HDMI2CSI port from 28.2.1 to 32.1
I am working on a project that uses the HDMI2CSI drivers from this project: https://github.com/InES-HPMM/linux-l4t-4.4 which only has explicit support for up to 28.2.1. I would like to use this with the latest release, 32.1, but I am unsure of how to go about attempting to test this or how to begin the port.
My initial assumption says that I should replace the kernel sources with the ones for R32.1 and try to compile but I’m not sure if this is the correct course of action.
Thank you!
  1. Start from sdk manager. https://developer.nvidia.com/embedded/downloads
  2. Check the document https://docs.nvidia.com/jetson/l4t/index.html
For the most part porting from R28.2.1 to R32.1 is seamless. There are some minor differences. For example the csi-port device tree property has been renamed to port-index. We also needed to change some of our drivers due to an interface change from Linux 4.4 vs. 4.9 (the i2c-mux interface changed somewhat). Again, the changes are all minimal.
If you are starting with the github link that you have above you’ll need to modify the submodule targets to pull the correct repositories. You can reference source_sync.sh in the L4T host directory to find out the correct repositories and where they belong in your source tree.
Let us know how it goes.
Regards,
Greg
I’ve made some progress on the port but I’ve run into a major stumbling block. When attempting to start capture I am getting an error as the system tries to dynamically parse the device tree. I updated from csi-port to port-index and as far as I’m aware that is the only update I needed to make in the .dts file. Is there anything else I’m missing that would cause issues when dynamically parsing the file?
 * tegra186-quill-p3310-c03-00-base.dts Quill C03 Board
 * Copyright (c) 2016-2017, NVIDIA CORPORATION. All rights reserved.
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; version 2 of the License.
 * This program is distributed in the hope that it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
#include "tegra186-quill-p3310-1000-a00-00-base.dts"
    nvidia,dtsfilename = __FILE__;
    nvidia,dtbbuildtime = __DATE__, __TIME__;
	nvidia,fastboot-usb-vid = <0x0955>;
	nvidia,fastboot-usb-pid = <0xee16>;
    pinmux@2430000 {
        common {
            gpio_edp2_pp5 {
                status = "okay";
            gpio_edp3_pp6 {
                status = "okay";
    gpio@2200000 {
        sdmmc-wake-support-input {
            status = "okay";
        sdmmc-wake-support-output {
            status = "okay";
    fixed-regulators {
        regulator@1 {
            gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(P, 6) 0>;
    sdhci@3400000 {
        cd-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(P, 5) 0>;
        nvidia,cd-wakeup-capable;
    i2c@3160000 {
        ina3221x@40 {
            channel@0 {
                ti,shunt-resistor-mohm = <10>;
            channel@1 {
        ina3221x@41 {
            channel@0 {
                ti,shunt-resistor-mohm = <20>;
            channel@1 {
            channel@2 {
                ti,rail-name = "VDD_SYS_DDR";
	i2c@c240000 {
		bmi160@69 {
			compatible = "bmi,bmi160";
			reg = <0x69>;
			interrupt-parent = <&tegra_aon_gpio>;
			interrupts = <TEGRA_AON_GPIO(AA, 2) 0x01>;
			accelerometer_matrix    = [01 00 00 00 01 00 00 00 01];
			gyroscope_matrix        = [01 00 00 00 01 00 00 00 01];
			accelerometer_delay_us_min = <1250>;
			gyroscope_delay_us_min = <1250>;
			vdd-supply = <&spmic_sd3>;
			vdd_IO-supply = <&spmic_sd3>;
			status = "okay";
	mttcan@c310000 {
		status = "okay";
		gpio_can_stb = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 0) GPIO_ACTIVE_HIGH>;
		gpio_can_en = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 1) GPIO_ACTIVE_HIGH>;
		mram-params = <0 16 16 8 8 8 16 16 16>;
		tx-config = <8 8 0 64>;
		rx-config = <64 64 64>;
	mttcan@c320000 {
		status = "okay";
		gpio_can_stb = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 6) GPIO_ACTIVE_HIGH>;
		gpio_can_en = <&tegra_aon_gpio TEGRA_AON_GPIO(AA, 7) GPIO_ACTIVE_HIGH>;
    ahci-sata@3507000 {
        gpios = <&spmic 7 0>;
    pcie-controller@10003000 {
        pci@1,0 {
            nvidia,num-lanes = <4>;
            nvidia,disable-clock-request;
        pci@2,0 {
            nvidia,num-lanes = <0>;
        pci@3,0 {
            nvidia,num-lanes = <1>;
        xhci@3530000 {
        phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
            <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
            <&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>;
        phy-names = "utmi-0", "utmi-1", "usb3-0";
    pinctrl@3520000 {
        pinmux {
            usb3-std-A-port2 {
                nvidia,lanes = "usb3-0";
       bluedroid_pm {
        bluedroid_pm,reset-gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(H, 5) 0>;
    bpmp_i2c {
        spmic@3c {
            pinmux@0 {
                pin_gpio2 {
                    status = "disabled";
                pin_gpio3 {
                pin_gpio7 {
                    drive-push-pull = <1>;
            regulators {
                ldo0 {
                    maxim,active-fps-source = <MAX77620_FPS_SRC_NONE>;
                ldo6 {
                    regulator-boot-on;
                    regulator-always-on;
                ldo7 {
                    regulator-min-microvolt = <1000000>;
                    regulator-max-microvolt = <1000000>;
                ldo8 {
                    regulator-name = "dvdd-pex";
     * NOTE: the following is manually added
    /* CSI subdevice */
    i2c@3180000 {
        status = "okay";
        #address-cells = <1>;
        #size-cells = <0>;
        tc358840@0f {
            status = "okay";
            compatible = "toshiba,tc358840";
            reg = <0x0f>;
            devnode = "video0";
            /* Power Supply */
            vdig-supply = <&en_vdd_cam_1v2>;
            vif-supply = <&en_vdd_cam>;
            // clocks = <&hdmi_osc>;
            // clock-names = "refclk";
            reset-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(R, 5) GPIO_ACTIVE_LOW>;
            interrupt-parent = <&tegra_main_gpio>;
            interrupts = <TEGRA_MAIN_GPIO(R, 0) IRQ_TYPE_LEVEL_HIGH>;
            csi_port = <3>;
            refclk_hz = <48000000>; /* 40 - 50 MHz */
            ddc5v_delay = <1>; /* 50 ms */
            enable_hdcp = <0>;
            // line rate 1 Gbit / CSI lane
            lineinitcnt = <8000>;
            lptxtimecnt = <7>;
            tclk_headercnt = <0x00320206>;
            tclk_trailcnt = <0x00040005>;
            ths_headercnt = <0x00190008>;
            twakeup = <0x00004E20>;
            tclk_postcnt = <0x0000000A>;
            ths_trailcnt = <0x0010000B>;
            hstxvregcnt = <0x00000020>;
            /* PLL */
            /* Bps per lane is (refclk_hz / pll_prd + 1) * pll_fbd + 1 */
            pll_prd = <5>;
            pll_fbd = <125>;
            port {
                tc358840_out0: endpoint {
                    vc-id = <0>;
                    remote-endpoint = <&hdmi_to_csi_in0>;
                    data-lanes = <1 2 3 4>;
                    clock-lanes = <0>;
                    // clock-noncontinuous;
                    link-frequencies = /bits/ 64 <297000000>;
        tc358840@1f {
            status = "okay";
            reg = <0x1f>;
                    devnode = "video1";
            /* Power Supply */
            reset-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(R, 1) GPIO_ACTIVE_LOW>;
            interrupts = <TEGRA_MAIN_GPIO(N, 2) IRQ_TYPE_LEVEL_HIGH>;
            csi_port = <1>;
            enable_hdcp = <0>;
            lptxtimecnt = <7>;
            /* PLL */
            pll_prd = <5>;
            pll_fbd = <125>;
            port {
                tc358840_out1: endpoint {
                    vc-id = <1>;
                    remote-endpoint = <&hdmi_to_csi_in1>;
                    clock-lanes = <0>;
    host1x {
        /* Delete existing VI node to avoid conflicts */
        /delete-node/ vi;
        /* CSI related */
        vi@15700000 {
            // compatible = "nvidia,tegra186-gp-vi";
            compatible = "nvidia,tegra186-vi";
            status = "okay";
            #size-cells = <0>;
            num-channels = <2>;
            avdd_dsi_csi-supply = <&spmic_sd1>;
            /* COPY FROM BASE DT: tegra186-soc-base.dtsi ------------------- */
            power-domains = <&bpmp TEGRA186_POWER_DOMAIN_VE>;
            reg = <0x0 0x15700000 0x0 0x00100000>;
            interrupts = <0 201 0x04
                          0 202 0x04
                          0 203 0x04>;
            resets = <&tegra_car TEGRA186_RESET_VI>,
                     <&tegra_car TEGRA186_RESET_TSCTNVI>;
            reset-names = "vi", "tsctnvi";
            clocks = <&tegra_car TEGRA186_CLK_VI>,
                     <&tegra_car TEGRA186_CLK_NVCSI>,
                     <&tegra_car TEGRA186_CLK_NVCSILP>;
            clock-names = "vi", "nvcsi", "nvcsilp";
            #stream-id-cells = <1>;
            ports {
                status = "okay";
                #size-cells = <0>;
                /* TX2 interconnect ports */
                port@0 {
                    status = "okay";
                    reg = <0>;
                    hdmi_to_csi_vi_in0: endpoint {
                        status = "okay";
                        vc-id = <0>;
                        port-index = <0>;
                        bus-width = <8>; //<8>
                        // bus-width = <1>;
                        remote-endpoint = <&hdmi_2_csi_out0>;
                port@1 {
                    status = "okay";
                    reg = <1>;
                    hdmi_to_csi_vi_in1: endpoint {
                        status = "okay";
                        vc-id = <1>;
                        port-index = <4>;
                        bus-width = <4>;
                        remote-endpoint = <&hdmi_2_csi_out1>;
        nvcsi@150c0000 {
            compatible = "nvidia,tegra186-nvcsi";
            status = "okay";
            num-channels = <2>;
            #size-cells = <0>;
            channel@0 {
                status = "okay";
                reg = <0>;
                ports {
                    status = "okay";
                    #size-cells = <0>;
                    port@0 {
                        status = "okay";
                        reg = <0>;
                        hdmi_to_csi_in0: endpoint@0 { /* from I2C */
                            status = "okay";
                            port-index = <0>;
                            bus-width = <8>;
                            remote-endpoint = <&tc358840_out0>; /* to I2C */
                    port@1 {
                        status = "okay";
                        reg = <1>;
                        hdmi_2_csi_out0: endpoint@1 { /* from VI */
                            status = "okay";
                            remote-endpoint = <&hdmi_to_csi_vi_in0>; /* to VI */
            channel@1 {
                status = "okay";
                reg = <1>;
                ports {
                    status = "okay";
                    #size-cells = <0>;
                    port@0 {
                        status = "okay";
                        reg = <0>;
                        hdmi_to_csi_in1: endpoint@2 { /* from I2C */
                            status = "okay";
                            port-index = <4>;
                            bus-width = <4>;
                            remote-endpoint = <&tc358840_out1>; /* to I2C */
                    port@1 {
                        status = "okay";
                        reg = <1>;
                        hdmi_2_csi_out1: endpoint@3 { /* from VI */
                            status = "okay";
                            remote-endpoint = <&hdmi_to_csi_vi_in1>; /* to VI */
    mipical {
        status = "okay";
    fixed-regulators {
        /* HDMI2CSI / FPGA MADI BOARD REGULATORS */
        en_vdd_sys:regulator@118 {
            regulator-boot-on;
        en_vdd_cam:regulator@2 {
            regulator-boot-on;
        en_vdd_cam_1v2:regulator@12 {
            regulator-boot-on;
        /* FPGA MADI BOARD REGULATOR */
        en_avdd_disp_3v3:regulator@8 {
            regulator-boot-on;
/*** HDMI2CSI ***/
    /* set camera gpio direction to output */
    pinmux@2430000 {
        common {
             * Pull down the INT pin of the TC358840 (HDMI IN A) while
             * in reset in order to set i2c address 0x0F.
            qspi_sck_pr0 {
                nvidia,pins = "qspi_sck_pr0";
                nvidia,function = "rsvd1";
                nvidia,enable-input = <TEGRA_PIN_ENABLE>;
                nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
                nvidia,tristate = <TEGRA_PIN_DISABLE>;
             * Pull up the INT pin of the TC358840 (HDMI IN B) while
             * in reset in order to set i2c address 0x1F.
            gpio_cam3_pn2 {
                nvidia,pins = "gpio_cam3_pn2";
                nvidia,function = "rsvd2";
                nvidia,pull = <TEGRA_PIN_PULL_UP>;
    gpio@2200000 {
        camera-control-output-low {
            status = "okay";
            gpio-hog;
            output-low;
            gpios = <TEGRA_MAIN_GPIO(R, 5) 0
                 TEGRA_MAIN_GPIO(R, 1) 0>;
            label = "cam0-rst", "cam1-rst";
        camera-control-input {
            status = "okay";
            gpio-hog;
            input;
            gpios = <TEGRA_MAIN_GPIO(R, 0) 0
                 TEGRA_MAIN_GPIO(N, 2) 0>;
            label = "cam0-int", "cam1-int";
I failed to use HDMI2CSI driver on l4t32.3 as well. is there any progress on the driver?
