered forwarding state
[   22.302312] l4tbr0: port 1(rndis0) entered blocking state
[   22.302322] l4tbr0: port 1(rndis0) entered forwarding state
[   22.308735] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   23.633556] fuse: init (API version 7.32)
[   23.640388] tegradc 15200000.display: blank - powerdown
[   23.640438] tegradc 15200000.display: unblank
[   23.692662] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.692670] tegradc 15200000.display: dc timeout waiting for DC to stop
[   23.744727] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.744734] tegradc 15200000.display: dc timeout waiting for DC to stop
[   23.796697] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.796708] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[   23.848697] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.848708] tegradc 15200000.display: timeout waiting for win assignments to promote
[   23.848713] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[   23.850395] tegradc 15200000.display: unblank
[   23.900784] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.900792] tegradc 15200000.display: dc timeout waiting for DC to stop
[   23.952676] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   23.952683] tegradc 15200000.display: dc timeout waiting for DC to stop
[   24.007975] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   24.007986] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[   24.056657] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   24.056667] tegradc 15200000.display: timeout waiting for win assignments to promote
[   24.056672] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[   24.058319] tegradc 15210000.display: blank - powerdown
[   24.246842] nvidia: loading out-of-tree module taints kernel.
[   24.263006] NVRM: No NVIDIA GPU found.
[   26.102397] tegradc 15200000.display: blank - powerdown
[   26.102441] tegradc 15200000.display: unblank
[   26.152643] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.152649] tegradc 15200000.display: dc timeout waiting for DC to stop
[   26.204645] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.204651] tegradc 15200000.display: dc timeout waiting for DC to stop
[   26.256636] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.256644] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[   26.308644] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.308651] tegradc 15200000.display: timeout waiting for win assignments to promote
[   26.308656] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[   26.310307] tegradc 15200000.display: unblank
[   26.360642] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.360648] tegradc 15200000.display: dc timeout waiting for DC to stop
[   26.412649] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.412656] tegradc 15200000.display: dc timeout waiting for DC to stop
[   26.464660] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.464669] tegradc 15200000.display: timeout waiting for postcomp init state to promote
[   26.516653] tegradc 15200000.display: dc_poll_register 0x41: timeout
[   26.516662] tegradc 15200000.display: timeout waiting for win assignments to promote
[   26.516667] tegradc 15200000.display: tegra_nvdisp_head_enable, failed head enable
[   26.518219] tegradc 15210000.display: blank - powerdown
[   39.904715] vdd-1v8-sd: disabling
[   39.904729] vdd-3v3-cvb: disabling
[   39.904768] vdd-1v8-cvb: disabling
[   39.904776] vdd-epb-1v0: disabling
[   39.904783] vdd-fan: disabling
[   39.904791] vdd_sys_en: disabling
[  340.415400] tegradc 15200000.display: blank - powerdown
[  340.415422] tegradc 15210000.display: blank - powerdown
[  949.901476] tegra-xudc 3550000.xudc: ep 3 disabled
[  949.901512] tegra-xudc 3550000.xudc: ep 2 disabled
[  949.901533] tegra-xudc 3550000.xudc: ep 5 disabled
[  949.901579] tegra-xudc 3550000.xudc: ep 4 disabled
[  949.901597] tegra-xudc 3550000.xudc: ep 7 disabled
[  949.901643] tegra-xudc 3550000.xudc: ep 9 disabled
[  949.901671] tegra-xudc 3550000.xudc: ep 13 disabled
[  949.901691] tegra-xudc 3550000.xudc: ep 8 disabled
[  949.901731] tegra-xudc 3550000.xudc: ep 15 disabled
[  949.901786] tegra-xudc 3550000.xudc: ep 11 disabled
[  949.901810] tegra-xudc 3550000.xudc: ep 6 disabled
[  949.902416] l4tbr0: port 1(rndis0) entered disabled state
[  949.912843] l4tbr0: port 2(usb0) entered disabled state
[  949.988449] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[  949.988474] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[  949.988492] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[  949.988647] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[  949.988665] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[  949.988681] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[  949.988713] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[  949.988772] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[  949.988798] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[  949.989244] l4tbr0: port 1(rndis0) entered blocking state
[  949.989259] l4tbr0: port 1(rndis0) entered forwarding state
[  951.260298] tegra-xudc 3550000.xudc: setup request failed: -22
[  951.261462] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[  951.261484] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[  951.261796] l4tbr0: port 2(usb0) entered blocking state
[  951.261810] l4tbr0: port 2(usb0) entered forwarding state
Known issue. Patch is over here.
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/SD/Kernel/DisplayConfigurationAndBringUp/XavierDisplayconfig.html?highlight=seamless#bypassing-the-seamless-display-issue
