HDMI monitors connected via USB-C hub not detected by xrandr
I have an HP Omen 16 with Garuda Gnome installed and two Dell HDMI monitors connected via an USB-C hub. All working fine. The problem arises when I try to use xrandrto rearrange the layout of my screens or their resolution, but nevertheless works perfectly if I do it through the Gnome preferences.
The reason I am trying to do this with xrandr is because I want to configure the Awesome tiling window manager and could’t find another way to change my laptop’s screen resolution.
Here is the output of xrandr -q:
Screen 0: minimum 320 x 200, current 5440 x 1080, maximum 16384 x 16384
eDP-1 connected 1600x900+0+0 (normal left inverted right x axis y axis) 355mm x 200mm
   2560x1440    165.00 +  60.00 +  59.99    59.99    59.96    59.95
   1920x1440     85.00    75.00    60.00
   1856x1392     75.00    60.01
   1792x1344     75.00    60.01
   2048x1152     59.99    59.98    59.90    59.91
   1920x1200     59.88    59.95
   1920x1080     60.01    59.97    59.96    59.93
   1600x1200     85.00    75.00    70.00    65.00    60.00
   1680x1050     59.95    59.88
   1400x1050     74.76    59.98
   1600x900      59.99*   59.94    59.95    59.82
   1280x1024     85.02    75.02    60.02
   1400x900      59.96    59.88
   1280x960      85.00    60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1280x800      59.99    59.97    59.81    59.91
   1152x864      75.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      85.00    75.05    60.04    85.00    75.03    70.07    60.00
   1024x768i     86.96
   960x720       85.00    75.00    60.00
   928x696       75.00    60.05
   896x672       75.05    60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   832x624       74.55
   960x540       59.96    59.99    59.63    59.82
   800x600       85.00    75.00    70.00    65.00    60.00    85.14    72.19    75.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       74.76    59.98
   800x450       59.95    59.82
   640x512       85.02    75.02    60.02
   700x450       59.96    59.88
   640x480       85.09    60.00    85.01    72.81    75.00    59.94
   720x405       59.51    58.99
   720x400       85.04
   684x384       59.88    59.85
   640x400       59.88    59.98    85.08
   576x432       75.00
   640x360       59.86    59.83    59.84    59.32
   640x350       85.08
   512x384       85.00    75.03    70.07    60.00
   512x384i      87.06
   512x288       60.00    59.92
   416x312       74.66
   480x270       59.63    59.82
   400x300       85.27    72.19    75.12    60.32    56.34
   432x243       59.92    59.57
   320x240       85.18    72.81    75.00    60.05
   360x202       59.51    59.13
   360x200       85.04
   320x200       85.27
   320x180       59.84    59.32
   320x175       85.27
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected primary (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
  1920x1080 (0xe1) 148.500MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0xe2) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1920x1080 (0xe3) 148.352MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1600x900 (0xe4) 108.000MHz +HSync +VSync
        h: width  1600 start 1624 end 1704 total 1800 skew    0 clock  60.00KHz
        v: height  900 start  901 end  904 total 1000           clock  60.00Hz
  1280x720 (0xe5) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1280x720 (0xe6) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  1280x720 (0xe7) 74.176MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  720x576 (0xe8) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  720x480 (0xe9) 27.027MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.50KHz
        v: height  480 start  489 end  495 total  525           clock  60.00Hz
  720x480 (0xea) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  640x480 (0xeb) 25.200MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.50KHz
        v: height  480 start  490 end  492 total  525           clock  60.00Hz
  720x400 (0xec) 28.320MHz -HSync +VSync
        h: width   720 start  738 end  846 total  900 skew    0 clock  31.47KHz
        v: height  400 start  412 end  414 total  449           clock  70.08Hz
As you can see, DP-1-1 and DP-1-2 are disconnected, but they are the ports that my two external monitors are actually using (note DP-1-1 is set as primary). In fact, I have this issue only with the propietary driver. If I uninstall it this two ports show as connected and I can change their configuration using xrandr.
I have read Gnome takes the .config/monitors.xml file and uses xrandr to do the changes. I can’t do it manually so I don’t know how it’s doing it, but autorandr also fails because of this two disconnected outputs that are actually in use.
nvidia-bug-report.log.gz (5.7 MB)
