HDMI display not working with DELL
I have my own custom board, I am able to bring up but display not working with DELL monitor. When I connect with VU tv I can see display but with lots of flickering.
Here is my schematic and kernel log when I plug hdmi :
Schematic:
[ 106.124655] edid invalid
[ 106.268200] edid invalid
[ 106.403059] tegradc 15200000.display: blank - powerdown
[ 106.403979] tegradc 15200000.display: unblank
[ 106.407909] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 106.408459] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 106.425429] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 106.427269] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 106.431269] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 106.431276] Extcon AUX1(HDMI) enable
[ 106.444066] tegradc 15200000.display: sync windows ret = 247
[ 106.444153] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 106.444159] Extcon HDMI: HPD enabled
[ 106.444166] tegradc 15200000.display: hdmi: plugged
[ 106.447838] tegradc 15200000.display: blank - powerdown
[ 106.510945] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 106.510951] Extcon AUX1(HDMI) disable
[ 106.534885] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 106.535980] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 106.536095] tegradc 15210000.display: blank - powerdown
[ 106.581936] tegradc 15200000.display: blank - powerdown
[ 106.581966] tegradc 15200000.display: unblank
[ 106.583381] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 106.583587] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 106.589809] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 106.591421] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 106.595535] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 106.595541] Extcon AUX1(HDMI) enable
[ 106.595609] tegradc 15200000.display: unblank
[ 106.595637] tegradc 15210000.display: blank - powerdown
I have tried with Samsung old monitor and it works. Looking forward your help to fix the issue with Dell monitor.
Sujit
please attach your full log. Not only partial log.
Thanks your quick reply. Attaching my full kernel log.
kernel_log.txt (64.4 KB)
Do you have a 3rd monitor that can validate ?
Also, is this hardware ever tested on rel-32 before?
I tried multiple dell monitor but no luck.
I also tried with HP which says set resolution to 1920x1200.
rel-32 ?? I didn’t understand what you mean.
Jetpack5.x is based on rel-35 software release.
Jetpack4.x is based on rel-32 software release.
Also, do you have NV devkit on your side which can check the monitor compatibility too?
I am using jetpack 5.1
No we don’t have NV devkit but we tried with AUVIDEA and monitor is working.
Yes, I know. I can tell it by reading your log. That is why I asked does this carrier board ever get tested on rel-32 .
Then your hardware may still have problem. Please check if lane 0 and lane 2 are reversed connected or not.
No, we have never tested on rel-32.
No its not reverse connected
could you share the full schematic with where that HDMI_TX0_P/N goes to?
Please refer to our design guide document. The lane 0 and lane 2 have to be reversed connected for HDMI.
Can you point which dtsi and where to change it.
I am referring tegra194-p3509-disp.dtsi & tegra194-hdmi.dtsi. I am not seeing any pin control.
Are you able to change your hardware design?
Hi Wayne,
I did small rework with my board, now I have made lane 0 and lane 2 reversed connected. With this changes I am able to get display working with Dell monitor.
Appreciate your quick response and help.
Thanks,
Sujit
