Hello Experts,
when there is no operating device for 600 seconds, the device automatically turns off the hdmi output. Even though I’ve turned these options off:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
I found that tegradc.will blank this in kmesg log below:
[ 4.779582] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 4.814305] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 4.814307] Extcon AUX1(HDMI) enable
[ 4.823439] tegradc tegradc.0: unblank
[ 4.823451] tegradc tegradc.1: blank - powerdown
[ 5.270069] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.270076] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.595037] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.626988] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.626995] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.626999] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.627003] usb 2-1: Manufacturer: Generic
[ 5.630483] hub 2-1:1.0: USB hub found
[ 5.631274] hub 2-1:1.0: 4 ports detected
[ 5.782675] usb 2-1: usb_suspend_both: status 0
[ 5.782810] usb usb2: usb_suspend_both: status 0
[ 655.013019] tegradc tegradc.0: blank - powerdown
[ 655.078210] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 655.078212] Extcon AUX1(HDMI) disable
[ 660.893176] tegradc tegradc.0: unblank
[ 660.911390] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 660.912904] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 660.913909] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 660.913916] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 660.953925] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 660.953943] Extcon AUX1(HDMI) enable
[ 660.986420] tegradc tegradc.0: unblank
[ 660.986430] tegradc tegradc.1: blank - powerdown
[ 688.342507] tegradc tegradc.0: blank - powerdown
[ 688.399258] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 688.399262] Extcon AUX1(HDMI) disable
[ 688.418261] tegradc tegradc.1: blank - powerdown
[ 688.420932] tegradc tegradc.0: blank - powerdown
[ 688.420953] tegradc tegradc.0: unblank
[ 688.432553] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 688.432639] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 688.433659] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 688.433666] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 688.468512] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 688.468514] Extcon AUX1(HDMI) enable
[ 688.470560] tegradc tegradc.0: sync windows ret = 250
[ 1430.643221] tegradc tegradc.0: blank - normal
[ 1574.036283] tegradc tegradc.0: unblank
[ 1574.037574] tegradc tegradc.0: sync windows ret = 250
[ 2249.843911] tegradc tegradc.0: blank - normal
[ 2285.467943] tegradc tegradc.0: unblank
[ 2285.469239] tegradc tegradc.0: sync windows ret = 250
[ 2905.203175] tegradc tegradc.0: blank - normal
[ 3242.059968] tegradc tegradc.0: unblank
[ 3242.062014] tegradc tegradc.0: sync windows ret = 250
PS: I use multi-user mode without Desktop Managerment(gnome):
sudo systemctl set-default multi-user.target
And the image was download form nvidia website.
Could you help to tell me who control tegradc to blank display? How to disable this sleep funciton?
