We are trying to get a bluetooth speaker working with the TX2 running headless. I’ve done the “Bluetooth Device Settings” section in the L4T docs and we can pair/connect to the speaker without issue. However PulseAudio doesn’t create a bluetooth sound card unless we log into Unity on a monitor and I can’t seem to find it anywhere.
Is it possible to use bluetooth without starting up Unity? Almost everything I’ve found online seems to assume you can use the GUI.
$ pactl list modules | grep bluetooth
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
