A few days ago the hdmi connection to the display stopped working on my Jetson board. I found I had a similar issue to the one presented in this forum:
[ 62.764535] tegra-i2c tegra12-i2c.0: --- register dump for debugging ----
[ 62.772744] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 62.779275] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 62.787563] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 62.794643] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 62.801979] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 62.808711] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 62.815522] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 62.821634] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 62.828094] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 62.834619] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x64
This issue appears to actually be due to a bent pin on the HDMI connector. The pin got pushed out of the back and angled downward. Upon trying to fix it the pin broke off entirely, making the HDMI connector permanently broken. Though I can still SSH into the board, the USB 3.0 port now also does not work, which makes the Jetson quite unusable to me. I get the same dump when connecting to the USB hub, so I am guessing this is the same issue (I am not sure how this makes sense, but I cannot find any other reason for this to be happening). Sadly this is also true for me “This board is already fully configured with my project and was in test phase”.
More info:
[code]ubuntu@tegra-ubuntu:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ubuntu@tegra-ubuntu:~$ lsusb -v -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-ehci/1p, 480M
ubuntu@tegra-ubuntu:~$ sudo dmesg -c
[sudo] password for ubuntu:
[ 48.774452] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 48.780874] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 48.787390] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x48
[ 49.797534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 49.805728] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 49.812241] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 49.820514] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 49.827552] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 49.834855] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 49.841541] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 49.848313] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 49.854383] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 49.860803] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 49.867313] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x49
[ 50.877559] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 50.885747] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 50.892254] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 50.900521] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 50.907555] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 50.914854] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 50.921537] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 50.928306] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 50.934371] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 50.940792] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 50.947303] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x0d
[ 51.957533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 51.965724] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 51.972232] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 51.980502] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 51.987536] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 51.994836] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 52.001517] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 52.008286] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 52.014352] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 52.020772] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 52.027288] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x0e
[ 53.037558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 53.045755] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 53.052268] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 53.060543] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 53.067579] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 53.074882] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 53.081571] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 53.088344] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 53.094415] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 53.100839] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 53.107355] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x3c
[ 54.117520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 54.125713] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 54.132226] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 54.140500] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 54.147541] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 54.154847] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 54.161540] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 54.168313] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 54.174385] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 54.180808] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 54.187325] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x3e
[ 55.197536] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 55.205733] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 55.212248] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 55.220525] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 55.227567] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 55.234873] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 55.241563] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 55.248337] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 55.254410] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 55.260835] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 55.267351] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x27
[ 56.277552] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 56.285747] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 56.292260] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 56.300533] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 56.307574] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 56.314880] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 56.321570] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 56.328343] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 56.334416] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 56.340840] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 56.347357] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbb
[ 57.357535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 57.365730] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 57.372242] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 57.380514] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 57.387551] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 57.394854] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 57.401539] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 57.408314] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 57.414385] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 57.420810] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 57.427326] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x64
[ 58.437520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 58.445714] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 58.452228] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 58.460502] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 58.467540] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 58.474843] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 58.481530] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 58.488304] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 58.494376] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 58.500799] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 58.507317] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x8f
[ 59.517558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 59.525754] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 59.532267] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 59.540542] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 59.547582] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 59.554885] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 59.561572] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 59.568345] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 59.574415] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 59.580836] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 59.587350] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x8e
[ 60.597518] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 60.605709] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 60.612221] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 60.620493] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 60.627529] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 60.634833] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 60.641519] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 60.648292] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 60.654364] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 60.660787] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 60.667301] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x80
[ 61.677535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 61.685729] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 61.692241] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 61.700514] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 61.707553] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 61.714859] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 61.721549] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 61.728367] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 61.734454] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 61.740882] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 61.747401] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x6a
[ 61.757813] rt5639 0-001c: Failed to set private addr: -110
[ 62.764535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 63.844558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 63.852766] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 63.859296] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 63.867581] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 63.874655] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 63.881989] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 63.888719] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 63.895526] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 63.901636] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 63.908093] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 63.914616] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x80
[ 63.929589] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 63.936363] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 63.943828] gpio wake49 for gpio=143
[ 64.948537] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 64.956719] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 64.963242] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 64.971539] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 64.978630] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 64.985979] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 64.992722] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 64.999548] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 65.005644] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 65.012020] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 65.018422] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x63
[ 66.028563] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 66.036746] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 66.043272] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 66.051573] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 66.058669] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 66.066024] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 66.072774] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 66.079601] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 66.085699] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 66.092074] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 66.098495] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x93
[ 67.064928] tegra-xhci tegra-xhci: failed to init firmware from filesystem: tegra_xusb_firmware
[ 67.108523] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 67.116820] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 67.123451] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 67.131852] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 67.139033] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 67.146481] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 67.153320] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 67.160238] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 67.166456] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 67.173002] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 67.179571] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xfa
[ 68.189537] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 68.197834] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 68.204457] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 68.212858] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 68.220039] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 68.227491] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 68.234331] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 68.241253] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 68.247475] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 68.254016] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 68.260578] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x80
[ 69.270584] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 69.278784] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 69.285298] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 69.293572] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 69.300610] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 69.307917] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 69.314607] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 69.321382] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 69.327453] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 69.333877] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 69.340393] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x64
[ 70.350536] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 70.358730] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 70.365243] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 70.373515] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 70.380556] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 70.387858] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 70.394543] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 70.401319] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 70.407391] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 70.413816] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 70.420331] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x6a
[ 70.430735] rt5639 0-001c: Failed to set private addr: -110
[ 70.437672] rt5639 0-001c: Failed to read private reg: -110
[ 71.445522] rt5639 0-001c: rt5639_headset_detect RT5639_PWR_ANLG1(0x63) = 0xa814
[ 72.455581] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 72.463874] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 72.470502] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 72.478920] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 72.486123] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 72.493591] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 72.500456] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 72.507368] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 72.513506] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 72.519927] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 72.526412] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 72.533235] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 72.539692] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 72.550107] rt5639 0-001c: rt5639_headset_detect RT5639_IRQ_CTRL2(0xbe) = 0xffffffff
[ 73.560520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 73.568966] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 73.575757] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 73.584299] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 73.591557] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 73.599029] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 73.605894] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 73.612799] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 73.618930] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 73.625341] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 73.631817] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 73.638629] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 73.645078] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 74.656535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 74.664828] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 74.671462] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 74.679878] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 74.687083] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 74.694547] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 74.701396] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 74.708300] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 74.714430] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 74.720836] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 74.727315] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 74.734029] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 74.740372] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 75.751534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 75.759683] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 75.766167] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 75.774451] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 75.781506] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 75.788829] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 75.795541] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 75.802329] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 75.808415] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 75.814821] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 75.821242] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 75.827952] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 75.834292] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 76.844561] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 76.852708] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 76.859190] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 76.867458] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 76.874511] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 76.881832] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 76.888542] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 76.895330] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 76.901411] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 76.907815] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 76.914232] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 76.920940] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 76.927281] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 77.937533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 77.945680] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 77.952163] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 77.960434] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 77.967486] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 77.974805] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 77.981515] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 77.988300] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 77.994382] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 78.000787] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 78.007208] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 78.013918] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 78.020260] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 79.030560] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 79.038707] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 79.045191] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 79.053465] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 79.060521] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 79.067843] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 79.074554] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 79.081343] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 79.087427] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 79.093831] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 79.100252] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 79.106962] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 79.113303] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 80.124519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 80.132667] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 80.139150] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 80.147422] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 80.154481] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 80.161804] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 80.168514] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 80.175301] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 80.181383] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 80.187786] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 80.194204] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 80.200912] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 80.207254] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 81.217534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 81.225681] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 81.232165] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 81.240437] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 81.247492] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 81.254814] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 81.261526] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 81.268313] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 81.274396] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 81.280800] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 81.287220] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 81.293927] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 81.300265] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 82.310554] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 82.318702] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 82.325185] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 82.333459] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 82.340516] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 82.347838] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 82.354550] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 82.361341] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 82.367424] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 82.373828] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 82.380247] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 82.386957] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 82.393295] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 83.403533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 83.411680] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 83.418164] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 83.426433] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 83.433487] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 83.440807] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 83.447516] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 83.454304] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 83.460386] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 83.466787] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 83.473203] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 83.479908] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 83.486245] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 84.496519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 84.504663] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 84.511142] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 84.519411] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 84.526463] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 84.533782] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 84.540490] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 84.547277] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 84.553359] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 84.559763] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 84.566182] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 84.572891] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 84.579231] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 85.589558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 85.597705] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 85.604187] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 85.612459] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 85.619516] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 85.626836] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 85.633548] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 85.640338] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 85.646422] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 85.652825] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 85.659245] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 85.665950] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 85.672286] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 86.682518] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 86.690659] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 86.697138] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 86.705404] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 86.712457] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 86.719776] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 86.726508] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 86.733297] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 86.739377] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 86.745778] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 86.752195] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 86.758901] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 86.765238] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 87.775558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 87.783702] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 87.790184] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 87.798454] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 87.805506] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 87.812827] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 87.819537] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 87.826326] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 87.832409] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 87.838812] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 87.845230] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 87.851938] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 87.858279] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 88.868534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 88.876679] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 88.883161] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 88.891428] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 88.898481] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 88.905801] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 88.912512] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 88.919299] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 88.925381] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 88.931783] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 88.938201] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 88.944908] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 88.951243] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 89.961557] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 89.969704] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 89.976184] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 89.984460] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 89.991512] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 89.998830] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 90.005539] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 90.012331] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 90.018414] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 90.024821] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 90.031243] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 90.037956] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 90.044299] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 91.055534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 91.063683] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 91.070169] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 91.078454] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 91.085513] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 91.092838] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 91.099552] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 91.106344] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 91.112432] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 91.118841] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 91.125264] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 91.131978] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 91.138324] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 92.149553] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 92.157705] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 92.164195] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 92.172467] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 92.179524] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 92.186846] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 92.193559] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 92.200349] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 92.206435] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 92.212840] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 92.219261] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 92.225970] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 92.232311] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 93.243534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 93.251683] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 93.258167] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 93.266450] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 93.273504] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 93.280826] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 93.287538] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 93.294327] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 93.300409] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 93.306815] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 93.313237] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 93.319947] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 93.326287] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 94.336517] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 94.344664] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 94.351145] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 94.359417] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 94.366470] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 94.373791] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 94.380501] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 94.387290] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 94.393371] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 94.399773] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 94.406188] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 94.412896] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 94.419237] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 95.429558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 95.437705] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 95.444186] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 95.452457] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 95.459511] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 95.466829] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 95.473539] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 95.480323] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 95.486406] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 95.492808] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 95.499228] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 95.505934] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 95.512273] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 96.522519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 96.530664] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 96.537146] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 96.545417] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 96.552471] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 96.559793] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 96.566504] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 96.573292] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 96.579373] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 96.585776] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 96.592194] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 96.598902] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 96.605241] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 97.615535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 97.623684] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 97.630168] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 97.638452] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 97.645507] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 97.652829] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 97.659541] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 97.666332] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 97.672417] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 97.678821] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 97.685243] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 97.691952] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 97.698294] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 98.709554] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 98.717703] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 98.724212] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 98.732489] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 98.739546] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 98.746868] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 98.753583] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 98.760373] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 98.766458] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 98.772862] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 98.779282] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 98.785989] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 98.792328] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 99.803534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 99.811679] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 99.818160] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 99.826428] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 99.833482] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 99.840802] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 99.847512] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 99.854297] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 99.860377] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 99.866775] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 99.873188] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 99.879889] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 99.886221] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 100.896558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 100.904700] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 100.911176] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 100.919452] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 100.926502] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 100.933819] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 100.940524] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 100.947310] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 100.953390] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 100.959787] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 100.966200] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 100.972904] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 100.979238] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 101.989534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 101.997676] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 102.004154] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 102.012426] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 102.019480] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 102.026803] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 102.033515] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 102.040305] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 102.046390] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 102.052794] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 102.059214] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 102.065921] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 102.072258] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 103.082553] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 103.090699] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 103.097182] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 103.105458] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 103.112512] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 103.119835] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 103.126548] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 103.133338] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 103.139422] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 103.145827] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 103.152247] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 103.158957] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 103.165295] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 104.175533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 104.183675] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 104.190154] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 104.198421] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 104.205471] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 104.212789] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 104.219496] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 104.226282] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 104.232363] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 104.238763] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 104.245176] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 104.251879] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 104.258215] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 105.268519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 105.276659] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 105.283136] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 105.291399] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 105.298455] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 105.305769] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 105.312477] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 105.319262] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 105.325342] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 105.331743] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 105.338158] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 105.344864] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 105.351198] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 106.361558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 106.369702] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 106.376181] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 106.384455] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 106.391507] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 106.398825] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 106.405535] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 106.412323] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 106.418405] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 106.424808] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 106.431226] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 106.437935] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 106.444275] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 107.454520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 107.462665] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 107.469147] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 107.477415] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 107.484469] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 107.491790] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 107.498502] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 107.505290] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 107.511373] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 107.517777] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 107.524195] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 107.530901] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 107.537244] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 108.547535] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 108.555680] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 108.562163] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 108.570435] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 108.577490] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 108.584811] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 108.591523] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 108.598311] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 108.604395] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 108.610799] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 108.617220] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 108.623931] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 108.630272] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 109.640554] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 109.648703] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 109.655188] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 109.663461] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 109.670513] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 109.677836] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 109.684549] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 109.691337] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 109.697422] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 109.703826] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 109.710249] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 109.716962] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 109.723327] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 110.734533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 110.742684] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 110.749171] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 110.757452] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 110.764510] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 110.771834] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 110.778547] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 110.785339] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 110.791422] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 110.797829] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 110.804249] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 110.810958] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 110.817303] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 111.828558] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 111.836707] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 111.843194] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 111.851467] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 111.858524] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 111.865848] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 111.872559] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 111.879349] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 111.885432] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 111.891835] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 111.898254] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 111.904962] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 111.911301] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 112.922533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 112.930679] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 112.937163] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 112.945435] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 112.952490] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 112.959811] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 112.966522] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 112.973312] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 112.979395] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 112.985798] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 112.992216] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 112.998923] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 113.005264] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 114.015557] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 114.023707] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 114.030192] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 114.038464] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 114.045521] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 114.052843] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 114.059558] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 114.066348] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 114.072431] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 114.078834] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 114.085252] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 114.091960] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 114.098299] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 115.109520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 115.117665] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 115.124147] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 115.132418] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 115.139472] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 115.146794] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 115.153506] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 115.160295] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 115.166381] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 115.172783] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 115.179199] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 115.185905] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 115.192244] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 116.202533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 116.210677] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 116.217159] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 116.225428] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 116.232483] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 116.239804] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 116.246515] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 116.253304] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 116.259387] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 116.265789] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 116.272208] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 116.278917] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 116.285258] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 117.295554] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 117.303702] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 117.310185] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 117.318459] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 117.325513] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 117.332835] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 117.339547] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 117.346337] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 117.352420] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 117.358823] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 117.365240] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 117.371948] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 117.378287] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 118.388532] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 118.396679] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 118.403162] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 118.411432] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 118.418487] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 118.425808] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 118.432519] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 118.439307] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 118.445390] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 118.451794] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 118.458212] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 118.464919] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 118.471255] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 119.481519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 119.489662] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 119.496142] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 119.504409] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 119.511461] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 119.518780] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 119.525490] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 119.532276] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 119.538358] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 119.544760] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 119.551176] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 119.557884] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 119.564222] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 120.574557] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 120.582702] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 120.589184] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 120.597459] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 120.604511] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 120.611833] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 120.618544] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 120.625334] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 120.631415] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 120.637817] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 120.644235] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 120.650940] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 120.657281] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 121.667517] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 121.675662] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 121.682146] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 121.690419] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 121.697476] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 121.704797] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 121.711510] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 121.718300] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 121.724408] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 121.730813] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 121.737232] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 121.743941] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 121.750280] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 122.760557] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 122.768703] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 122.775184] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 122.783454] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 122.790505] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 122.797824] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 122.804534] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 122.811320] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 122.817402] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 122.823805] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 122.830222] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 122.836932] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 122.843269] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 123.853533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 123.861679] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 123.868159] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 123.876423] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 123.883476] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 123.890791] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 123.897500] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 123.904285] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 123.910366] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 123.916768] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 123.923183] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 123.929888] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 123.936225] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 124.946557] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 124.954701] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 124.961182] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 124.969459] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 124.976511] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 124.983830] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 124.990538] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 124.997325] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 125.003406] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 125.009811] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 125.016233] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 125.022943] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 125.029286] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 126.039532] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 126.047682] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 126.054167] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 126.062451] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 126.069508] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 126.076829] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 126.083542] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 126.090331] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 126.096417] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 126.102822] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 126.109245] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 126.115959] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 126.122301] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 127.133554] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 127.141703] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 127.148190] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 127.156464] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 127.163522] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 127.170841] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 127.177552] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 127.184340] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 127.190424] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 127.196831] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 127.203252] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 127.209963] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 127.216308] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 128.227533] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 128.235684] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 128.242172] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 128.250454] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 128.257512] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 128.264837] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 128.271551] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 128.278343] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 128.284430] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 128.290834] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 128.297255] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 128.303965] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 128.310306] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 129.320520] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 129.328669] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 129.335155] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 129.343430] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 129.350486] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800040
[ 129.357811] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xed
[ 129.364526] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 129.371314] tegra-i2c tegra12-i2c.0: msg->len - 1
[ 129.377401] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 129.383806] tegra-i2c tegra12-i2c.0: next_msg->len - 2
[ 129.390228] tegra-i2c tegra12-i2c.0: is_next_msg_write - 0
[ 129.396939] tegra-i2c tegra12-i2c.0: buf_remaining - 2
[ 129.403280] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0xbe
[ 130.412555] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 130.420705] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 130.427189] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 130.435461] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 130.442516] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 130.449839] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 130.456551] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 130.463340] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 130.469425] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 130.475828] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 130.482251] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x80
[ 131.492519] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 131.500676] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 131.507159] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 131.515422] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 131.522467] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 131.529781] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 131.536481] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 131.543263] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 131.549344] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 131.555771] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 131.562287] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x63
[ 132.572534] tegra-i2c tegra12-i2c.0: — register dump for debugging ----
[ 132.580725] tegra-i2c tegra12-i2c.0: I2C_CNFG - 0x2c00
[ 132.587237] tegra-i2c tegra12-i2c.0: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 132.595510] tegra-i2c tegra12-i2c.0: I2C_FIFO_CONTROL - 0xe0
[ 132.602551] tegra-i2c tegra12-i2c.0: I2C_FIFO_STATUS - 0x800070
[ 132.609855] tegra-i2c tegra12-i2c.0: I2C_INT_MASK - 0xec
[ 132.616542] tegra-i2c tegra12-i2c.0: I2C_INT_STATUS - 0x0
[ 132.623318] tegra-i2c tegra12-i2c.0: msg->len - 3
[ 132.629388] tegra-i2c tegra12-i2c.0: is_msg_write - 1
[ 132.635809] tegra-i2c tegra12-i2c.0: buf_remaining - 0
[ 132.642323] tegra-i2c tegra12-i2c.0: i2c transfer timed out, addr 0x001c, data 0x64
[ 132.652725] rt5639 0-001c: rt5639_headset_detect jack_type = 4
[ 132.660270] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 132.672001] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 132.683762] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 132.695805] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 132.707959] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 132.720018] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 132.731337] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 132.742672] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 132.756631] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 132.771628] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 132.783857] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 132.796258] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 132.811128] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 132.832721] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
