- Regarding the HDMI connection, in the OEM DG series resistors (Rs ~ 6 ohm) supposed to be after the ESD protection wiring, but in the devkit schematics you place it before the ESD protection, what is the correct one?
- If I want to use the EMI protection, in the devkit schematics you place it in parallel with Rs resistors. So, do I still need the Rs resistors - If so, where should I place them?
- In the schematics you route HDMI_DP2_TXDP/N0 to D2+/- in the connector, is this correct?
Thank you,
