HDMI/DP in IGX Thor T5000
Hi team,
Could you tell me How many channels of HDMI/DP is supported in IGX Thor T5000 ? Is it same as Jetson thor T5000 SoM ? As per datasheet it says 2x HDMI/DP support, but the design guide shows 4x Pin description for HDMI/DP. Could you tell me why is this contradiction ? Even the developer kit schematic shows 4x HDMI/DP output. (2x is DP alt mode). Could you clarify this ?
Thank you for pointing out the discrepancy in the documentation. I am confirming with the team.
Hi chris,
Could you please clarify this?
IGX Thor T5000 supports 2x DP/HDMI. I am still confirming which specific ports out of DP[3:0].
DP[1:0] should be used. They map to the HDMI (DP1) and DP (DP0) connectors in the IGX Thor reference schematics.
ok thanks.
So, this means only 2x DP/HDMI support in IGX Thor T5000 whereas Jetson Thor T5000 has 4x DP/HDMI support. Am i correct?
There are some software issues on Jetson Thor T5000 so that even 4x display is not working on it either and we are still fixing it.
Okay. Is there any blocker in implementing 4x DP/HDMI in carrier board for jetson T5000? Can i implement 4x DP/HDMI in my custom carrier board?
I assume eventually this software issue will be fixed.
