HDMI pixel clock higher than expected on cutom carrier board
hi sir
For HDMI tuning, we have configured the supported resolutions and actually hdmi clock are higher than expected as the following:
  1. 480p (27 MHz) → 33mhz is measured by external
  2. 720p (74.25 MHz) → 93mhz is measured by external
  3. 1080p (148.5 MHz) → 185mhz is measured by external
How can we check pll clock source or deep color is active? if deep color is active how it can be disable it?
Jetpack 6 DP
Jetson Agx Orin 32G
Customized carrier board
Please share below info when each mode is connected.
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/hub# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/disp# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/nvdisplay_p0# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/nvdisplay_p1# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/vpll0# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/vpll1# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/emc# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/pll_hub# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/disppll# cat rate
root@tegra-ubuntu:/sys/kernel/debug/bpmp/debug/clk/disphubpll# cat rate
If possible, also dump same cases from rel-35.
Also, please provide the waveform result as your measurement.
Hi sir
Based on r36.2, see the below.
1080p
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/hub/rate
48214285
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/disp/rate
150000000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/nvdisplay_p0/rate
148500000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/nvdisplay_p1/rate
148500000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/vpll0/rate
148500000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/vpll1/rate
148500000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/emc/rate
2133000000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/pll_hub/rate
467000390
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/disppll/rate
1191000000
root@l-desktop:~# cat /sys/kernel/debug/bpmp/debug/clk/disphubpll/rate
12698437
720p
48214285
77142857
148500000
74250000
148500000
74250000
665600000
467000390
1191000000
12698437
480p:
48214285
42857142
148500000
27000000
148500000
27000000
2133000000
467000390
1191000000
12698437
Did you follow the tuning guide document to probe the signal?
