hi ,all
We need to use NX core board to develop a system with one camera,we use a HDMI2MIPI chip(lt6911uxc) that output mipi-cs2 signal. camera connects CSI0 with 2 lane.
our L4T version is 32.6.1. I find in BSP source has a LT6911UXC driver,( Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/i2c/lt6911uxc.c ),so I modify DTS(tegra194-camera-e2832.dtsi),
now when I use command “v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RGB --set-ctrl bypass_mode=0 --stream-mmap=3 --stream-count=100” to capture vidio ,system
report error "tegra194-vi5 15c10000.vi: vi_capture_setup: control failed, errno 2
[40394.029770] tegra194-vi5 15c10000.vi: vi capture setup failed "
I find errno 2 in capture.c ,so What does this error represent and how to check it?
Get the trace log to check if can get more clue.
v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, lt6911uxc 1-002b
Bus info : platform:15c10000.vi:0
Driver version: 4.9.253
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : ‘AR24’
Field : None
Bytes per Line : 7680
Size Image : 8294400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
sensor_configuration 0x009a2032 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
I modified tegra194-camera-e2832.dtsi:
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_out0>;
port@1 {
reg = <1>;
e2832_csi_out0: endpoint@1 {
remote-endpoint = <&e2832_vi_in0>;
i2c@c240000 {
e2832@2b {
compatible = “nvidia,lt6911uxc”;
/* I2C device address */
reg = <0x2b>;
/* V4L2 device node location */
devnode = "video0";
reset-gpios = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 1) GPIO_ACTIVE_HIGH>;
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "e2832";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
/* avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
/*post_crop_frame_drop = "0";*/
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
* num_of_exposure = "";
* Digital overlap(Dol) frames
* num_of_ignored_lines = "";
* Used for cropping, eg. OB lines + Ignored area of effective pixel lines
* num_of_lines_offset_0 = "";
* Used for cropping, vertical blanking in front of short exposure data
* If more Dol frames are used, it can be extended, eg. num_of_lines_offset_1
* num_of_ignored_pixels = "";
* Used for cropping, The length of line info(pixels)
* num_of_left_margin_pixels = "";
* Used for cropping, the size of the left edge margin before
* the active pixel area (after ignored pixels)
* num_of_right_margin_pixels = "";
* Used for cropping, the size of the right edge margin after
mode0 { // E2832_1920x1080_60Fps
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
mode_type = "rgb";
pixel_phase = "rgb888";
csi_pixel_bit_depth = "24";
line_length = "1920";
inherent_gain = "1";
mclk_multiplier = "24";
pix_clk_hz = "576000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
step_framerate = "1";
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "16667"; /* us */
mode1 { // E2832_3840x2160
mclk_khz = "24000";
num_lanes = "8";
phy_mode = "DPHY";
active_w = "3840";
active_h = "2160";
mode_type = "rgb";
line_length = "3840";
gain_factor = "16";
mode2 { // E2832_1280x720_60Fps
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
mode_type = "rgb";
line_length = "1280";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_csi_in0>;
egra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e2832_ltx6911";
position = "bottom";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "e2832 2-002b";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/e2832@2b";
hi CCC:what trace log do we need?
@ShaneCCC any advise?
Check this link for the instruction to enable the trace log.
@ShaneCCC “Check this link” mean that check HDMITOMIPI physical connect?
Sorry didn’t post the link.
@ShaneCCC
cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 81/81 #P:6
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:3-2067 [000] .... 196.475414: rtos_queue_peek_from_isr_failed: tstamp:6684334203 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 196.643415: rtos_queue_peek_from_isr_failed: tstamp:6689334204 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 196.811397: rtos_queue_peek_from_isr_failed: tstamp:6694334207 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 196.923391: rtos_queue_peek_from_isr_failed: tstamp:6699334208 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.091409: rtos_queue_peek_from_isr_failed: tstamp:6704334205 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.259417: rtos_queue_peek_from_isr_failed: tstamp:6709334229 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.427402: rtos_queue_peek_from_isr_failed: tstamp:6714334208 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.595412: rtos_queue_peek_from_isr_failed: tstamp:6719334203 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.763452: rtos_queue_peek_from_isr_failed: tstamp:6724334200 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 197.931394: rtos_queue_peek_from_isr_failed: tstamp:6729334217 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.043407: rtos_queue_peek_from_isr_failed: tstamp:6734334208 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.211412: rtos_queue_peek_from_isr_failed: tstamp:6739334204 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.379445: rtos_queue_peek_from_isr_failed: tstamp:6744334208 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.547418: rtos_queue_peek_from_isr_failed: tstamp:6749334203 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.715492: rtos_queue_peek_from_isr_failed: tstamp:6754334204 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 198.883407: rtos_queue_peek_from_isr_failed: tstamp:6759334201 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.051407: rtos_queue_peek_from_isr_failed: tstamp:6764334211 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.163410: rtos_queue_peek_from_isr_failed: tstamp:6769334211 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.331407: rtos_queue_peek_from_isr_failed: tstamp:6774334209 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.499398: rtos_queue_peek_from_isr_failed: tstamp:6779334221 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.667472: rtos_queue_peek_from_isr_failed: tstamp:6784334209 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 199.835399: rtos_queue_peek_from_isr_failed: tstamp:6789334226 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 200.003402: rtos_queue_peek_from_isr_failed: tstamp:6794334201 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 200.171461: rtos_queue_peek_from_isr_failed: tstamp:6799334214 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 200.283409: rtos_queue_peek_from_isr_failed: tstamp:6804334207 queue:0x0bcbcf78
kworker/0:3-2067 [000] .... 200.339418: rtos_queue_peek_from_isr_failed: tstamp:6804956905 queue:0x0bcbcf78
v4l2-ctl-7665 [005] .... 219.597299: tegra_channel_open: vi-output, lt6911uxc 1-002b
v4l2-ctl-7665 [000] .... 219.599756: tegra_channel_set_power: lt6911uxc 1-002b : 0x1
v4l2-ctl-7665 [000] .... 219.599774: camera_common_s_power: status : 0x1
v4l2-ctl-7665 [000] .... 219.601101: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-7665 [000] .... 219.601104: csi_s_power: enable : 0x1
v4l2-ctl-7665 [000] .... 219.618076: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 9
v4l2-ctl-7665 [000] .... 219.640437: tegra_channel_close: vi-output, lt6911uxc 1-002b
v4l2-ctl-7665 [000] .... 219.645422: tegra_channel_set_power: lt6911uxc 1-002b : 0x0
v4l2-ctl-7665 [000] .... 219.645471: camera_common_s_power: status : 0x0
v4l2-ctl-7665 [000] .... 219.645743: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-7665 [000] .... 219.645754: csi_s_power: enable : 0x0
kworker/0:1-789 [000] .... 219.659542: rtos_queue_peek_from_isr_failed: tstamp:7408875401 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 219.659560: rtcpu_start: tstamp:7408877172
kworker/0:1-789 [000] .... 219.659616: rtos_queue_send_from_isr_failed: tstamp:7408890099 queue:0x0bcb41f8
kworker/0:1-789 [000] .... 219.659617: rtos_queue_send_from_isr_failed: tstamp:7408890249 queue:0x0bcb8a60
kworker/0:1-789 [000] .... 219.659618: rtos_queue_send_from_isr_failed: tstamp:7408890398 queue:0x0bcba5e0
kworker/0:1-789 [000] .... 219.659621: rtos_queue_send_from_isr_failed: tstamp:7408890545 queue:0x0bcbb3a0
kworker/0:1-789 [000] .... 219.659623: rtos_queue_send_from_isr_failed: tstamp:7408890690 queue:0x0bcbc160
kworker/0:1-789 [000] .... 219.827434: rtos_queue_peek_from_isr_failed: tstamp:7413875952 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 219.995495: rtos_queue_peek_from_isr_failed: tstamp:7418875966 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.107415: rtos_queue_peek_from_isr_failed: tstamp:7423875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.275434: rtos_queue_peek_from_isr_failed: tstamp:7428875952 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.443449: rtos_queue_peek_from_isr_failed: tstamp:7433875970 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.611413: rtos_queue_peek_from_isr_failed: tstamp:7438875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.779408: rtos_queue_peek_from_isr_failed: tstamp:7443875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 220.947391: rtos_queue_peek_from_isr_failed: tstamp:7448875956 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.115399: rtos_queue_peek_from_isr_failed: tstamp:7453875955 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.227399: rtos_queue_peek_from_isr_failed: tstamp:7458875965 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.395420: rtos_queue_peek_from_isr_failed: tstamp:7463875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.563487: rtos_queue_peek_from_isr_failed: tstamp:7468875952 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.731407: rtos_queue_peek_from_isr_failed: tstamp:7473875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 221.899408: rtos_queue_peek_from_isr_failed: tstamp:7478875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.067475: rtos_queue_peek_from_isr_failed: tstamp:7483875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.235410: rtos_queue_peek_from_isr_failed: tstamp:7488875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.347419: rtos_queue_peek_from_isr_failed: tstamp:7493875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.515498: rtos_queue_peek_from_isr_failed: tstamp:7498875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.683409: rtos_queue_peek_from_isr_failed: tstamp:7503875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 222.851404: rtos_queue_peek_from_isr_failed: tstamp:7508875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.019413: rtos_queue_peek_from_isr_failed: tstamp:7513875974 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.187423: rtos_queue_peek_from_isr_failed: tstamp:7518875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.355419: rtos_queue_peek_from_isr_failed: tstamp:7523875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.467429: rtos_queue_peek_from_isr_failed: tstamp:7528875958 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.635401: rtos_queue_peek_from_isr_failed: tstamp:7533875960 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.803406: rtos_queue_peek_from_isr_failed: tstamp:7538875960 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 223.971410: rtos_queue_peek_from_isr_failed: tstamp:7543875955 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.139408: rtos_queue_peek_from_isr_failed: tstamp:7548875961 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.307438: rtos_queue_peek_from_isr_failed: tstamp:7553875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.475398: rtos_queue_peek_from_isr_failed: tstamp:7558875956 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.587411: rtos_queue_peek_from_isr_failed: tstamp:7563875965 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.755631: rtos_queue_peek_from_isr_failed: tstamp:7568875773 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 224.923416: rtos_queue_peek_from_isr_failed: tstamp:7573875953 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 225.091400: rtos_queue_peek_from_isr_failed: tstamp:7578875952 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 225.259406: rtos_queue_peek_from_isr_failed: tstamp:7583875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 225.427429: rtos_queue_peek_from_isr_failed: tstamp:7588875957 queue:0x0bcbcf78
kworker/0:1-789 [000] .... 225.427435: rtos_queue_peek_from_isr_failed: tstamp:7588956967 queue:0x0bcbcf78
The trace log show didn’t receive any validate data from MIPI bus.
Did you probe the signal to confirm it?
I can’t tell if the DTS is correctly or not. You need check with your HW connection to confirm the port-index/bus-width
@ShaneCCC we use CSI0,so port-index is 0 and bus-width is 2?
Yes, that’s correct. Maybe need to confirm the output signal follow MIPI spec.
@ShaneCCC we checkout mipi signal,its ok,so why we dont capture any MIPI signal?HDMI input is 1080P/30f,Are the configurations in the red boxes of our DTS correct?
num_lanes is correct and pix_clk_hz should doesn’t matter
@ShaneCCC What should the pix_clk_hz shoud be?
Have a check this document for detail information.
