HDMI stopped working
The HDMI output on my new B01 seems to have stopped working. I can still SSH into it, so I know it’s on and functioning, but I’m getting no more signal. I’ve tried swapping HDMI cables, as well as the port on the monitor, but there just doesn’t seem to be any signal. Just for kicks I tried using the USB-C for power instead of the barrel jack, but that didn’t work either (not that I thought it would) but I wanted to try everything I could. I disconnected all peripherals, and I still have no video
Can anybody think of anything I’m missing ?
It is necessary to share your dmesg when you want to debug such issue.
Please try to hotplug your HDMI cable and then dump the dmesg and share with us.
This is my third time trying to make this readable
jetbot@jetbot:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc ver sion 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7 f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 201 9
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_c arveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_c arveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nv idia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id n vidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible i d nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d326 16 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M secti on=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvf s=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debu g_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_ scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root =/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net. ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29492(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes )
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3576064K/4159488K available (15166K kernel code, 2914K rw data, 6616K rodata, 8512K init, 605K bss, 108288K reserved, 475136K cma-reserved )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 M B)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 G B)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 K B)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 K B)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 K B)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 K B)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 K B)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 K B)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 M B)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 G B maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 M B actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 M B)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /inte rrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (ph ys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980 46511078ns
[ 0.001388] Console: colour dummy device 80x25
[ 0.002232] console [tty0] enabled
[ 0.002257] kmemleak: Kernel memory leak detector disabled
[ 0.002285] Calibrating delay loop (skipped), value calculated using timer fr equency… 38.40 BogoMIPS (lpj=76800)
[ 0.002313] pid_max: default: 32768 minimum: 301
[ 0.002766] Security Framework initialized
[ 0.002997] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003018] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004132] ftrace: allocating 46802 entries in 183 pages
[ 0.175677] sched-energy: CPU device node has no sched-energy-costs
[ 0.175710] ASID allocator initialised with 65536 entries
[ 0.211202] tegra-id: chipid=22117.
[ 0.211244] tegra-id: opt_subrevision=0.
[ 0.211272] Tegra Speedo/IDDQ fuse revision 4
[ 0.211287] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211302] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211318] Tegra: CPU Speedo Value 2061, SoC Speedo Value 1952, GPU Speedo V alue 2069
[ 0.211339] Tegra: CPU IDDQ Value 2304, SoC IDDQ Value 2456, GPU IDDQ Value 3 110
[ 0.211372] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211397] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/ arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel- dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211431] DTB Build time: Mar 15 2019 09:52:07
[ 0.261048] CPU1: Booted secondary processor [411fd071]
[ 0.292944] CPU2: Booted secondary processor [411fd071]
[ 0.324932] CPU3: Booted secondary processor [411fd071]
[ 0.325019] Brought up 4 CPUs
[ 0.325078] SMP: Total of 4 processors activated.
[ 0.325094] CPU features: detected feature: 32-bit EL0 Support
[ 0.325368] CPU: All CPU(s) started at EL2
[ 0.325397] alternatives: patching kernel code
[ 0.333383] devtmpfs: initialized
[ 0.367825] Initilizing CustomIPI irq domain
[ 0.368242] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.368288] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.378778] pinctrl core: initialized pinctrl subsystem
[ 0.379409] OS set in device tree is not L4T.
[ 0.379810] regulator-dummy: no parameters
[ 0.380094] Initializing plugin-manager
[ 0.380254] Plugin module not found
[ 0.380474] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.381020] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.384773] NET: Registered protocol family 16
[ 0.386207] pstore: using zlib compression
[ 0.386839] console [pstore-1] enabled
[ 0.386857] pstore: Registered ramoops as persistent store backend
[ 0.386875] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.401065] cpuidle: using governor menu
[ 0.404749] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.406172] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e240 00)
[ 0.406219] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.409462] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomi c allocations
[ 0.410905] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.411830] tegra_powergate_init: DONE
[ 0.411867] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/ arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel- dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.411903] DTB Build time: Mar 15 2019 09:52:07
[ 0.413473] Tegra reboot handler registered.
[ 0.417797] iommu: Adding device tegra-carveouts to group 0
[ 0.417969] platform tegra-carveouts: domain=ffffffc0f9bf8318 allocates as[0] =ffffffc0f9be80a8
[ 0.418351] iommu: Adding device smmu_test to group 1
[ 0.418417] platform smmu_test: domain=ffffffc0f9bf8558 allocates as[0]=fffff fc0f9be8110
[ 0.419235] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.419308] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.419381] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.419403] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.419436] mc-err: mcerr ops are set to t21x
[ 0.429155] iommu: Adding device 70090000.xusb to group 2
[ 0.429475] iommu: Adding device 70006000.serial to group 3
[ 0.429578] platform 70006000.serial: domain=ffffffc0f9484618 allocates as[0] =ffffffc0f9be8178
[ 0.430010] iommu: Adding device 70006040.serial to group 4
[ 0.430295] iommu: Adding device 70006200.serial to group 5
[ 0.430530] iommu: Adding device sound to group 6
[ 0.430590] platform sound: domain=ffffffc0f9484b58 allocates as[0]=ffffffc0f 9be81e0
[ 0.431156] iommu: Adding device 7000d400.spi to group 7
[ 0.431435] iommu: Adding device 7000d600.spi to group 8
[ 0.431721] iommu: Adding device 70410000.spi to group 9
[ 0.432043] iommu: Adding device 50000000.host1x to group 10
[ 0.432330] iommu: Adding device 54080000.vi to group 11
[ 0.432737] iommu: Adding device 54600000.isp to group 12
[ 0.433051] iommu: Adding device 54680000.isp to group 13
[ 0.433379] iommu: Adding device tegradc.0 to group 14
[ 0.433448] platform tegradc.0: domain=ffffffc0f9491a98 allocates as[0]=fffff fc0f9be8248
[ 0.433987] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.434313] iommu: Adding device tegradc.1 to group 15
[ 0.434375] platform tegradc.1: domain=ffffffc0f9491cd8 allocates as[0]=fffff fc0f9be82b0
[ 0.434902] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.435161] iommu: Adding device 54340000.vic to group 16
[ 0.435387] iommu: Adding device 544c0000.nvenc to group 17
[ 0.435600] iommu: Adding device 54500000.tsec to group 18
[ 0.435817] iommu: Adding device 54100000.tsecb to group 19
[ 0.436035] iommu: Adding device 54480000.nvdec to group 20
[ 0.436273] iommu: Adding device 54380000.nvjpg to group 21
[ 0.437415] iommu: Adding device 546c0000.i2c to group 22
[ 0.437763] iommu: Adding device 57000000.gpu to group 23
[ 0.437829] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[0]=ff ffffc0f9be8318
[ 0.437887] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[1]=ff ffffc0f9be8380
[ 0.437949] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[2]=ff ffffc0f9be83e8
[ 0.438005] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[3]=ff ffffc0f9be8450
[ 0.438896] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency t hermal reset disabled.
[ 0.438939] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.438966] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.438987] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.439003] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.489131] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registere d
[ 0.489165] tegra-pmc: Clear bootloader IO dpd settings
[ 0.489202] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.489282] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.489596] iommu: Adding device 70012000.se to group 24
[ 0.490455] iommu: Adding device 7000c000.i2c to group 25
[ 0.490729] iommu: Adding device 7000c400.i2c to group 26
[ 0.491058] iommu: Adding device 7000c500.i2c to group 27
[ 0.491331] iommu: Adding device 7000c700.i2c to group 28
[ 0.491689] iommu: Adding device 7000d000.i2c to group 29
[ 0.492016] iommu: Adding device 7000d100.i2c to group 30
[ 0.492378] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.492446] platform sdhci-tegra.0: domain=ffffffc0f952ce58 allocates as[0]=f fffffc0f9be84b8
[ 0.493387] iommu: Adding device 700d0000.xudc to group 32
[ 0.498840] vdd-ac-bat: 5000 mV
[ 0.499265] vdd-5v0-sys: 5000 mV
[ 0.500234] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.500319] vdd-5v0-hdmi: 5000 mV
[ 0.500749] vdd-1v8: 1800 mV
[ 0.501210] vdd-fan: supplied by vdd-5v0-sys
[ 0.501264] vdd-fan: 5000 mV
[ 0.501716] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.501793] vdd-usb-vbus: 5000 mV
[ 0.502319] vdd-usb-vbus2: 5000 mV
[ 0.534001] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.536533] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.536598] GPIO line 6 (system-suspend-gpio) hogged as output/low
[ 0.536969] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip 0 (tegra-gpio)
[ 0.545040] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.545424] SCSI subsystem initialized
[ 0.545670] libata version 3.00 loaded.
[ 0.545949] usbcore: registered new interface driver usbfs
[ 0.546025] usbcore: registered new interface driver hub
[ 0.546115] usbcore: registered new device driver usb
[ 0.550060] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.551877] random: fast init done
[ 0.556378] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.557644] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.560228] vdd-ddr-1v1: 1150 mV
[ 0.564227] vdd-pre-reg-1v35: 1350 mV
[ 0.568226] vdd-1v8: 1800 mV
[ 0.568504] vdd-1v8: Failed to create debugfs directory
[ 0.572225] avdd-sys-1v2: 1200 mV
[ 0.576225] vdd-pex-1v0: 1050 mV
[ 0.576998] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.577635] max77620-ldo3: at 3100 mV
[ 0.580230] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.580912] max77620-ldo5: at 3100 mV
[ 0.581571] max77620-ldo6: at 2800 mV
[ 0.584231] avdd-1v05-pll: 1050 mV
[ 0.588225] avdd-io-hdmi-dp: 1050 mV
[ 0.589772] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.590054] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpioch ip1 (max77620-gpio)
[ 0.592157] max77620 4-003c: max77620 probe successful
[ 0.594343] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.594879] media: Linux media interface: v0.10
[ 0.595010] Linux video capture interface: v2.00
[ 0.595952] pps_core: LinuxPPS API ver. 1 registered
[ 0.595978] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti giometti@linux.it
[ 0.596021] PTP clock support registered
[ 0.599285] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.605508] tegra210-emc 7001b000.external-memory-controller: validated EMC D FS table
[ 0.606355] Advanced Linux Sound Architecture Driver Initialized.
[ 0.607014] Bluetooth: Core ver 2.22
[ 0.607084] NET: Registered protocol family 31
[ 0.607102] Bluetooth: HCI device and connection manager initialized
[ 0.607130] Bluetooth: HCI socket layer initialized
[ 0.607151] Bluetooth: L2CAP socket layer initialized
[ 0.607187] Bluetooth: SCO socket layer initialized
[ 0.608814] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.608849] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.608913] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.608941] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.611656] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering pr obe
[ 0.612990] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.613164] vdd-3v3-sys: 3300 mV
[ 0.613449] vdd-1v8: supplied by vdd-3v3-sys
[ 0.617130] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.617675] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.617725] vdd-3v3-sd: 3300 mV
[ 0.618956] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.619018] avdd-io-edp-1v05: 1050 mV
[ 0.619474] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.619549] vdd-usb-hub-en: 5000 mV
[ 0.620876] camchar: rtcpu character device driver loaded
[ 0.621653] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.622998] clocksource: Switched to clocksource arch_sys_counter
[ 0.663826] VFS: Disk quotas dquot_6.6.0
[ 0.663992] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.664502] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.664945] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr , base=0x00000000d7000000, size=0x19000000
[ 0.664995] dma-vpr: heap size is not multiple of cma_chunk_size heap_info-> num_chunks (13) rem_chunk_size(0x1000000)
[ 0.665209] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.665232] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap =vpr create successful
[ 0.665258] tegra-carveouts tegra-carveouts: assigned reserved memory node vp r-carveout
[ 0.665310] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0 x0000000040001000,258048
[ 0.665335] tegra-carveouts tegra-carveouts: assigned reserved memory node ir am-carveout
[ 0.665367] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.665388] nvmap_page_pool_init: Total RAM pages: 1012800
[ 0.665405] nvmap_page_pool_init: nvmap page pool size: 126600 pages (494 MB)
[ 0.665516] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.665955] misc nvmap: created heap iram base 0x0000000040001000 size (252Ki B)
[ 0.666905] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600 KiB)
[ 0.674944] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.675375] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.675652] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.675883] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.676089] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.676371] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.676389] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.676839] NET: Registered protocol family 2
[ 0.677833] TCP established hash table entries: 32768 (order: 6, 262144 bytes )
[ 0.678069] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.678578] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.678740] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.678840] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.679348] NET: Registered protocol family 1
[ 0.680047] RPC: Registered named UNIX socket transport module.
[ 0.680076] RPC: Registered udp transport module.
[ 0.680092] RPC: Registered tcp transport module.
[ 0.680109] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.680133] PCI: CLS 0 bytes, default 64
[ 0.680375] Trying to unpack rootfs image as initramfs…
[ 0.689343] host1x 50000000.host1x: initialized
[ 0.691460] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av ailable
[ 0.694693] audit: initializing netlink subsys (disabled)
[ 0.694789] audit: type=2000 audit(0.543:1): initialized
[ 0.695600] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.705637] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.707182] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.707991] 9p: Installing v9fs 9p2000 file system support
[ 0.711279] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 40)
[ 0.711449] io scheduler noop registered
[ 0.711753] io scheduler cfq registered (default)
[ 0.714384] gic 702f9000.agic: GIC IRQ controller registered
[ 0.717385] iommu: Adding device 702ef000.adsp to group 33
[ 0.724504] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.724692] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.725293] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x6227c0c
[ 0.725325] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_ 0 = 0x4
[ 0.726946] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.727124] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.727266] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.727494] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.727605] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.727719] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.727830] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.727935] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.728043] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.728152] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.734535] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.735882] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.737724] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.739078] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.739452] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.740644] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:c amera_platform_driver probe
[ 0.740891] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1 500000, vi_iso_bw=750000, max_bw=1500000
[ 0.741157] Adding domain tsec-pd to PM domain host1x-pd
[ 0.743144] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.744136] tsec 54500000.tsec: initialized
[ 0.745784] tsec 54100000.tsecb: initialized
[ 0.746486] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.749553] nvdec 54480000.nvdec: initialized
[ 0.750610] Adding domain vic03-pd to PM domain host1x-pd
[ 0.750806] Adding domain msenc-pd to PM domain host1x-pd
[ 0.751016] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.754733] falcon 54340000.vic: initialized
[ 0.756046] falcon 544c0000.nvenc: initialized
[ 0.757377] falcon 54380000.nvjpg: initialized
[ 0.761828] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.761957] display board info: id 0x0, fab 0x0
[ 0.762034] generic_infoframe_type: 0x87
[ 0.762173] tegradc tegradc.0: DT parsed successfully
[ 0.762233] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id =0
[ 0.765740] tegradc tegradc.0: probed
[ 0.769828] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 cha nnels
[ 0.774607] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 chan nels
[ 0.775517] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initi alized
[ 0.775879] kfuse 7000fc00.kfuse: initialized
[ 0.777439] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:0 0
[ 0.777495] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.777518] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 0.777544] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pre f]
[ 0.777573] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.777654] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 0.777830] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.778306] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-suppl y not available
[ 0.778340] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 0.778475] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.778765] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 0.778807] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 0.779160] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 0.779232] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 0.779504] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.779597] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.781029] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.781071] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.781551] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator regis tration passed
[ 0.783515] vdd-gpu: applied init 1000000uV constraint
[ 0.783550] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.784007] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator regis tration passed
[ 0.788515] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.788699] No Device Node present for smmu client: serial8250 !!
[ 0.788731] platform serial8250: No iommus property found in DT node, got swg ids from fixup(101004000)
[ 0.788814] iommu: Adding device serial8250 to group 35
[ 0.791245] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.791582] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.791631] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 0.791688] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 0.791720] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 0.791985] pci 0000:02:00.0: supports D1 D2
[ 0.791991] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.792160] console [ttyS0] disabled
[ 0.792312] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 0.819195] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.819283] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 0.819289] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 0.819293] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.819302] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bi t]
[ 0.819333] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.819341] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 0.819353] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bi t]
[ 0.819378] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bi t]
[ 0.819401] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 0.819410] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.819414] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 0.819420] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 0.820445] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.820451] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.820459] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 0.820595] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 0.820815] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 0.820820] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.820826] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 0.820927] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.160644] console [ttyS0] enabled
[ 3.161009] Console: switching to colour frame buffer device 80x30
[ 3.162052] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.163291] serial-tegra 70006200.serial: RX in PIO mode
[ 3.163397] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.164542] [drm] Initialized
[ 3.186173] brd: module loaded
[ 3.198589] loop: module loaded
[ 3.198689] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.200210] tegra_profiler: auth: init
[ 3.204321] THERMAL EST: found 2 subdevs
[ 3.204327] THERMAL EST num_resources: 0
[ 3.204332] [THERMAL EST subdev 0]
[ 3.204339] [THERMAL EST subdev 1]
[ 3.204796] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.204798] THERMAL EST: thz register success.
[ 3.204953] THERMAL EST: end of probe, return err: 0
[ 3.206229] hisi_sas: driver version v1.6
[ 3.210129] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.213035] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.213052] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4M iB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.223025] libphy: Fixed MDIO Bus: probed
[ 3.223653] tun: Universal TUN/TAP device driver, 1.6
[ 3.223656] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.224650] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.224652] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.224710] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.224712] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.224756] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.224758] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.224799] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.224802] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.225734] r8168 0000:02:00.0: enabling device (0000 → 0003)
[ 3.225764] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.240328] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.240479] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found va lid ethernet address 00:04:4b:ec:08:09 from device tree
[ 3.241068] r8168: This product is covered by one or more of the following pa tents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.241108] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@real tek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, ple ase see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it un der certain conditions; see http://www.gnu.org/licenses/.
[ 3.241673] PPP generic driver version 2.4.2
[ 3.241883] PPP BSD Compression module registered
[ 3.241889] PPP Deflate Compression module registered
[ 3.241932] PPP MPPE Compression module registered
[ 3.241939] NET: Registered protocol family 24
[ 3.242014] usbcore: registered new interface driver r8152
[ 3.242057] usbcore: registered new interface driver asix
[ 3.242133] usbcore: registered new interface driver ax88179_178a
[ 3.242181] usbcore: registered new interface driver cdc_ether
[ 3.242216] usbcore: registered new interface driver net1080
[ 3.242251] usbcore: registered new interface driver cdc_subset
[ 3.242296] usbcore: registered new interface driver zaurus
[ 3.242353] usbcore: registered new interface driver cdc_ncm
[ 3.242526] VFIO - User Level meta-driver version: 0.3
[ 3.244056] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.244080] ehci-pci: EHCI PCI platform driver
[ 3.244136] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.244148] ohci-pci: OHCI PCI platform driver
[ 3.244191] ohci-platform: OHCI generic platform driver
[ 3.246824] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.247655] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.248848] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f90f0000 id
[ 3.248958] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_ firmware failed with error -2
[ 3.248961] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.250227] usbcore: registered new interface driver uas
[ 3.250291] usbcore: registered new interface driver usb-storage
[ 3.250392] usbcore: registered new interface driver usbserial
[ 3.253432] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.254751] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.254766] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.254806] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.255132] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.255812] mousedev: PS/2 mouse device common for all mice
[ 3.255895] usbcore: registered new interface driver xpad
[ 3.502746] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as r tc0
[ 3.515373] rtc rtc1: alarm rtc device
[ 3.515390] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.515418] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.515957] i2c /dev entries driver
[ 3.517673] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.547229] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.547305] imx219 6-0010: imx219_board_setup: error during i2c read probe (- 121)
[ 3.547337] imx219 6-0010: board setup failed
[ 3.547439] imx219: probe of 6-0010 failed with error -121
[ 3.553356] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.593985] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.593990] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.594418] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.594435] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.594444] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when c pu reaches 100500 mC
[ 3.594569] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.594578] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.594583] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when g pu reaches 101000 mC
[ 3.594726] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.594735] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.594740] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot tem perature
[ 3.594942] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.595823] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.595877] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.595905] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.595921] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.595931] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.596871] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.596890] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.597071] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.597101] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling devi ce’ registered
[ 3.597536] parse_throttle_dt_data: Num cap clks = 6
[ 3.597542] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.597556] parse_throttle_dt_data: clk=gpu type=4
[ 3.597581] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.597601] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.597623] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.597626] parse_throttle_dt_data: clk=emc type=3
[ 3.599038] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.599144] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 3.599279] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.600036] FAN dev name: pwm-fan
[ 3.600086] FAN:gpio request success.
[ 3.600160] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.600459] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.600665] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.600677] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.600772] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, st ate:2
[ 3.600778] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.600782] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.600786] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.600789] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.600793] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.600796] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.600800] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.600804] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1 , state:4
[ 3.600807] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1 , state:4
[ 3.601491] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.601928] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowa yout = 1)
[ 3.602871] device-mapper: uevent: version 1.0.3
[ 3.603408] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-d evel@redhat.com
[ 3.608653] tegra210-cpufreq cpufreq: probe()…completed
[ 3.609490] sdhci: Secure Digital Host Controller Interface driver
[ 3.609491] sdhci: Copyright(c) Pierre Ossman
[ 3.609492] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.609980] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.610338] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.610462] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.614125] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.614616] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.616173] usbcore: registered new interface driver usbhid
[ 3.616175] usbhid: USB HID core driver
[ 3.635439] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.635755] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.637455] nvpmodel: initialized successfully
[ 3.638407] usbcore: registered new interface driver snd-usb-audio
[ 3.638469] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.638473] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.638489] iommu: Adding device snd-soc-dummy to group 36
[ 3.651083] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADM A 64-bit with 64 bit addr
[ 3.667773] OPE platform probe
[ 3.667864] OPE platform probe successful
[ 3.668262] OPE platform probe
[ 3.668347] OPE platform probe successful
[ 3.693863] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.693991] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.694114] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.694243] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.694366] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.694487] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.694615] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.694735] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.694858] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.694996] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.707393] u32 classifier
[ 3.707394] Actions configured
[ 3.707467] Initializing XFRM netlink socket
[ 3.708197] NET: Registered protocol family 10
[ 3.708898] NET: Registered protocol family 17
[ 3.708908] NET: Registered protocol family 15
[ 3.708980] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.716179] Bluetooth: RFCOMM socket layer initialized
[ 3.716188] Bluetooth: RFCOMM ver 1.11
[ 3.716192] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.716196] Bluetooth: HIDP socket layer initialized
[ 3.716214] 9pnet: Installing 9P2000 support
[ 3.716255] Key type dns_resolver registered
[ 3.725387] Registered cp15_barrier emulation handler
[ 3.725442] Registered setend emulation handler
[ 3.726581] registered taskstats version 1
[ 3.727236] Adding domain ve2-pd to PM domain host1x-pd
[ 3.727474] Adding domain ve-pd to PM domain host1x-pd
[ 3.826768] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/car d0/input0
[ 4.319869] tegradc tegradc.0: fb registered
[ 4.324818] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.331230] tegradc tegradc.1: No lt-data, using default setting
[ 4.337265] tegradc tegradc.1: No hpd-gpio in DT
[ 4.341910] tegradc tegradc.1: DT parsed successfully
[ 4.346995] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id =1
[ 4.354950] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.865937] Host read timeout at address 545c00c4
[ 4.866513] tegradc tegradc.1: probed
[ 4.881111] tegradc tegradc.1: fb registered
[ 4.888531] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.890701] isp 54600000.isp: initialized
[ 4.891509] isp 54680000.isp: initialized
[ 4.903098] clk_cbus_recalc_rate: no gbus parent
[ 4.903102] clk_cbus_round_rate: no gbus parent
[ 4.903104] clk_cbus_round_rate: no gbus parent
[ 4.903110] clk_cbus_recalc_rate: no gbus parent
[ 4.903208] clk_cbus_recalc_rate: no gbus parent
[ 4.903210] clk_cbus_round_rate: no gbus parent
[ 4.903211] clk_cbus_round_rate: no gbus parent
[ 4.903214] clk_cbus_recalc_rate: no gbus parent
[ 4.903227] tegra_dvfs: GPU-cap: registered
[ 4.903287] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200u V, scaling enabled
[ 4.903289] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500 uV, scaling enabled
[ 4.903290] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000u V, scaling enabled
[ 4.953654] tegra_dvfs: vdd-gpu-vts: registered
[ 4.975516] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.983370] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.988875] tegradc tegradc.1: blank - powerdown
[ 4.988930] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor co oling device’ registered
[ 4.989527] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap coolin g device’ registered
[ 4.990061] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.017547] extcon-disp-state extcon:disp-state: cable 44 state 0 already set .
[ 5.024775] Extcon DP: HPD disabled
[ 5.028271] hpd: hpd_switch 0
[ 5.031255] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.037888] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.043804] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00: 34 UTC (946688434)
[ 5.044706] vi 54080000.vi: vi_probe: ++
[ 5.056480] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.066877] vi 54080000.vi: initialized
[ 5.073243] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.079272] Disable partitions left on by BL
[ 5.083554] disb
[ 5.085605] bwmgr: missing cdev-type property
[ 5.089063] mmc0: Applying tuning correction
[ 5.089076] mmc0: Tap value after applying correction 61
[ 5.089092] mmc0: hw tuning done …
[ 5.089123] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 5.089483] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[ 5.094809] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 5.119974] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -214 7483647 forced to -127000
[ 5.129279] DRAM derating cdev registered.
[ 5.134605] vdd-fan: disabling
[ 5.137671] vdd-usb-vbus: disabling
[ 5.141164] vdd-usb-vbus2: disabling
[ 5.144747] avdd-io-edp-1v05: disabling
[ 5.148583] vdd-usb-hub-en: disabling
[ 5.152410] ALSA device list:
[ 5.155387] #0: tegra-hda at 0x70038000 irq 83
[ 5.160001] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.178635] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. O pts: (null)
[ 5.186751] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.195599] devtmpfs: mounted
[ 5.201639] Freeing unused kernel memory: 8512K
[ 5.435411] systemd[1]: System time before build time, advancing clock.
[ 5.487090] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.503366] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.524755] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL + XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr id)
[ 5.546819] systemd[1]: Detected architecture arm64.
[ 5.576101] systemd[1]: Set hostname to .
[ 5.668201] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not sup port BPF/cgroup based firewalling.
[ 5.685372] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warni ng is only shown for the first loaded unit using IP firewalling.)
[ 5.890039] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.898521] systemd[1]: Created slice User and Session Slice.
[ 5.904660] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.911331] systemd[1]: Reached target User and Group Name Lookups.
[ 5.917718] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.924464] systemd[1]: Started ntp-systemd-netif.path.
[ 5.929933] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ 5.937636] systemd[1]: Reached target System Time Synchronized.
[ 5.995113] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.180928] systemd-journald[1890]: Received request to flush runtime journal from PID 1
[ 6.190809] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 6.431322] Adding 4194300k swap on /var/swapfile. Priority:-1 extents:15 ac ross:6569980k SS
[ 7.167188] using random self ethernet address
[ 7.180432] using random host ethernet address
[ 7.264055] Mass Storage Function, version: 2009/09/11
[ 7.264061] LUN: removable file: (no medium)
[ 7.271562] using random self ethernet address
[ 7.280366] using random host ethernet address
[ 7.296760] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 s econd
[ 7.303479] rndis0: HOST MAC 72:b5:f7:73:b7:5c
[ 7.303637] rndis0: MAC 72:b5:f7:73:b7:5d
[ 7.305219] usb0: HOST MAC 72:b5:f7:73:b7:5e
[ 7.305247] usb0: MAC 72:b5:f7:73:b7:5f
[ 7.305266] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 7.307261] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 7.307277] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.307304] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 7.307559] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 7.307575] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 7.308157] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 7.308178] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 7.308404] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 7.448685] l4tbr0: port 1(rndis0) entered blocking state
[ 7.448690] l4tbr0: port 1(rndis0) entered disabled state
[ 7.450659] device rndis0 entered promiscuous mode
[ 7.459024] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.464008] l4tbr0: port 2(usb0) entered blocking state
[ 7.464013] l4tbr0: port 2(usb0) entered disabled state
[ 7.464172] device usb0 entered promiscuous mode
[ 7.465874] random: crng init done
[ 7.469282] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.478387] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.478395] l4tbr0: port 2(usb0) entered blocking state
[ 7.478398] l4tbr0: port 2(usb0) entered forwarding state
[ 7.492130] nvs_dsm nvs_dsm: dsm_probe
[ 7.492153] nvs_dsm nvs_dsm: dsm_remove
[ 7.492156] nvs_dsm nvs_dsm: dsm_probe done
[ 7.666331] Intel(R) Wireless WiFi driver for Linux
[ 7.666335] Copyright(c) 2003- 2015 Intel Corporation
[ 7.666567] iwlwifi 0000:01:00.0: enabling device (0000 → 0002)
[ 7.880296] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.uc ode failed with error -2
[ 7.891924] iwlwifi 0000:01:00.0: Falling back to user helper
[ 8.307113] l4tbr0: port 2(usb0) entered disabled state
[ 8.321195] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 8.321232] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.321251] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus nu mber 1
[ 8.322109] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 8.322143] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 8.322357] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.322362] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 8.322365] usb usb1: Product: xHCI Host Controller
[ 8.322368] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.322371] usb usb1: SerialNumber: 70090000.xusb
[ 8.348567] hub 1-0:1.0: USB hub found
[ 8.348632] hub 1-0:1.0: 5 ports detected
[ 8.349042] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.349052] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus nu mber 2
[ 8.349139] usb usb2: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 8.349214] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.349218] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 8.349222] usb usb2: Product: xHCI Host Controller
[ 8.349224] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.349227] usb usb2: SerialNumber: 70090000.xusb
[ 8.349630] hub 2-0:1.0: USB hub found
[ 8.349697] hub 2-0:1.0: 4 ports detected
[ 8.451433] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 8.451548] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 8.675041] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.704463] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 8.704469] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.704473] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 8.704477] usb 1-2: Manufacturer: Generic
[ 8.730375] hub 1-2:1.0: USB hub found
[ 8.731016] hub 1-2:1.0: 4 ports detected
[ 8.746516] nvgpu: 57000000.gpu railgate_enable_store:343 [INFO] railgate is disabled.
[ 8.815631] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.844265] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.844272] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.844277] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.844280] usb 2-1: Manufacturer: Generic
[ 8.848306] hub 2-1:1.0: USB hub found
[ 8.849130] hub 2-1:1.0: 4 ports detected
[ 8.872025] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.873164] eth0: 0xffffff800a2fe000, 00:04:4b:ec:08:09, IRQ 404
[ 8.951121] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.959036] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.981548] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 8.981555] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.007036] usb 2-1: usb_suspend_both: status 0
[ 9.007273] usb usb2: usb_suspend_both: status 0
[ 9.059029] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 9.083421] usb 1-2.3: New USB device found, idVendor=046d, idProduct=c534
[ 9.083429] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber =0
[ 9.083432] usb 1-2.3: Product: USB Receiver
[ 9.083436] usb 1-2.3: Manufacturer: Logitech
[ 9.086670] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1 -2.3/1-2.3:1.0/0003:046D:C534.0001/input/input2
[ 9.143981] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Key board [Logitech USB Receiver] on usb-70090000.xusb-2.3/input0
[ 9.147535] input: Logitech USB Receiver as /devices/70090000.xusb/usb1/1-2/1 -2.3/1-2.3:1.1/0003:046D:C534.0002/input/input3
[ 9.179321] IRQ11 no longer affine to CPU2
[ 9.187028] CPU2: shutdown
[ 9.189771] psci: CPU2 killed.
[ 9.207816] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mou se [Logitech USB Receiver] on usb-70090000.xusb-2.3/input1
[ 9.231304] IRQ12 no longer affine to CPU3
[ 9.236337] CPU3: shutdown
[ 9.243347] psci: CPU3 killed.
[ 10.460923] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.uc ode failed with error -2
[ 10.475150] iwlwifi 0000:01:00.0: Falling back to user helper
[ 11.488128] tegradc tegradc.0: blank - powerdown
[ 11.488140] tegradc tegradc.1: blank - powerdown
[ 12.492500] usbcore: registered new interface driver btusb
[ 12.499662] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 12.500658] Bluetooth: hci0: Device revision is 16
[ 12.500663] Bluetooth: hci0: Secure boot is enabled
[ 12.500666] Bluetooth: hci0: OTP lock is enabled
[ 12.500668] Bluetooth: hci0: API lock is enabled
[ 12.500671] Bluetooth: hci0: Debug lock is disabled
[ 12.500675] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 12.510047] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 12.972346] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.uc ode failed with error -2
[ 12.985077] iwlwifi 0000:01:00.0: Falling back to user helper
[ 13.054552] r8168: eth0: link up
[ 13.054723] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.219311] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.219324] Bluetooth: BNEP socket layer initialized
[ 13.303867] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.uc ode failed with error -2
[ 13.317133] iwlwifi 0000:01:00.0: Falling back to user helper
[ 13.562014] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 13.689397] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 826 5, REV=0x230
[ 13.691466] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 13.692701] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 13.819928] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 13.821772] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 13.832350] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 14.087610] Bluetooth: hci0: Waiting for firmware download to complete
[ 14.088627] Bluetooth: hci0: Firmware loaded in 1559048 usecs
[ 14.088787] Bluetooth: hci0: Waiting for device to boot
[ 14.100617] Bluetooth: hci0: Device booted in 11623 usecs
[ 14.101404] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 14.104639] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 14.173816] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 14.182819] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 14.183503] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 14.349586] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 14.350021] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 14.446137] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 14.645050] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 18.120739] fuse init (API version 7.26)
[ 46.440303] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 56.691581] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 74.833429] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 84.839741] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 105.482501] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 115.553419] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 133.857586] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 143.974676] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 161.294049] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 171.376289] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 189.158896] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 199.285434] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 216.626261] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 226.680863] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 244.135616] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 254.331072] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 271.530426] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 281.720840] tegra-i2c 7000c400.i2c: timed out for bus clear
[ 299.150867] tegra-i2c 7000c400.i2c: arb lost in communicate to add 0x3c
[ 309.366274] tegra-i2c 7000c400.i2c: timed out for bus clear
jetbot@jetbot:~$
dmesg.log (64.2 KB)
Maybe the log will be easier to read
Hi spyder19,
Does the last i2c error comes when you hotplug the hdmi cable?
This is the detailed step to dump the log we want.
  1. Connect the HDMI cable to Nano and press to power button.
  2. After system is up, if there is no signal over monitor, please unplug/plug the HDMI cable once.
  3. Use command “dmesg” and share the log.
Was this what you’ve tried?
No. I started the computer with the HDMI unplugged, then waited til I could log in, then I plugged in the HDMI. I didn’t start it with HDMI plugged in.
This time, I started the computer with HDMI plugged in, waited a few seconds to see if it worked, saw no output on the display, logged in thru SSH, unplugged HDMI, waited a few seconds, then plugged in the HDMI, still saw no display, then
grabbed the dmesg
So here’s the new dmesg…
dmesg2.log (56.7 KB)
Unfortunately I think it is hardware issue on your device.
You should file a RMA request.
How should I initiate it ?
Hi spyder19,
Please the RMA process from Jetson FAQ | NVIDIA Developer
Thank you. I got the RMA process accelerated due to my interactions with Wayne. The device was sent out last Saturday via fedex with the return label that was emailed to me in the RMA process and I am waiting to hear something back from somebody
I have the tracking number if you’d like
