Headless Audio2Gesture?
Is there a way to run Audio2Gesture in a headless mode? If not:
  1. Are there any APIs currently in the works (similar to the Rest API for Audio2Face)?
  2. Could an extension or connector be created for Audio2Gesture that:
    a. takes in a model
    b. animates that model based on an audio file
    c. exports the geometry of the animation as a .usd or provides some kind of output stream for rendering.
I could probably figure out the coding if you would only be so kind as to point me in the right vector.
Let me see if I can someone to help from A2F
