My board is jetson AGX Xavier ,and I’m use kernel source code build new Image,but 3 hdmi ports are no display out after NVIDIA Boot Logo.
the kernel config file is arch/arm64/configs/tegra_defconfig.
The log is as follows:
dmesg.txt (70.0 KB)
log.txt (37.5 KB)
Welcome to the NVIDIA Developer forums. Your issue belongs in the Jetson category, I will move it over for you.
Check if your lsmod is empty or not.
If it is empty, then your kernel build process has something missing. Read the document again.
