hdmi does not work
Hi, We use our own carrier board ,however hdmi does not work,pls help for us
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x116e5
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.374] Csd NumOfBlocks=30703616
[0000.379] Set High speed to 1
[0000.384] Using GPT Primary to query partitions
[0000.389] Loading Tboot-CPU binary
[0000.402] Verifying TBC in OdmNonSecureSBK mode
[0000.412] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.419] Bootloader downloaded successfully.
[0000.423] Downloaded Tboot-CPU binary to 0xa0000258
[0000.428] MAX77620_GPIO5 configured
[0000.431] CPU power rail is up
[0000.434] CPU clock enabled
[0000.438] Performing RAM repair
[0000.441] Updating A64 Warmreset Address to 0xa00002e9
[0000.446] Loading NvTbootBootloaderDTB
[0000.481] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.546] Bootloader DTB Load Address: 0x83000000
[0000.551] Loading NvTbootKernelDTB
[0000.586] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.651] Kernel DTB Load Address: 0x83100000
[0000.656] Loading cboot binary
[0000.700] Verifying EBT in OdmNonSecureSBK mode
[0000.742] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.749] Bootloader downloaded successfully.
[0000.753] Next binary entry address: 0x92c00258
[0000.758] BoardId: 3448
[0000.762] Overriding pmu board id with proc board id
[0000.767] Display board id is not available
[0000.808] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.860] /bpmp deleted
[0000.862] SC7EntryFw header found loaded at 0xff700000
[0001.051] OVR2 PMIC
[0001.053] Bpmp FW successfully loaded
[0001.057] WB0 init successfully at 0xff780000
[0001.061] Set NvDecSticky Bits
[0001.065] GSC2 address ff53fffc value c0edbbcc
[0001.071] GSC MC Settings done
[0001.074] TOS Image length 53680
[0001.077] Monitor size 53680
[0001.080] OS size 0
[0001.089] Secure Os AES-CMAC Verification Success!
[0001.093] TOS image cipher info: plaintext
[0001.097] Loading and Validation of Secure OS Successful
[0001.113] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.118] NvTbootPackSdramParams: start.
[0001.123] NvTbootPackSdramParams: done.
[0001.126] Tegraboot started after 53760 us
[0001.130] Basic modules init took 736821 us
[0001.134] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.140] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.146] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.152] Storage Device Read Time = 162 ms, Read Size = 2226 KB
[0001.158] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.163] Next stage binary read took 37512 us
[0001.167] Carveout took -49172 us
[0001.171] CPU initialization took 374953 us
[0001.175] Total time taken by TegraBoot 1100114 us
[0001.179] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 21:10:01, Aug 12 2019
ERROR: Error initializing runtime service trusty_fast
[0001.302] RamCode = 0
[0001.306] LPDDR4 Training: Read DT: Number of tables = 2
[0001.311] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.324] EMC Training Successful
[0001.327] 408000 not found in DVFS table
[0001.334] RamCode = 0
[0001.337] DT Write: emc-table@204000 succeeded
[0001.342] DT Write: emc-table@1600000 succeeded
[0001.347] LPDDR4 Training: Write DT: Number of tables = 2
[0001.388]
[0001.389] Debug Init done
[0001.392] Marked DTB cacheable
[0001.395] Bootloader DTB loaded at 0x83000000
[0001.399] Marked DTB cacheable
[0001.402] Kernel DTB loaded at 0x83100000
[0001.406] DeviceTree Init done
[0001.418] Pinmux applied successfully
[0001.422] gicd_base: 0x50041000
[0001.426] gicc_base: 0x50042000
[0001.429] Interrupts Init done
[0001.433] Using base:0x60005090 & irq:208 for tick-timer
[0001.438] Using base:0x60005098 for delay-timer
[0001.442] platform_init_timer: DONE
[0001.446] Timer(tick) Init done
[0001.449] osc freq = 38400 khz
[0001.454]
[0001.455] welcome to cboot
[0001.457]
[0001.458] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.463] calling constructors
[0001.466] initializing heap
[0001.469] initializing threads
[0001.472] initializing timers
[0001.475] creating bootstrap completion thread
[0001.479] top of bootstrap2()
[0001.482] CPU: ARM Cortex A57
[0001.485] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.490] initializing platform
[0001.493] Scratch reg 37 & 271 initial value set…
[0001.499] cboot:secure-pmc present
[0001.503] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.507] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.511] Macronix QSPI chip present
[0001.515] SPI device register
[0001.518] init boot device
[0001.520] allocating memory for boot device(SPI)
[0001.525] registering boot device
[0001.535] sdmmc node status = okay
[0001.538] sdcard instance = 0
[0001.541] sdcard gpio handle 0x56
[0001.544] sdcard gpio pin 0xc9
[0001.547] sdcard gpio flags 0x0
[0001.550] vmmc-supply 0x99
[0001.552] Instance: 0
[0001.555] Allocating memory for context
[0001.558] enabling clock
[0001.561] sd card init
[0001.563] Check card present and stable
[0001.567] Send command 0
[0001.583] Send command 3
[0001.588] Set RCA for the card
[0001.590] Query card specific data by command 9
[0001.597] Parse CSD data
[0001.599] Send command 7
[0001.610] Calling sd device register
[0001.613] Init sdcard
[0001.615] Allocating memory for boot device
[0001.619] Registering user device
[0001.633] Enable APE clock
[0001.635] Un-powergate APE partition
[0001.639] of_register: registering tegra_udc to of_hal
[0001.644] of_register: registering tegra_udc to of_hal
[0001.649] of_register: registering inv20628-driver to of_hal
[0001.655] of_register: registering ads1015-driver to of_hal
[0001.660] of_register: registering lp8557-bl-driver to of_hal
[0001.666] of_register: registering bq2419x_charger to of_hal
[0001.671] of_register: registering cpc to of_hal
[0001.676] of_register: registering bq27441_fuel_gauge to of_hal
[0001.687] gpio framework initialized
[0001.691] of_register: registering tca9539_gpio to of_hal
[0001.696] of_register: registering tca9539_gpio to of_hal
[0001.702] of_register: registering i2c_bus_driver to of_hal
[0001.707] of_register: registering i2c_bus_driver to of_hal
[0001.713] of_register: registering i2c_bus_driver to of_hal
[0001.718] of_register: registering i2c_bus_driver to of_hal
[0001.724] pmic framework initialized
[0001.727] of_register: registering max77620_pmic to of_hal
[0001.733] regulator framework initialized
[0001.737] of_register: registering tps65132_bl_driver to of_hal
[0001.743] initializing target
[0001.748] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.757] fixed regulator driver initialized
[0001.774] initializing OF layer
[0001.777] NCK carveout not present
[0001.780] Skipping dts_overrides
[0001.784] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.801] I2C Bus Init done
[0001.803] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.814] I2C Bus Init done
[0001.816] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.827] I2C Bus Init done
[0001.829] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.839] I2C Bus Init done
[0001.842] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.852] I2C Bus Init done
[0001.855] of_children_init: Ops found for compatible string maxim,max77620
[0001.865] max77620_init using irq 118
[0001.870] register ‘maxim,max77620’ pmic
[0001.874] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.881] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.891] I2C Bus Init done
[0001.895] NCK carveout not present
[0001.898] shim_invoke: No NCT, Calling dts updates
[0001.909] Find /i2c@7000c000’s alias i2c0
[0001.913] get eeprom at 1-a0, size 256, type 0
[0001.922] Find /i2c@7000c500’s alias i2c2
[0001.926] get eeprom at 3-a0, size 256, type 0
[0001.930] get eeprom at 3-ae, size 256, type 0
[0001.934] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.940] I2C slave not started
[0001.943] I2C write failed
[0001.945] Writing offset failed
[0001.948] eeprom_init: EEPROM read failed
[0001.952] pm_ids_update: eeprom init failed
[0001.956] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.986] pm_ids_update: The pm board id is 3448-0000-200
[0001.993] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.001] pm_ids_update: pm id update successful
[0002.005] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.011] I2C slave not started
[0002.014] I2C write failed
[0002.016] Writing offset failed
[0002.019] eeprom_init: EEPROM read failed
[0002.023] pm_ids_update: eeprom init failed
[0002.053] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.059] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.067] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.073] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.082] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:42:c1
[0002.088] Plugin Manager: Parse ODM data 0x00094000
[0002.098] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.119] Find /i2c@7000c000’s alias i2c0
[0002.123] get eeprom at 1-a0, size 256, type 0
[0002.132] Find /i2c@7000c500’s alias i2c2
[0002.136] get eeprom at 3-a0, size 256, type 0
[0002.140] get eeprom at 3-ae, size 256, type 0
[0002.145] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.150] I2C slave not started
[0002.153] I2C write failed
[0002.155] Writing offset failed
[0002.158] eeprom_init: EEPROM read failed
[0002.162] pm_ids_update: eeprom init failed
[0002.167] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.197] pm_ids_update: The pm board id is 3448-0000-200
[0002.203] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.210] pm_ids_update: pm id update successful
[0002.215] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.220] I2C slave not started
[0002.223] I2C write failed
[0002.226] Writing offset failed
[0002.229] eeprom_init: EEPROM read failed
[0002.233] pm_ids_update: eeprom init failed
[0002.263] Chip UID is 00000001644495082400000009fe04c0
[0002.268] Add serial number:14224190871460c004fe as DT property
[0002.276] Applying platform configs
[0002.283] platform-init is not present. Skipping
[0002.287] calling apps_init()
[0002.307] Found 14 GPT partitions in “sd0”
[0002.311] Proceeding to Cold Boot
[0002.314] starting app android_boot_app
[0002.318] Device state: unlocked
[0002.321] display console init
[0002.329] could not find regulator
[0002.333] hdmi cable connected
[0002.348] edid read success
[0002.363] edid rDT entry for leds-pwm not found
e[0002.371] ad success
[0002.373] width = 640, height = 480, frequency = 25174825
[0002.379] width = 1920, height = 1080, frequency = 148500000
[0002.384] width = 1280, height = 768, frequency = 79500000
[0002.390] width = 1360, height = 768, frequency = 85500000
[0002.395] width = 1280, height = 720, frequency = 74250000
[0002.401] width = 1920, height = 1080, frequency = 148351648
[0002.406] width = 1280, height = 720, frequency = 74175824
[0002.412] width = 1920, height = 1080, frequency = 148351648
[0002.417] width = 1280, height = 720, frequency = 74175824
[0002.423] width = 720, height = 576, frequency = 26973026
[0002.428] width = 720, height = 480, frequency = 26973026
[0002.434] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.441] tmds-config node not found
[0002.445] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.460] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.468] could not find regulator
[0002.471] could not find regulator
[0002.474] could not find regulator
[0002.503] using default cmu settings
[0002.506] dc_hdmi_enable, starting HDMI initialisation
[0002.512] dc_hdmi_enable, HDMI initialisation complete
[0002.517] list and configure display window
[0002.526] display console init completed
[0002.537] subnode volume_up is not found !
[0002.541] subnode back is not found !
[0002.545] subnode volume_down is not found !
[0002.549] subnode menu is not found !
[0002.553] Gpio keyboard init success
[0002.597] found decompressor handler: lz4-legacy
[0002.611] decompressing blob (type 1)…
[0002.651] load_bmp_blob: panelresolution=1080 type=3
[0002.702] decompressor handler not found
[0002.705] load_firmware_blob: Firmware blob loaded, entries=2
[0002.711] se_aes_verify_sbk_clear: Error
[0002.715] bl_battery_charging: connected to external power supply
[0002.722] xusb is supported
[0002.728] error while finding nvidia,portmap
[0002.734] could not find regulator
[0003.237] xusb blob version 0 size 124416
[0003.241] firmware size 124416
[0003.246] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.255] xhci0: 64 bytes context size, 32-bit DMA
[0003.295] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.315] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.965] uhub0: 9 ports with 9 removable, self powered
[0004.965] failed to get HID devices
[0004.968] failed to init xhci or no usb device attached
[0004.979] device_query_partition_size: failed to open partition sd0:MSC !
[0004.985] MSC Partition not found
[0004.992] device_query_partition_size: failed to open partition sd0:USP !
[0004.998] USP partition read failed!
[0005.002] blob_init: blob-partition USP header read failed
[0005.007] android_boot Unable to update recovery partition
[0005.013] kfs_getpartname: name = LNX
[0005.016] Loading kernel from LNX
[0005.076] Verifying boot image in OdmNonSecureSBK mode
[0005.120] kernel load address: 0x80080000, size: 482032 bytes
[0005.126] ramdisk load address: 0x84100000, size: 0 bytes
[0005.131] load kernel from storage
[0005.143] decompressor handler not found
[0005.200] Successfully loaded kernel and ramdisk images
[0005.206] load_bmp_blob: panelresolution=1080 type=3
[0005.704] display bmp image done
[0005.707] NCK carveout not present
[0005.710] Skipping dts_overrides
[0005.713] NCK carveout not present
[0005.717] shim_invoke: No NCT, Calling dts updates
[0005.728] Find /i2c@7000c000’s alias i2c0
[0005.732] get eeprom at 1-a0, size 256, type 0
[0005.741] Find /i2c@7000c500’s alias i2c2
[0005.745] get eeprom at 3-a0, size 256, type 0
[0005.749] get eeprom at 3-ae, size 256, type 0
[0005.753] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.759] I2C slave not started
[0005.762] I2C write failed
[0005.764] Writing offset failed
[0005.767] eeprom_init: EEPROM read failed
[0005.771] pm_ids_update: eeprom init failed
[0005.775] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.805] pm_ids_update: The pm board id is 3448-0000-200
[0005.812] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.820] pm_ids_update: pm id update successful
[0005.824] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.830] I2C slave not started
[0005.833] I2C write failed
[0005.835] Writing offset failed
[0005.838] eeprom_init: EEPROM read failed
[0005.842] pm_ids_update: eeprom init failed
[0005.872] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.878] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.886] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.892] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.901] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:42:c1
[0005.907] Plugin Manager: Parse ODM data 0x00094000
[0005.917] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.932] Add serial number:14224190871460c004fe as DT property
[0005.941] “bpmp” doesn’t exist, creating
[0005.947] Updated bpmp info to DTB
[0005.952] Updated initrd info to DTB
[0005.955] “proc-board” doesn’t exist, creating
[0005.961] Updated board info to DTB
[0005.964] “pmu-board” doesn’t exist, creating
[0005.969] Updated board info to DTB
[0005.973] “display-board” doesn’t exist, creating
[0005.978] Updated board info to DTB
[0005.982] “reset” doesn’t exist, creating
[0005.986] Updated reset info to DTB
[0005.990] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1
[0006.028] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.041] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.054] Updated bootarg info to DTB
[0006.057] Adding uuid 00000001644495082400000009fe04c0 to DT
[0006.063] Adding eks info 0 to DT
[0006.069] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.075] Updated memory info to DTB
[0006.083] set vdd_core voltage to 1075 mv
[0006.087] setting ‘vdd-core’ regulator to 1075000 micro volts
[0006.105] could not find regulator
[0006.109] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:10:20 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 105 ms (5.9 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5562384 bytes read in 336 ms (15.8 MiB/s)
Retrieving file: /boot/Image
34115592 bytes read in 1541 ms (21.1 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831772dd
Starting kernel …
[ 1.100892] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.146150] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.152479] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100 [ 1.172690] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.178992] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.192299] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.198591] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.211903] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.218200] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.231517] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.231521] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.231527] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.242527] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121) [ 1.242559] imx219 6-0010: board setup failed [ 1.274042] rt5640 2-001c: Device with ID register 0xffffff80 is not rt5640/39 [ 1.347642] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.347646] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.352621] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.352624] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.357597] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.357600] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.362572] tegradc tegradc.1: dp: aux write got error (0x10000100) [ 1.362592] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100 [ 1.362595] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2) [ 1.362598] hpd: edid read prepare failed [ 5.429561] cgroup: cgroup2: unknown option "nsdelegate" [ 8.741172] using random self ethernet address [ 8.745713] using random host ethernet address [ 8.778520] using random self ethernet address [ 8.783089] using random host ethernet address
Ubuntu 18.04.2 LTS test1-desktop ttyS0
test1-desktop login: test1
Password:
Last login: Sun Jan 28 23:58:41 HKT 2018 on ttyS0
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.9.140+ aarch64)
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the ‘unminimize’ command.
0 packages can be updated.
0 updates are security updates.
Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
test1@test1-desktop:~ uname -a Linux test1-desktop 4.9.140+ #1 SMP PREEMPT Wed Dec 4 21:09:40 CST 2019 aarch64 aarch64 aarch64 GNU/Linux test1@test1-desktop:~ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140+ (fred@YWUS0) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Dec 4 21:09:40 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb3000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb3000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb3000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29416(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562228K/4159488K available (15230K kernel code, 2916K rwdata, 6568K rodata, 8576K init, 611K bss, 122124K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095d0000 ( 6592 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e30000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e30000 - 0xffffff800a109008 ( 2917 KB)
[ 0.000000] .bss : 0xffffff800a109008 - 0xffffff800a1a1e3c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001697] Console: colour dummy device 80x25
[ 0.001720] console [tty0] enabled
[ 0.001737] kmemleak: Kernel memory leak detector disabled
[ 0.001755] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001769] pid_max: default: 32768 minimum: 301
[ 0.002223] Security Framework initialized
[ 0.002447] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002456] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003611] ftrace: allocating 46962 entries in 184 pages
[ 0.174627] sched-energy: CPU device node has no sched-energy-costs
[ 0.174664] ASID allocator initialised with 65536 entries
[ 0.211821] tegra-id: chipid=22117.
[ 0.211836] tegra-id: opt_subrevision=0.
[ 0.211855] Tegra Speedo/IDDQ fuse revision 4
[ 0.211860] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211864] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211870] Tegra: CPU Speedo Value 2084, SoC Speedo Value 1973, GPU Speedo Value 2099
[ 0.211874] Tegra: CPU IDDQ Value 2044, SoC IDDQ Value 2140, GPU IDDQ Value 2740
[ 0.211894] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211908] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211914] DTB Build time: Dec 4 2019 21:00:10
[ 0.261096] CPU1: Booted secondary processor [411fd071]
[ 0.293002] CPU2: Booted secondary processor [411fd071]
[ 0.324968] CPU3: Booted secondary processor [411fd071]
[ 0.325059] Brought up 4 CPUs
[ 0.325066] SMP: Total of 4 processors activated.
[ 0.325074] CPU features: detected feature: 32-bit EL0 Support
[ 0.325336] CPU: All CPU(s) started at EL2
[ 0.325354] alternatives: patching kernel code
[ 0.333725] devtmpfs: initialized
[ 0.372145] Initilizing CustomIPI irq domain
[ 0.372548] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.372567] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.384183] pinctrl core: initialized pinctrl subsystem
[ 0.384862] OS set in device tree is not L4T.
[ 0.385369] regulator-dummy: no parameters
[ 0.385660] Initializing plugin-manager
[ 0.385769] Plugin module not found
[ 0.385997] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.386538] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.387565] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.388018] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.388453] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.392959] NET: Registered protocol family 16
[ 0.394436] pstore: using zlib compression
[ 0.394481] console [pstore-1] enabled
[ 0.394486] pstore: Registered ramoops as persistent store backend
[ 0.394492] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.409115] cpuidle: using governor menu
[ 0.413368] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.415022] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e34000)
[ 0.415044] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.417705] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.420236] tegra_powergate_init: DONE
[ 0.420251] DTS File Name: …/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.420258] DTB Build time: Dec 4 2019 21:00:10
[ 0.422046] Tegra reboot handler registered.
[ 0.426549] iommu: Adding device tegra-carveouts to group 0
[ 0.426699] platform tegra-carveouts: domain=ffffffc0f9bba318 allocates as[0]=ffffffc0f9bd40a8
[ 0.427051] iommu: Adding device smmu_test to group 1
[ 0.427100] platform smmu_test: domain=ffffffc0f9bba558 allocates as[0]=ffffffc0f9bd4110
[ 0.427929] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.427986] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.428038] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.428047] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.428071] mc-err: mcerr ops are set to t21x
[ 0.437600] iommu: Adding device 70090000.xusb to group 2
[ 0.437878] iommu: Adding device 70006000.serial to group 3
[ 0.437956] platform 70006000.serial: domain=ffffffc0f94c1618 allocates as[0]=ffffffc0f9bd4178
[ 0.438381] iommu: Adding device 70006040.serial to group 4
[ 0.438654] iommu: Adding device 70006200.serial to group 5
[ 0.438871] iommu: Adding device sound to group 6
[ 0.438953] platform sound: domain=ffffffc0f94c1b58 allocates as[0]=ffffffc0f9bd41e0
[ 0.439482] iommu: Adding device 7000d400.spi to group 7
[ 0.439734] iommu: Adding device 7000d600.spi to group 8
[ 0.440010] iommu: Adding device 70410000.spi to group 9
[ 0.440312] iommu: Adding device 50000000.host1x to group 10
[ 0.440580] iommu: Adding device 54080000.vi to group 11
[ 0.440957] iommu: Adding device 54600000.isp to group 12
[ 0.441375] iommu: Adding device 54680000.isp to group 13
[ 0.441691] iommu: Adding device tegradc.0 to group 14
[ 0.441746] platform tegradc.0: domain=ffffffc0f94cea98 allocates as[0]=ffffffc0f9bd4248
[ 0.445918] platform tegradc.0: IOVA linear map 0x0000000092cb3000(800000)
[ 0.446310] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.446637] iommu: Adding device tegradc.1 to group 15
[ 0.446684] platform tegradc.1: domain=ffffffc0f94cecd8 allocates as[0]=ffffffc0f9bd42b0
[ 0.450841] platform tegradc.1: IOVA linear map 0x0000000092cb3000(800000)
[ 0.451232] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451487] iommu: Adding device 54340000.vic to group 16
[ 0.451695] iommu: Adding device 544c0000.nvenc to group 17
[ 0.451890] iommu: Adding device 54500000.tsec to group 18
[ 0.452109] iommu: Adding device 54100000.tsecb to group 19
[ 0.452299] iommu: Adding device 54480000.nvdec to group 20
[ 0.452527] iommu: Adding device 54380000.nvjpg to group 21
[ 0.453582] iommu: Adding device 546c0000.i2c to group 22
[ 0.453908] iommu: Adding device 57000000.gpu to group 23
[ 0.453962] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[0]=ffffffc0f9bd4318
[ 0.453997] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[1]=ffffffc0f9bd4380
[ 0.454037] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[2]=ffffffc0f9bd43e8
[ 0.454074] platform 57000000.gpu: domain=ffffffc0f94ddcd8 allocates as[3]=ffffffc0f9bd4450
[ 0.454980] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.454990] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.455003] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.455008] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.455013] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.505190] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.505198] tegra-pmc: Clear bootloader IO dpd settings
[ 0.505219] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.505286] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.505572] iommu: Adding device 70012000.se to group 24
[ 0.506362] iommu: Adding device 7000c000.i2c to group 25
[ 0.506610] iommu: Adding device 7000c400.i2c to group 26
[ 0.506862] iommu: Adding device 7000c500.i2c to group 27
[ 0.507114] iommu: Adding device 7000c700.i2c to group 28
[ 0.507401] iommu: Adding device 7000d000.i2c to group 29
[ 0.507643] iommu: Adding device 7000d100.i2c to group 30
[ 0.507937] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.507992] platform sdhci-tegra.0: domain=ffffffc0f9574e58 allocates as[0]=ffffffc0f9bd44b8
[ 0.508806] iommu: Adding device 700d0000.xudc to group 32
[ 0.512199] vdd-ac-bat: 5000 mV
[ 0.512552] vdd-5v0-sys: 5000 mV
[ 0.513507] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.513578] vdd-5v0-hdmi: 5000 mV
[ 0.513984] vdd-1v8-sys: 1800 mV
[ 0.514372] vdd-fan: supplied by vdd-5v0-sys
[ 0.514412] vdd-fan: 5000 mV
[ 0.514786] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.514844] vdd-usb-vbus: 5000 mV
[ 0.515361] vdd-usb-vbus2: 5000 mV
[ 0.545940] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548421] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.549573] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.549591] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.549623] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.549993] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.557934] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.558279] SCSI subsystem initialized
[ 0.558498] libata version 3.00 loaded.
[ 0.558764] usbcore: registered new interface driver usbfs
[ 0.558809] usbcore: registered new interface driver hub
[ 0.558891] usbcore: registered new device driver usb
[ 0.562813] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.569076] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.569726] random: fast init done
[ 0.570007] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.572991] vdd-ddr-1v1: 1150 mV
[ 0.576989] vdd-pre-reg-1v35: 1350 mV
[ 0.580986] vdd-1v8: 1800 mV
[ 0.584986] avdd-sys-1v2: 1200 mV
[ 0.588984] vdd-pex-1v0: 1050 mV
[ 0.589564] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.590044] max77620-ldo3: at 3100 mV
[ 0.592988] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.593513] max77620-ldo5: at 3100 mV
[ 0.594010] max77620-ldo6: at 2800 mV
[ 0.596986] avdd-1v05-pll: 1050 mV
[ 0.600986] avdd-io-hdmi-dp: 1050 mV
[ 0.602151] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.602424] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.603777] max77620 4-003c: max77620 probe successful
[ 0.606556] media: Linux media interface: v0.10
[ 0.606610] Linux video capture interface: v2.00
[ 0.607487] pps_core: LinuxPPS API ver. 1 registered
[ 0.607493] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.607509] PTP clock support registered
[ 0.611187] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.617599] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.618427] Advanced Linux Sound Architecture Driver Initialized.
[ 0.619084] Bluetooth: Core ver 2.22
[ 0.619132] NET: Registered protocol family 31
[ 0.619137] Bluetooth: HCI device and connection manager initialized
[ 0.619151] Bluetooth: HCI socket layer initialized
[ 0.619161] Bluetooth: L2CAP socket layer initialized
[ 0.619186] Bluetooth: SCO socket layer initialized
[ 0.620803] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.620818] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.620860] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.620874] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.624054] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.625126] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.625195] vdd-3v3-sys: 3300 mV
[ 0.625461] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629064] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629527] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629562] vdd-3v3-sd: 3300 mV
[ 0.630473] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630512] avdd-io-edp-1v05: 1050 mV
[ 0.630966] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.630997] vdd-usb-hub-en: 5000 mV
[ 0.632398] camchar: rtcpu character device driver loaded
[ 0.633150] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.634596] clocksource: Switched to clocksource arch_sys_counter
[ 0.675479] VFS: Disk quotas dquot_6.6.0
[ 0.675635] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.676159] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676609] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676627] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.676838] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.676844] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.676857] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.676890] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.676896] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.676907] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.676915] nvmap_page_pool_init: Total RAM pages: 1009341
[ 0.676921] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.677011] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677490] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678541] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.686871] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.687303] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687539] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687745] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.687923] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.688194] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.688197] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.688626] NET: Registered protocol family 2
[ 0.689726] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.689938] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.690477] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.690709] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690791] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.691214] NET: Registered protocol family 1
[ 0.691999] RPC: Registered named UNIX socket transport module.
[ 0.692005] RPC: Registered udp transport module.
[ 0.692008] RPC: Registered tcp transport module.
[ 0.692011] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.692026] PCI: CLS 0 bytes, default 64
[ 0.692260] Trying to unpack rootfs image as initramfs…
[ 0.942071] Freeing initrd memory: 5432K
[ 0.951968] host1x 50000000.host1x: initialized
[ 0.953823] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.957115] audit: initializing netlink subsys (disabled)
[ 0.957187] audit: type=2000 audit(0.803:1): initialized
[ 0.957940] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.968100] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.969612] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.970408] 9p: Installing v9fs 9p2000 file system support
[ 0.973730] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.973901] io scheduler noop registered
[ 0.974194] io scheduler cfq registered (default)
[ 0.976939] gic 702f9000.agic: GIC IRQ controller registered
[ 0.979799] iommu: Adding device 702ef000.adsp to group 33
[ 0.985735] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.985882] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.986445] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0xa249c11
[ 0.986453] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.988590] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.988699] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.988802] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.988992] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.989083] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.989170] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.989259] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.989344] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.989436] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.989539] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.995014] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.996767] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.998720] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.999960] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.000315] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.001512] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.001743] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.001990] Adding domain tsec-pd to PM domain host1x-pd
[ 1.004253] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.005141] tsec 54500000.tsec: initialized
[ 1.006720] tsec 54100000.tsecb: initialized
[ 1.007409] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.010827] nvdec 54480000.nvdec: initialized
[ 1.011841] Adding domain vic03-pd to PM domain host1x-pd
[ 1.012021] Adding domain msenc-pd to PM domain host1x-pd
[ 1.012178] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.016314] falcon 54340000.vic: initialized
[ 1.017526] falcon 544c0000.nvenc: initialized
[ 1.018867] falcon 54380000.nvjpg: initialized
[ 1.023286] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.023412] display board info: id 0x0, fab 0x0
[ 1.023473] generic_infoframe_type: 0x87
[ 1.023607] tegradc tegradc.0: DT parsed successfully
[ 1.023662] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.024203] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.027581] tegradc tegradc.0: probed
[ 1.031489] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.035647] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.036364] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.036689] kfuse 7000fc00.kfuse: initialized
[ 1.038121] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.039402] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.041435] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.041459] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.042015] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.043545] vdd-gpu: applied init 1000000uV constraint
[ 1.043558] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.044010] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.048871] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.049031] No Device Node present for smmu client: serial8250 !!
[ 1.049046] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.049125] iommu: Adding device serial8250 to group 35
[ 1.052802] console [ttyS0] disabled
[ 1.052957] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.053150] console [ttyS0] enabled
[ 1.054369] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.054798] serial-tegra 70006200.serial: RX in PIO mode
[ 1.054919] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.055989] [drm] Initialized
[ 1.060792] Console: switching to colour frame buffer device 240x67
[ 1.060920] tegradc tegradc.0: fb registered
[ 1.067582] brd: module loaded
[ 1.070160] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.070212] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.070834] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.070847] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.073428] loop: module loaded
[ 1.073549] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.073674] tegra_profiler: auth: init
[ 1.075160] THERMAL EST: found 2 subdevs
[ 1.075169] THERMAL EST num_resources: 0
[ 1.075175] [THERMAL EST subdev 0]
[ 1.075182] [THERMAL EST subdev 1]
[ 1.075640] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.075645] THERMAL EST: thz register success.
[ 1.075816] THERMAL EST: end of probe, return err: 0
[ 1.077080] hisi_sas: driver version v1.6
[ 1.081215] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.082522] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.082531] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.085929] libphy: Fixed MDIO Bus: probed
[ 1.086649] tun: Universal TUN/TAP device driver, 1.6
[ 1.086654] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.087907] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.087913] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.087974] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.087978] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.088026] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.088029] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.088079] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.088084] Copyright© 1999 - 2017 Intel Corporation.
[ 1.089147] PPP generic driver version 2.4.2
[ 1.089355] PPP BSD Compression module registered
[ 1.089360] PPP Deflate Compression module registered
[ 1.089404] PPP MPPE Compression module registered
[ 1.089411] NET: Registered protocol family 24
[ 1.089483] usbcore: registered new interface driver r8152
[ 1.089530] usbcore: registered new interface driver asix
[ 1.089699] usbcore: registered new interface driver ax88179_178a
[ 1.089744] usbcore: registered new interface driver cdc_ether
[ 1.089784] usbcore: registered new interface driver net1080
[ 1.089823] usbcore: registered new interface driver cdc_subset
[ 1.089861] usbcore: registered new interface driver zaurus
[ 1.089927] usbcore: registered new interface driver cdc_ncm
[ 1.090097] VFIO - User Level meta-driver version: 0.3
[ 1.091541] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.091572] ehci-pci: EHCI PCI platform driver
[ 1.091618] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.091630] ohci-pci: OHCI PCI platform driver
[ 1.091673] ohci-platform: OHCI generic platform driver
[ 1.094410] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.095012] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.096212] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d2800 id
[ 1.096857] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.096868] Extcon AUX1(HDMI) enable
[ 1.098458] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.098572] tegradc tegradc.1: No lt-data, using default setting
[ 1.098810] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.098812] tegradc tegradc.1: No hpd-gpio in DT
[ 1.098852] tegradc tegradc.1: DT parsed successfully
[ 1.098882] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.098914] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.098923] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.098955] usbcore: registered new interface driver uas
[ 1.099015] usbcore: registered new interface driver usb-storage
[ 1.099131] usbcore: registered new interface driver usbserial
[ 1.099858] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.099923] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.100400] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.100409] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100414] usb usb1: Product: xHCI Host Controller
[ 1.100419] usb usb1: Manufacturer: Linux 4.9.140+ xhci-hcd
[ 1.100423] usb usb1: SerialNumber: 70090000.xusb
[ 1.101120] hub 1-0:1.0: USB hub found
[ 1.101215] hub 1-0:1.0: 5 ports detected
[ 1.102053] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.102067] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.102168] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.102266] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.102271] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102274] usb usb2: Product: xHCI Host Controller
[ 1.102278] usb usb2: Manufacturer: Linux 4.9.140+ xhci-hcd
[ 1.102281] usb usb2: SerialNumber: 70090000.xusb
[ 1.102812] hub 2-0:1.0: USB hub found
[ 1.102846] hub 2-0:1.0: 4 ports detected
[ 1.103905] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.105284] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.105295] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.105310] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.105338] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.105360] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.106021] mousedev: PS/2 mouse device common for all mice
[ 1.106136] usbcore: registered new interface driver xpad
[ 1.111275] tegradc tegradc.1: probed
[ 1.134580] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.138057] tegradc tegradc.1: fb registered
[ 1.142000] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.143244] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.144698] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.167959] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[ 1.168696] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.170149] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.171239] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.187921] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.189380] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.190840] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.202704] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.207513] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.208972] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.210430] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.211148] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.213859] rtc rtc1: alarm rtc device
[ 1.213880] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.213914] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.214716] i2c /dev entries driver
[ 1.219124] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.227138] tegradc tegradc.1: dp: aux write retry (0x10000100) – 2
[ 1.228599] tegradc tegradc.1: dp: aux write retry (0x10000100) – 1
[ 1.230056] tegradc tegradc.1: dp: aux write retry (0x10000100) – 0
[ 1.230265] tegradc tegradc.0: blank - powerdown
[ 1.231668] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.231674] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.242455] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.242685] imx219: probe of 6-0010 failed with error -121
[ 1.243646] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.246235] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.246241] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.246759] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.246777] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.246787] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.246928] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.246938] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.246945] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.247091] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.247101] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.247106] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.247282] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.248118] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.248171] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.248195] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.248212] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.248221] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.249071] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.249090] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.249260] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.249289] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.249657] parse_throttle_dt_data: Num cap clks = 6
[ 1.249662] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.249678] parse_throttle_dt_data: clk=gpu type=4
[ 1.249702] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.249722] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.249743] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.249747] parse_throttle_dt_data: clk=emc type=3
[ 1.250347] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.250466] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.250675] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.251567] FAN dev name: pwm-fan
[ 1.251621] FAN:gpio request success.
[ 1.251700] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.252010] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.252231] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.252242] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.252341] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.252346] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.252351] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.252355] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.252360] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.252364] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.252367] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.252371] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.252375] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.252379] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.253018] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.253448] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.254362] device-mapper: uevent: version 1.0.3
[ 1.254898] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.260657] tegra210-cpufreq cpufreq: probe()…completed
[ 1.261359] sdhci: Secure Digital Host Controller Interface driver
[ 1.261360] sdhci: Copyright© Pierre Ossman
[ 1.261362] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.261834] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.262182] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.262309] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.266605] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.267125] hidraw: raw HID events driver © Jiri Kosina
[ 1.268319] usbcore: registered
Hi 530954029,
Please refer to https://devtalk.nvidia.com/default/topic/1066993/jetson-nano/hdmi-is-not-working/
