this is the dmesg Info, i have B some important info:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra-gfad838a-dirty (ubuntu@OptiPlex-7050) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue May 19 16:24:52 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f676a000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29404(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7968732K/8220672K available (15422K kernel code, 2934K rwdata, 6696K rodata, 8576K init, 634K bss, 186404K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f90000 ( 15424 KB)
[ 0.000000] .rodata : 0xffffff8008f90000 - 0xffffff8009620000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e80000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a15d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a15d808 - 0xffffff800a1fc15c ( 635 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001656] Console: colour dummy device 80x25
[ 0.001662] console [tty0] enabled
[ 0.001665] bootconsole [uart8250] disabled
[ 0.001671] kmemleak: Kernel memory leak detector disabled
[ 0.001681] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001689] pid_max: default: 32768 minimum: 301
[ 0.002005] Security Framework initialized
[ 0.002162] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002166] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002785] ftrace: allocating 47445 entries in 186 pages
[ 0.129272] sched-energy: Sched-energy-costs installed from DT
[ 0.129282] ASID allocator initialised with 65536 entries
[ 0.168420] tegra-id: chipid=21817.
[ 0.168426] tegra-id: opt_subrevision=1.
[ 0.168443] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.168451] DTS File Name: /home/ubuntu/Jetpack_4.4/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.168457] DTB Build time: May 19 2020 16:40:40
[ 0.217674] CPU1: Booted secondary processor [4e0f0030]
[ 0.249326] CPU2: Booted secondary processor [4e0f0030]
[ 0.281105] CPU3: Booted secondary processor [411fd073]
[ 0.313090] CPU4: Booted secondary processor [411fd073]
[ 0.345094] CPU5: Booted secondary processor [411fd073]
[ 0.345148] Brought up 6 CPUs
[ 0.345152] SMP: Total of 6 processors activated.
[ 0.345157] CPU features: detected feature: 32-bit EL0 Support
[ 0.345837] CPU: All CPU(s) started at EL2
[ 0.345886] alternatives: patching kernel code
[ 0.348837] devtmpfs: initialized
[ 0.387793] Initilizing CustomIPI irq domain
[ 0.387991] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.388000] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.388864] pinctrl core: initialized pinctrl subsystem
[ 0.389068] OS set in device tree is not L4T.
[ 0.389235] regulator-dummy: no parameters
[ 0.389370] Initializing plugin-manager
[ 0.389424] Plugin module not found
[ 0.389461] Plugin-manager status disabled
[ 0.391310] NET: Registered protocol family 16
[ 0.391979] pstore: using zlib compression
[ 0.391991] console [pstore-1] enabled
[ 0.391994] pstore: Registered ramoops as persistent store backend
[ 0.391998] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.405118] cpuidle: using governor menu
[ 0.406665] bpmp: waiting for handshake
[ 0.406669] bpmp: handshake completed
[ 0.406687] bpmp: synchronizing channels
[ 0.406700] bpmp: channels synchronized
[ 0.406704] bpmp: mail init ok
[ 0.408784] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.408788] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.408792] arm-smmu 12000000.iommu: stage 1 translation
[ 0.408795] arm-smmu 12000000.iommu: stage 2 translation
[ 0.408798] arm-smmu 12000000.iommu: nested translation
[ 0.408804] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.408809] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.408813] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.408817] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.408820] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.410910] vdso: 2 pages (1 code @ ffffff8008f97000, 1 data @ ffffff8009e84000)
[ 0.410924] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413288] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415238] Registering BPMP clocks…
[ 0.415324] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.416262] Serial: AMBA PL011 UART driver
[ 0.417412] tegra_powergate_init: DONE
[ 0.417421] DTS File Name: /home/ubuntu/Jetpack_4.4/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.417427] DTB Build time: May 19 2020 16:40:40
[ 0.419546] Tegra reboot handler registered.
[ 0.421121] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.421190] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.421203] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.421205] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.421208] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.421362] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.421372] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.421705] iommu: Adding device 3460000.sdhci to group 0
[ 0.422411] iommu: Adding device 3400000.sdhci to group 1
[ 0.423469] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.423482] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.423932] iommu: Adding device 3160000.i2c to group 3
[ 0.424380] iommu: Adding device c240000.i2c to group 4
[ 0.424763] iommu: Adding device 3180000.i2c to group 5
[ 0.425123] iommu: Adding device 3190000.i2c to group 6
[ 0.425561] iommu: Adding device 31b0000.i2c to group 7
[ 0.425908] iommu: Adding device 31c0000.i2c to group 8
[ 0.426243] iommu: Adding device c250000.i2c to group 9
[ 0.426582] iommu: Adding device 31e0000.i2c to group 10
[ 0.428122] iommu: Adding device 3210000.spi to group 11
[ 0.428466] iommu: Adding device c260000.spi to group 12
[ 0.428868] iommu: Adding device 3240000.spi to group 13
[ 0.429586] iommu: Adding device 3100000.serial to group 14
[ 0.429938] iommu: Adding device 3110000.serial to group 15
[ 0.430281] iommu: Adding device c280000.serial to group 16
[ 0.430621] iommu: Adding device 3130000.serial to group 17
[ 0.432015] iommu: Adding device 2490000.ether_qos to group 18
[ 0.432029] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.432763] iommu: Adding device b000000.rtcpu to group 19
[ 0.435021] iommu: Adding device 13e10000.host1x to group 20
[ 0.435336] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.435645] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.435958] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.436264] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.436569] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.436934] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.437247] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.437552] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.438024] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.438693] iommu: Adding device 15700000.vi to group 30
[ 0.439061] iommu: Adding device 15600000.isp to group 31
[ 0.439537] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.440150] iommu: Adding device 15340000.vic to group 33
[ 0.440371] iommu: Adding device 154c0000.nvenc to group 34
[ 0.440585] iommu: Adding device 15480000.nvdec to group 35
[ 0.440967] iommu: Adding device 15380000.nvjpg to group 36
[ 0.441187] iommu: Adding device 15500000.tsec to group 37
[ 0.441404] iommu: Adding device 15100000.tsecb to group 38
[ 0.442085] iommu: Adding device 15810000.se to group 39
[ 0.442299] iommu: Adding device 15820000.se to group 40
[ 0.442520] iommu: Adding device 15830000.se to group 41
[ 0.442735] iommu: Adding device 15840000.se to group 42
[ 0.443638] iommu: Adding device smmu_test to group 43
[ 0.444230] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c10000
[ 0.444240] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c20000
[ 0.444250] mc: mapped MMIO address: 0xffffff800b110000 → 0x2c30000
[ 0.444260] mc: mapped MMIO address: 0xffffff800b130000 → 0x2c40000
[ 0.444271] mc: mapped MMIO address: 0xffffff800b150000 → 0x2c50000
[ 0.444280] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.444289] mc-err: mcerr ops are set to t18x
[ 0.444428] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.445613] iommu: Adding device 3530000.xhci to group 44
[ 0.445625] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.446081] iommu: Adding device 3550000.xudc to group 45
[ 0.446092] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.446805] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.446811] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.447385] iommu: Adding device 17000000.gp10b to group 46
[ 0.448422] tegra-reset 5000000.clock: registered 193 resets.
[ 0.450670] iommu: Adding device d000000.bpmp to group 47
[ 0.450874] bpmp: ping status is 0
[ 0.450975] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.453471] bpmp d000000.bpmp: probe ok
[ 0.456629] iommu: Adding device 2600000.dma to group 48
[ 0.457938] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.457967] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.457996] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.458023] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.458052] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.458080] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.458107] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.458263] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.461997] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.462137] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.463731] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.463745] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.464068] iommu: Adding device sound to group 50
[ 0.464426] iommu: Adding device 3510000.hda to group 51
[ 0.472052] iommu: Adding device c1a0000.aon to group 52
[ 0.472500] vdd-ac-bat: 5000 mV
[ 0.474248] vdd-1v8-ap: 1800 mV
[ 0.501526] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.504266] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.504445] SCSI subsystem initialized
[ 0.504558] libata version 3.00 loaded.
[ 0.504740] usbcore: registered new interface driver usbfs
[ 0.504773] usbcore: registered new interface driver hub
[ 0.504838] usbcore: registered new device driver usb
[ 0.505334] random: fast init done
[ 0.516341] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.521266] vddio-ddr: at 1125 mV
[ 0.525106] avdd_dsi_csi: 1200 mV
[ 0.529107] vdd-1v8: 1800 mV
[ 0.533106] vdd-3v3-sys: 3300 mV
[ 0.534287] spmic-ldo0: at 1800 mV
[ 0.535047] spmic-ldo1: at 800 mV
[ 0.536695] vddio-3v3: 3300 mV
[ 0.537481] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.540701] vdd-rtc: at 800 mV
[ 0.541459] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.544695] spmic-ldo6: at 1500 mV
[ 0.548694] vdd-pex-1v00: 1000 mV
[ 0.549329] dvdd-pex: 1000 mV
[ 0.551559] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.551712] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.551865] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.552040] max77620 4-003c: max77620 probe successful
[ 0.552432] media: Linux media interface: v0.10
[ 0.552460] Linux video capture interface: v2.00
[ 0.556168] pps_core: LinuxPPS API ver. 1 registered
[ 0.556172] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.556191] PTP clock support registered
[ 0.556378] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.556583] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.556600] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.558017] trusty trusty: trusty version: Built: 18:08:29 Apr 8 2020
[ 0.558032] trusty trusty: selected api version: 3 (requested 3)
[ 0.558840] Advanced Linux Sound Architecture Driver Initialized.
[ 0.559143] Bluetooth: Core ver 2.22
[ 0.559167] NET: Registered protocol family 31
[ 0.559170] Bluetooth: HCI device and connection manager initialized
[ 0.559176] Bluetooth: HCI socket layer initialized
[ 0.559180] Bluetooth: L2CAP socket layer initialized
[ 0.559194] Bluetooth: SCO socket layer initialized
[ 0.559912] en-vdd-sd: 3300 mV
[ 0.560129] en-vdd-cam: 1800 mV
[ 0.560449] vdd-usb0-5v: 5000 mV
[ 0.560717] vdd-usb1-5v: 5000 mV
[ 0.560919] en-vdd-ts-1v8: 1800 mV
[ 0.561141] en-vdd-ts-hv-3v3: 3300 mV
[ 0.561345] en-vdd-disp-3v3: 3300 mV
[ 0.561547] en-mdm-pwr-3v7: 3700 mV
[ 0.561753] en-vdd-disp-1v8: 1800 mV
[ 0.561966] en-vdd-cam-hv-2v8: 2800 mV
[ 0.562196] en-vdd-cam-1v2: 1200 mV
[ 0.562412] vdd-fan: 5000 mV
[ 0.562629] vdd-3v3: 3300 mV
[ 0.562855] dis-vdd-1v2: 1200 mV
[ 0.563082] en-vdd-vcm-2v8: 2800 mV
[ 0.563315] vdd-usb2-5v: 5000 mV
[ 0.563559] vdd-sys-bl: 3300 mV
[ 0.563799] en-vdd-sys: 1200 mV
[ 0.565870] camchar: rtcpu character device driver loaded
[ 0.566405] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.568098] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.568830] clocksource: Switched to clocksource arch_sys_counter
[ 0.590645] VFS: Disk quotas dquot_6.6.0
[ 0.590716] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.590948] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.591471] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.591477] nvmap_page_pool_init: Total RAM pages: 2008567
[ 0.591480] nvmap_page_pool_init: nvmap page pool size: 251070 pages (980 MB)
[ 0.591546] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.594154] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.601062] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.601240] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.601614] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.601688] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.601794] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.601899] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.602056] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.602256] la/ptsa driver initialized.
[ 0.602265] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.602268] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.602566] NET: Registered protocol family 2
[ 0.603231] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.603543] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.604150] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.604199] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.604320] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.604654] NET: Registered protocol family 1
[ 0.605114] RPC: Registered named UNIX socket transport module.
[ 0.605117] RPC: Registered udp transport module.
[ 0.605119] RPC: Registered tcp transport module.
[ 0.605121] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.605129] PCI: CLS 0 bytes, default 64
[ 0.605240] Trying to unpack rootfs image as initramfs…
[ 0.772701] Freeing initrd memory: 5432K
[ 0.788724] host1x 13e10000.host1x: initialized
[ 0.789881] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.791990] audit: initializing netlink subsys (disabled)
[ 0.792015] audit: type=2000 audit(0.680:1): initialized
[ 0.792445] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.798920] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.799895] ntfs: driver 2.1.32 [Flags: R/W DEBUG].
[ 0.800406] fuse init (API version 7.26)
[ 0.800743] 9p: Installing v9fs 9p2000 file system support
[ 0.802849] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.802931] io scheduler noop registered
[ 0.803139] io scheduler cfq registered (default)
[ 0.806429] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.910435] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.945235] iommu: Adding device 2993000.adsp to group 54
[ 0.946302] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.948572] tegra-xusb-padctl 3520000.xusb_padctl: Invalid OC pin: 2
[ 0.948940] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.952670] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.953878] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.954974] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.956051] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.958632] tegra-pcie 10003000.pcie-controller: 1x1, 1x1, 1x1 configuration
[ 0.959575] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.959910] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[ 0.960025] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.960127] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.960132] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 0.962381] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 0.963703] tsec 15500000.tsec: initialized
[ 0.964862] tsec 15100000.tsecb: initialized
[ 0.968360] nvdec 15480000.nvdec: initialized
[ 0.974818] falcon 15340000.vic: initialized
[ 0.976152] falcon 154c0000.nvenc: initialized
[ 0.977588] falcon 15380000.nvjpg: initialized
[ 0.979542] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.980989] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.982432] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.983836] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.985258] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.986682] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.988094] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.989532] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.992741] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.992748] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.992773] tegradccommon 15200000.dc_common: dma mapping done
[ 0.993544] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=390
[ 0.993698] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.993742] generic_infoframe_type: 0x87
[ 0.993820] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.993838] tegradc 15210000.nvdisplay: Display dc.ffffff800b3e0000 registered with id=0
[ 0.994232] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 0.997161] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 0.997247] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 0.997317] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 0.997320] tegra_cec 3960000.tegra_cec: probed
[ 0.999071] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.999075] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.999078] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.999251] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.999257] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.999988] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn’t get regulator vdd_hdmi_5v0, -517
[ 1.002837] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.002842] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.012109] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.012760] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.012788] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.013227] kfuse 3830000.kfuse: initialized
[ 1.014578] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.017320] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.022089] console [ttyS0] disabled
[ 1.022131] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.037939] console [ttyS0] enabled
[ 1.038330] tegradc 15210000.nvdisplay: probed
[ 1.038826] Console: switching to colour frame buffer device 240x67
[ 1.038910] tegradc 15210000.nvdisplay: fb registered
[ 1.039056] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 1.039403] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.040262] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.040556] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.040594] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.040639] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.040756] serial-tegra 3130000.serial: RX in PIO mode
[ 1.048542] Parent Clock set for DC plld2
[ 1.048583] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.049918] [drm] Initialized
[ 1.052364] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.053668] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.053676] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.058973] brd: module loaded
[ 1.062371] loop: module loaded
[ 1.062439] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.062513] tegra_profiler: auth: init
[ 1.062858] nct1008_nct72 7-004c: starting parse dt
[ 1.062958] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.062963] nct1008_nct72 7-004c: success parsing dt
[ 1.063067] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.063421] THERMAL EST: found 3 subdevs
[ 1.063425] THERMAL EST num_resources: 0
[ 1.063429] [THERMAL EST subdev 0]
[ 1.063433] [THERMAL EST subdev 1]
[ 1.063436] [THERMAL EST subdev 2]
[ 1.063691] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.063693] THERMAL EST: thz register success.
[ 1.063776] THERMAL EST: end of probe, return err: 0
[ 1.064416] sd: No Scsi addr parsed to reserve index
[ 1.064452] hisi_sas: driver version v1.6
[ 1.067971] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.067993] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.068701] scsi host0: tegra_ahci
[ 1.069097] scsi host1: tegra_ahci
[ 1.069232] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.069235] ata2: DUMMY
[ 1.071872] spi-tegra114 c260000.spi: chipselect 0 already in use
[ 1.077992] spi_master spi1: spi_device register error /spi@c260000/spi-touch-sharp19x12@0
[ 1.086395] spi_master spi1: Failed to create SPI device for /spi@c260000/spi-touch-sharp19x12@0
[ 1.089063] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.089067] Extcon AUX1(HDMI) enable
[ 1.089391] libphy: Fixed MDIO Bus: probed
[ 1.089942] tun: Universal TUN/TAP device driver, 1.6
[ 1.089945] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.090087] vcan: Virtual CAN interface driver
[ 1.090092] CAN device driver interface
[ 1.090612] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.090614] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.090645] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.090647] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.090676] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.090678] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.090706] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.090709] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.095514] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.096005] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.096933] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 1.099814] eqos 2490000.ether_qos: Setting local MAC: 60 60 1f cd 60 f7
[ 1.099909] libphy: dwc_phy: probed
[ 1.100187] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.102094] PPP generic driver version 2.4.2
[ 1.102214] PPP BSD Compression module registered
[ 1.102218] PPP Deflate Compression module registered
[ 1.102232] PPP MPPE Compression module registered
[ 1.102236] NET: Registered protocol family 24
[ 1.102275] usbcore: registered new interface driver r8152
[ 1.102309] usbcore: registered new interface driver asix
[ 1.102336] usbcore: registered new interface driver ax88179_178a
[ 1.102361] usbcore: registered new interface driver cdc_ether
[ 1.102387] usbcore: registered new interface driver net1080
[ 1.102414] usbcore: registered new interface driver cdc_subset
[ 1.102438] usbcore: registered new interface driver zaurus
[ 1.102473] usbcore: registered new interface driver cdc_ncm
[ 1.102575] VFIO - User Level meta-driver version: 0.3
[ 1.103423] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.103434] ehci-pci: EHCI PCI platform driver
[ 1.103463] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.103469] ohci-pci: OHCI PCI platform driver
[ 1.103497] ohci-platform: OHCI generic platform driver
[ 1.109015] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.109020] tegra-xusb 3530000.xhci: USB3 port 0 has OTG_CAP
[ 1.111544] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eacd4400 id
[ 1.112291] usbcore: registered new interface driver uas
[ 1.112332] usbcore: registered new interface driver usb-storage
[ 1.112400] usbcore: registered new interface driver usbserial
[ 1.113911] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 1.114466] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.115698] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 1.116186] mousedev: PS/2 mouse device common for all mice
[ 1.116230] usbcore: registered new interface driver xpad
[ 1.128734] nct1008_nct72 7-004c: initial LOC temp: 23000
[ 1.129047] nct1008_nct72 7-004c: initial EXT temp: 36000
[ 1.129649] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.129946] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.130128] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.140871] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.140885] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.141576] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.141605] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 1.141765] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.141770] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.141774] usb usb1: Product: xHCI Host Controller
[ 1.141777] usb usb1: Manufacturer: Linux 4.9.140-tegra-gfad838a-dirty xhci-hcd
[ 1.141781] usb usb1: SerialNumber: 3530000.xhci
[ 1.142121] hub 1-0:1.0: USB hub found
[ 1.142151] hub 1-0:1.0: 4 ports detected
[ 1.142502] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.142510] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.142653] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.142658] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.142662] usb usb2: Product: xHCI Host Controller
[ 1.142665] usb usb2: Manufacturer: Linux 4.9.140-tegra-gfad838a-dirty xhci-hcd
[ 1.142669] usb usb2: SerialNumber: 3530000.xhci
[ 1.142957] hub 2-0:1.0: USB hub found
[ 1.142982] hub 2-0:1.0: 3 ports detected
[ 1.224660] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.244957] usb usb1: usb_suspend_both: status 0
[ 1.246594] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.247723] Wake73 for irq=42
[ 1.248965] rtc rtc1: alarm rtc device
[ 1.248977] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.248991] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.249204] i2c /dev entries driver
[ 1.251122] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.256189] parse_throttle_dt_data: Num cap clks = 4
[ 1.256192] parse_throttle_dt_data: clk=mcpu type=1
[ 1.256195] parse_throttle_dt_data: clk=bcpu type=2
[ 1.256200] parse_throttle_dt_data: clk=gpu type=4
[ 1.256202] parse_throttle_dt_data: clk=emc type=3
[ 1.257268] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.257851] FAN dev name: pwm-fan
[ 1.257914] FAN:gpio request success.
[ 1.257922] FAN: can’t find tach_gpio
[ 1.257946] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.258133] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.258137] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.258733] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.258737] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.258740] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.258743] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.258747] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.258749] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.258752] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.258755] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.258758] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.258761] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.259683] device-mapper: uevent: version 1.0.3
[ 1.260055] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.260331] CPU EMC frequency mapping table: from device tree
[ 1.264283] cpufreq: platform driver Initialization: pass
[ 1.264894] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.265009] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.265808] sdhci: Secure Digital Host Controller Interface driver
[ 1.265809] sdhci: Copyright(c) Pierre Ossman
[ 1.265810] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.267009] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.268761] CMDQ: cmdq_platfm_init successful
[ 1.269756] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.269773] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.270495] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.270496] Extcon AUX1(HDMI) disable
[ 1.271626] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.271674] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.273674] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.275386] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 1.280075] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.280986] tegra-se-nvhost 15810000.se: initialized
[ 1.282309] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.282890] tegra-se-nvhost 15820000.se: initialized
[ 1.284050] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.284616] tegra-se-nvhost 15830000.se: initialized
[ 1.285590] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.286165] tegra-se-nvhost 15840000.se: initialized
[ 1.287274] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.287509] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.288334] usbcore: registered new interface driver usbhid
[ 1.288336] usbhid: USB HID core driver
[ 1.290948] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.293542] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 1.293827] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.293917] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.294159] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.294318] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.294417] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.294582] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.295351] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.295424] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.295472] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.295520] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.295618] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.296001] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.296003] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.296729] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.298749] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.299190] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.299352] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.299417] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.299719] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299721] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 1.299723] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.299772] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299774] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 1.299775] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.299824] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299826] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 1.299827] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.299874] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299875] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 1.299877] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.299924] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299926] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 1.299928] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.299975] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.299979] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 1.299981] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.300039] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300043] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 1.300045] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.300093] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300097] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 1.300099] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.300146] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300150] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 1.300151] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.300198] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300200] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 1.300201] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.300249] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300254] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 1.300255] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.300319] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300324] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 1.300325] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.300377] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300381] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 1.300383] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.300430] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300435] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 1.300436] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.300490] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 1.300494] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 1.300495] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.300550] **** A57 ECC: Enabled
[ 1.300552] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 1.300614] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.301079] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.301541] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.301665] denver_knobs_init:MTS_VERSION:47926945
[ 1.303454] nvpmodel: initialized successfully
[ 1.304327] trusty-virtio trusty:virtio: initializing
[ 1.304428] trusty_ipc virtio0: vring0: va¶ ffffffc1e5408000(0) qsz 32 notifyid 1
[ 1.304434] trusty_ipc virtio0: vring1: va¶ ffffffc1e540a000(0) qsz 32 notifyid 2
[ 1.304498] trusty-virtio trusty:virtio: initializing done
[ 1.304587] trusty_ipc virtio0: is online
[ 1.306075] usbcore: registered new interface driver snd-usb-audio
[ 1.308636] tegradc 15210000.nvdisplay: unblank
[ 1.309457] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.309533] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.309613] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 1.310762] Parent Clock set for DC plld2
[ 1.313552] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.314766] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.314773] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.316864] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.316866] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.324887] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.324933] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.326601] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.326770] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.331766] OPE platform probe
[ 1.331830] OPE platform probe successful
[ 1.351814] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.351817] Extcon AUX1(HDMI) enable
[ 1.362553] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.376666] mmc0: periodic cache flush enabled
[ 1.376673] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.381032] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 1.381148] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 1.381257] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 1.382476] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.384838] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.384911] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.384977] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.385051] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.385117] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.385180] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.385244] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.385306] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.385378] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.385431] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 1.385450] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.385527] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.385601] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.385670] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.385741] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.385808] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.385872] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.385938] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.386005] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.386069] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.386140] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.388539] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.405894] u32 classifier
[ 1.405896] Actions configured
[ 1.405952] Initializing XFRM netlink socket
[ 1.406504] NET: Registered protocol family 10
[ 1.407146] NET: Registered protocol family 17
[ 1.407155] NET: Registered protocol family 15
[ 1.407212] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.407213] can: controller area network core (rev 20120528 abi 9)
[ 1.407278] NET: Registered protocol family 29
[ 1.407279] can: raw protocol (rev 20120528)
[ 1.407281] can: broadcast manager protocol (rev 20161123 t)
[ 1.407284] can: netlink gateway (rev 20130117) max_hops=1
[ 1.407451] Bluetooth: RFCOMM socket layer initialized
[ 1.407466] Bluetooth: RFCOMM ver 1.11
[ 1.407469] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.407473] Bluetooth: HIDP socket layer initialized
[ 1.407486] 9pnet: Installing 9P2000 support
[ 1.407520] Key type dns_resolver registered
[ 1.407735] Registered cp15_barrier emulation handler
[ 1.407748] Registered setend emulation handler
[ 1.408612] registered taskstats version 1
[ 1.412392] isp 15600000.isp: initialized
[ 1.416957] nvcsi 150c0000.nvcsi: initialized
[ 1.418688] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 1.421356] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.423054] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 1.423457] tegra-vi4 15700000.vi: initialized
[ 1.423925] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.424000] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.424067] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.424176] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.424609] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 1.424612] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 1.424666] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.425420] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 1.426620] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.427269] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 1.458074] tegra_rtc c2a0000.rtc: setting system clock to 2021-10-28 06:10:17 UTC (1635401417)
[ 1.459426] mmcblk mmc0:0001: Card claimed for testing.
[ 1.488048] bpmp: mounted debugfs mirror
[ 1.489320] bwmgr: missing cdev-type property
[ 1.495186] spmic-ldo0: disabling
[ 1.495357] spmic-ldo1: disabling
[ 1.495498] en-vdd-sd: disabling
[ 1.495500] en-vdd-cam: disabling
[ 1.495501] vdd-usb0-5v: disabling
[ 1.495503] vdd-usb1-5v: disabling
[ 1.495505] en-vdd-disp-3v3: disabling
[ 1.495506] en-mdm-pwr-3v7: disabling
[ 1.495508] en-vdd-disp-1v8: disabling
[ 1.495509] en-vdd-cam-hv-2v8: disabling
[ 1.495510] en-vdd-cam-1v2: disabling
[ 1.495512] vdd-fan: disabling
[ 1.495513] vdd-3v3: disabling
[ 1.495515] en-vdd-vcm-2v8: disabling
[ 1.495517] vdd-usb2-5v: disabling
[ 1.495518] vdd-sys-bl: disabling
[ 1.495519] en-vdd-sys: disabling
[ 1.495521] ALSA device list:
[ 1.495524] #0: tegra-hda at 0x3518000 irq 383
[ 1.495525] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.545627] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.545749] ata1.00: ATA-10: KINGSTON RBUSNS4180S3128GJ, SBFK61D1, max UDMA/133
[ 1.545751] ata1.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 1.545864] ata1.00: configured for UDMA/133
[ 1.556186] scsi 0:0:0:0: Direct-Access ATA KINGSTON RBUSNS4 61D1 PQ: 0 ANSI: 5
[ 1.563893] mmc1: Applying tuning correction
[ 1.563904] mmc1: Tap value after applying correction 62
[ 1.563910] mmc1: hw tuning done …
[ 1.567823] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.593149] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.593699] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.594422] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 1.594587] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.594738] sd 0:0:0:0: [sda] Write Protect is off
[ 1.594742] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.594784] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.595606] sda: sda1
[ 1.596139] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.789167] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.024866] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.089386] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.089389] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.190855] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.192875] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.592932] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 2.994990] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 3.362604] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.362606] Extcon HDMI: HPD enabled
[ 3.362618] tegradc 15210000.nvdisplay: hdmi: plugged
[ 3.364897] Freeing unused kernel memory: 8576K
[ 3.382161] Root device found: mmcblk0p1
[ 3.382938] Found dev node: /dev/mmcblk0p1
[ 3.396853] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 3.398882] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
[ 3.463791] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 3.463796] EXT4-fs (mmcblk0p1): recovery complete
[ 3.467258] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.467917] Rootfs mounted over mmcblk0p1
[ 3.494641] Switching from initrd to actual rootfs
[ 3.603363] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.603624] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.627556] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.636314] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.648710] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.649488] systemd[1]: Detected architecture arm64.
[ 3.667002] systemd[1]: Set hostname to .
[ 3.755131] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.755140] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.864918] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.865108] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.865193] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.866420] systemd[1]: Created slice System Slice.
[ 3.866478] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.866496] systemd[1]: Reached target Swap.
[ 3.866524] systemd[1]: Reached target User and Group Name Lookups.
[ 3.866718] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.899808] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.919561] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 3.920138] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.921050] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 4.207888] systemd-journald[2299]: Received request to flush runtime journal from PID 1
[ 4.269819] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.270706] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 4.271563] Wake76 for irq=199
[ 4.271567] Wake77 for irq=199
[ 4.271568] Wake78 for irq=199
[ 4.271569] Wake79 for irq=199
[ 4.271570] Wake80 for irq=199
[ 4.271572] Wake81 for irq=199
[ 4.271573] Wake82 for irq=199
[ 4.271605] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.271609] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.373034] usb usb2: usb_suspend_both: status 0
[ 4.480252] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.481282] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 4.646777] random: crng init done
[ 4.650208] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.977583] zram: Added device: zram0
[ 5.980902] zram: Added device: zram1
[ 5.989266] zram: Added device: zram2
[ 5.991625] zram: Added device: zram3
[ 5.999006] zram: Added device: zram4
[ 6.001137] zram: Added device: zram5
[ 6.029505] zram0: detected capacity change from 0 to 686788608
[ 6.086194] Adding 670688k swap on /dev/zram0. Priority:5 extents:1 across:670688k SS
[ 6.105848] zram1: detected capacity change from 0 to 686788608
[ 6.205518] Adding 670688k swap on /dev/zram1. Priority:5 extents:1 across:670688k SS
[ 6.208504] zram2: detected capacity change from 0 to 686788608
[ 6.228779] Adding 670688k swap on /dev/zram2. Priority:5 extents:1 across:670688k SS
[ 6.243921] zram3: detected capacity change from 0 to 686788608
[ 6.275262] Adding 670688k swap on /dev/zram3. Priority:5 extents:1 across:670688k SS
[ 6.290141] zram4: detected capacity change from 0 to 686788608
[ 6.304467] Adding 670688k swap on /dev/zram4. Priority:5 extents:1 across:670688k SS
[ 6.310467] zram5: detected capacity change from 0 to 686788608
[ 6.339680] Adding 670688k swap on /dev/zram5. Priority:5 extents:1 across:670688k SS
[ 6.388143] dhd_module_init in
[ 6.388235] found wifi platform device bcmdhd_wlan
[ 6.397711] wifi_platform_get_country_code_map: could not get country_code_map
[ 6.397717] wifi_plat_dev_drv_probe:platform country code map is not available
[ 6.397734] Power-up adapter ‘DHD generic adapter’
[ 6.397742] wifi_platform_set_power = 1
[ 6.627630] wifi_platform_bus_enumerate device present 1
[ 6.659902] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.660918] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 6.665763] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.666753] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 6.703591] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.704582] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 6.714171] wifi_platform_bus_enumerate device present 0
[ 6.732939] F1 signature read @0x18000000=0x17214354
[ 6.812758] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.830337] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.830418] wifi_platform_get_mac_addr
[ 6.840067] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.856890] ids dhd_log_netlink_init
[ 6.917762] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 6.920235] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.927527] wl_event_handler :
[ 6.927532] tsk Enter, tsk = 0xffffffc1bffc1a90
[ 6.927562] wl_create_event_handler(): thread:wl_event_handler:167f started
[ 6.933373] dhd_attach(): thread:dhd_watchdog_thread:1681 started
[ 6.942990] dhd_attach(): thread:dhd_dpc:1687 started
[ 6.945393] dhd_attach(): thread:dhd_rxf:168c started
[ 6.945402] dhd_deferred_work_init: work queue initialized
[ 6.954536]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 6.960023] Register interface [wlan0] MAC: 60:60:1f:cd:60:f8
[ 6.960030] dhd_prot_ioctl : bus is down. we have nothing to do
[ 6.960311] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 62
[ 6.962050] wifi_platform_set_power = 0
[ 6.984887] tegra-xusb 3530000.xhci: entering ELPG
[ 6.989945] tegra-xusb 3530000.xhci: entering ELPG done
[ 7.172328] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.173539] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 7.175730] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.176984] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 7.223051] tegradc 15210000.nvdisplay: blank - powerdown
[ 7.248338] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 7.248341] Extcon AUX1(HDMI) disable
[ 7.270491] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 7.270579] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 7.271238] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 7.271460] tegradc 15210000.nvdisplay: unblank
[ 7.271472] tegradc 15210000.nvdisplay: update windows ret = -14
[ 7.271474] tegradc 15210000.nvdisplay: sync windows ret = -14
[ 7.291568] tegradc 15210000.nvdisplay: blank - powerdown
[ 7.291799] extcon-disp-state external-connection:disp-state: cable 51 state 0
[ 7.291802] Extcon HDMI: HPD disabled
[ 7.291828] tegradc 15210000.nvdisplay: hdmi: unplugged
[ 7.447320] tegradc 15210000.nvdisplay: blank - powerdown
[ 7.465573] tegradc 15210000.nvdisplay: unblank
[ 7.470032] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.470130] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.476254] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 7.478206] Parent Clock set for DC plld2
[ 7.481428] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 7.482815] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 7.482821] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 7.518035] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.518036] Extcon AUX1(HDMI) enable
[ 8.593191] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.593310]
Compiled from
[ 8.593318] wl_android_wifi_on in
[ 8.593322] wifi_platform_set_power = 1
[ 8.805367] vdd-1v8: voltage operation not allowed
[ 8.805387] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.825141] vdd-1v8: voltage operation not allowed
[ 8.825161] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.845980] vdd-1v8: voltage operation not allowed
[ 8.845994] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.848412] vdd-1v8: voltage operation not allowed
[ 8.848421] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.960713] vdd-1v8: voltage operation not allowed
[ 8.960740] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.961747] vdd-1v8: voltage operation not allowed
[ 8.961767] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.963420] vdd-1v8: voltage operation not allowed
[ 8.963436] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 8.963473] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 62
[ 8.965095] F1 signature read @0x18000000=0x17214354
[ 8.973108] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.974073] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.054283] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.116530] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.116909] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 9.116986] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 9.116988] Enabling wake69
[ 9.117900] wifi_platform_get_mac_addr
[ 9.120159] Firmware up: op_mode=0x0005, MAC=60:60:1f:cd:60:f8
[ 9.124996] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 9.125046] Skipping the clm download. len:0 memblk: (null)
[ 9.127467] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.132768] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 9.135392] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.261776] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 9.261776] P2P interface registered
[ 9.269996] WLC_E_IF: NO_IF set, event Ignored
[ 9.282666] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.662004] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 9.662008] Extcon HDMI: HPD enabled
[ 9.662041] tegradc 15210000.nvdisplay: hdmi: plugged
[ 11.028778] [10-28 06:10:27.71] wl_cfg80211_connect: Connectting with e4:67:1e:25:0e:04 channel (6) ssid “FAP_2G_0E02”, len (11)
[ 11.101127] [10-28 06:10:27.143] wl_notify_connect_status: wl_bss_connect_done succeeded with e4:67:1e:25:0e:04
[ 11.101903] [10-28 06:10:27.144] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M1 of 4way
[ 11.123018] wl_bss_connect_done :
[ 11.123018] Report connect result - connection succeeded
[ 11.124372] [10-28 06:10:27.166] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M2 of 4way
[ 11.129768] [10-28 06:10:27.172] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M3 of 4way
[ 11.129938] [10-28 06:10:27.172] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 11.153157] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 11.165647] [10-28 06:10:27.208] wl_notify_connect_status: wl_bss_connect_done succeeded with e4:67:1e:25:0e:04
[ 11.167449] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 11.167456] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 11.268928] ifidx:0 DHCP - DISCOVER [RX]
[ 13.827675] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.976711] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 14.117821] tegradc 15210000.nvdisplay: blank - powerdown
[ 14.139767] ifidx:0 DHCP - DISCOVER [RX]
[ 14.183038] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 14.183040] Extcon AUX1(HDMI) disable
[ 14.204974] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 14.205053] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 14.205627] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 14.205795] tegradc 15210000.nvdisplay: unblank
[ 14.206643] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 14.206727] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 14.206806] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 14.208132] Parent Clock set for DC plld2
[ 14.213841] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 14.215188] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 14.215197] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 14.250514] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 14.250516] Extcon AUX1(HDMI) enable
[ 14.250563] tegradc 15210000.nvdisplay: unblank
[ 17.207325] ifidx:0 DHCP - DISCOVER [RX]
[ 20.799089] ifidx:0 DHCP - DISCOVER [RX]
[ 23.869418] ifidx:0 DHCP - DISCOVER [RX]
[ 26.789568] ifidx:0 DHCP - DISCOVER [RX]
[ 29.809764] ifidx:0 DHCP - DISCOVER [RX]
[ 32.881057] ifidx:0 DHCP - DISCOVER [RX]
[ 35.851488] ifidx:0 DHCP - DISCOVER [RX]
[ 38.821060] ifidx:0 DHCP - DISCOVER [RX]
[ 41.892172] ifidx:0 DHCP - DISCOVER [RX]
[ 44.862870] ifidx:0 DHCP - DISCOVER [RX]
[ 47.834635] ifidx:0 DHCP - DISCOVER [RX]
[ 50.904585] ifidx:0 DHCP - DISCOVER [RX]
[ 53.874212] ifidx:0 DHCP - DISCOVER [RX]
[ 56.843850] ifidx:0 DHCP - DISCOVER [RX]
[ 59.915955] ifidx:0 DHCP - DISCOVER [RX]
[ 62.373055] ifidx:0 DHCP - DISCOVER [RX]
[ 65.342923] ifidx:0 DHCP - DISCOVER [RX]
[ 68.312899] ifidx:0 DHCP - DISCOVER [RX]
[ 71.384859] ifidx:0 DHCP - DISCOVER [RX]
[ 74.354538] ifidx:0 DHCP - DISCOVER [RX]
[ 77.324032] ifidx:0 DHCP - DISCOVER [RX]
[ 81.010746] ifidx:0 DHCP - DISCOVER [RX]
[ 83.980278] ifidx:0 DHCP - DISCOVER [RX]
[ 87.052266] ifidx:0 DHCP - DISCOVER [RX]
[ 90.021973] ifidx:0 DHCP - DISCOVER [RX]
[ 92.991693] ifidx:0 DHCP - DISCOVER [RX]
[ 96.063628] ifidx:0 DHCP - DISCOVER [RX]
[ 99.033353] ifidx:0 DHCP - DISCOVER [RX]
[ 102.001055] ifidx:0 DHCP - DISCOVER [RX]
[ 105.075127] ifidx:0 DHCP - DISCOVER [RX]
[ 105.268537] tegradc 15210000.nvdisplay: blank - powerdown
[ 105.332158] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 105.332160] Extcon AUX1(HDMI) disable
[ 105.354079] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 105.354156] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 105.354734] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 105.363948] tegradc 15210000.nvdisplay: blank - powerdown
[ 105.363970] tegradc 15210000.nvdisplay: unblank
[ 105.364757] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 105.364899] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 105.364975] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 105.366234] Parent Clock set for DC plld2
[ 105.369094] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 105.370317] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 105.370323] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 105.405469] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 105.405470] Extcon AUX1(HDMI) enable
